cgal-discuss - Re: [cgal-discuss] RE: Problems on segment Voronoi diagram
  • To:
  • Subject: Re: [cgal-discuss] RE: Problems on segment Voronoi diagram
  • Date: Fri, 23 Apr 2010 11:07:04 +0300
Could you also send your code, that is the program that you use to produce the results below?
- m.
On 23 Apr 2010, at 11:04, Bai wrote:
Thanks very much for replying.
I've just tested the insertion into segment Delaunay Graph, the tests were
performed on the same data set, the segment set is actually a discrete line,
containing about 8000 segnent connecting each other
sequentially at endpoints. The different size of input is controlled simply
changing the number of input segments.
The following are the results, still very slow, (time unit is ms):
Result 1: EK= Simple_cartesian<double>
50 segments are read in
15.5716
200 segments are read in
72.0865
250 segments are read in
93.0119
500 segments are read in
305.27
1000 segments are read in
1347.81
2500 segments are read in
8496.68
3000 segments are read in
12208.4
Still, when 5000 segment are read in, my program corrupted.
Result 2: EK=Simple_cartesian<ENT>
2577.35
25875.1
35973.3
104792
338392
1.51143e+006
I did not test on size more than 2500 .
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problems-on-segment-Voronoi-diagram-tp2023020p2034004.html
