cgal-discuss - Re: [cgal-discuss] Problems on segment Voronoi diagram
  • To:
  • Subject: Re: [cgal-discuss] Problems on segment Voronoi diagram
  • Date: Fri, 23 Apr 2010 11:03:43 +0300
What you describe sounds really strange. Could you be more precise (Again code and examples will help) as to what exactl you did?
Integer coordinates should be okay. I do not see any reason why integer coordinates would cause a problem.
- m.
On 23 Apr 2010, at 11:00, Vu, Khuong wrote:
By the way, have you guys tried non-integer coordinates? I used exactly the same declaration as in the demo with only about 80 segments. It was extremely slow, taking hours! However, the Delaunay construction was much faster. Could you please tell me what was wrong with that?
Also, were you aware of a possible bug in Voronoi diagram, in which the Voronoi construction procedure misses some vertex although the Delaunay gives the correct result?
Thank you,
Khuong
________________________________________
Sent: Friday, April 23, 2010 1:43 AM
To:
Try using CGAL::Simple_cartesian<CGAL::Gmpq> as your exact kernel.
Also using the segment Delaunay graph hierarchy should make things
faster.
There are also other alternatives for constructing the segment
Delaunay graph even faster, but they apply only if you know all your
input in advance (i.e., they are not incremental).
As far as the problem with more than 5000 segments is concerned,
please send the data, along with the actual code you used to compute
the segment Delaunay graph, so that I can take a look at them.
- m.
On 23 Apr 2010, at 05:36, Vu, Khuong wrote:
Hi there,
I think what you did was good. I got the same thing working with
Voronoi diagram. I guess it is the problem of Voronoi diagram adapter.
You can check if it is by constructing the DELAUNAY diagram of the
same set of input instead of Vornoi diagram. If it runs reasonably
fast, then it is the Voronoi adapter to have trouble. You can look
at the header definition of the SegmentDelaunayGraph demo. The
declaration should be good for you since it deals with no strongly
intersection. However, it is Delaunay. Constructing the Voronoi
still runs pretty slow though.
Please let me know if you need further help. I have written an
alternative Voronoi adapter, currently just for myself. But I'm now
away from my desk.
Khuong
Sent: Thursday, April 22, 2010 8:01 PM
To:
Subject: [cgal-discuss] Problems on segment Voronoi diagram
I am constructing Vornoi diagrams using CGAL, the segments are all
from a
polygonal line, they are consecutive, and there are
weak intersections as CGAL describes.
Firstly,I chose MP_Float as the data type for EK, however, the
running
time is rather slow,
even slower than the results given in the corresponding papar<< A
robust and
efficient implementation for the segment Voronoi diagram>>
in 2004.
Then, I chose Simple_cartesian<double> as EK, this time the running
time is
rather short , however, the checking function is_valid()
returns false. And for segments more than 5000, the program corrupted.
Could someone give a trait and policy configurtion ,under which I
can build
Voronoi diagram of a polygonal line efficiently? Thank you
The following is my current configuration(under which the program runs
quite slow, if replace EK with Simple_cartesian<double>,
the build time is short but for more than 5000 segments the program
corrupts):
typedef CGAL::Quotient<CGAL::MP_Float> ENT;
typedef CGAL::Simple_cartesian<double> CK;
typedef CGAL::Simple_cartesian<ENT> EK;
typedef
CGAL
::Segment_Delaunay_graph_filtered_traits_2
<CK,CGAL::Field_with_sqrt_tag,
EK, CGAL::Field_tag> Gt;
typedef CGAL::Segment_Delaunay_graph_2<Gt> SDG2;
typedef CGAL::Segment_Delaunay_graph_adaptation_traits_2<SDG2>
TRAIT;
typedef
CGAL ::Segment_Delaunay_graph_caching_degeneracy_removal_policy_2<SDG2>
POLICY;
typedef CGAL::Voronoi_diagram_2<SDG2,TRAIT,POLICY> SEG_VD;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problems-on-segment-Voronoi-diagram-tp2023020p2023020.html
