- To:
- Subject: Re: [cgal-discuss] Re: is fast location for periodic Delaunay broken?
- Date: Mon, 03 May 2010 18:36:09 +0200
Hi Ariel,
here is the patch. You have to copy the two attached files to your include/CGAL folder (replacing the existing ones). Please tell me if there are any problems.
Thanks again for your report!
Manuel
On 29/04/10 20:29, Ariel Keselman wrote:
Hi,
Thanks for the reply. The program crashes-
The point set that i have sent actually contains only 667 points.
The program you write crashes at point 987, with the point set
attached here:
http://n4.nabble.com/forum/FileDownload.jtp?type=n&id=2076004&name=points.xyz
points.xyz
So, I do think it's a bug...
// Copyright (c) 1999-2003,2006-2009 INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL:
svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.6-branch/Periodic_3_triangulation_3/include/CGAL/Periodic_3_triangulation_3.h
// $Id: Periodic_3_triangulation_3.h 53867 2010-01-28 12:18:19Z lrineau $
// Author(s) : Monique Teillaud
// Sylvain Pion
// Nico Kruithof
// Manuel Caroli
#ifndef CGAL_PERIODIC_3_TRIANGULATION_3_H
#define CGAL_PERIODIC_3_TRIANGULATION_3_H
#include <CGAL/basic.h>
#include <iostream>
#include <algorithm>
#include <cmath>
#include <functional>
#include <list>
#include <boost/tuple/tuple.hpp>
#include <boost/random/linear_congruential.hpp>
#include <boost/random/uniform_smallint.hpp>
#include <boost/random/variate_generator.hpp>
#include <CGAL/triangulation_assertions.h>
#include <CGAL/Triangulation_data_structure_3.h>
#include <CGAL/Periodic_3_triangulation_ds_cell_base_3.h>
#include <CGAL/Periodic_3_triangulation_ds_vertex_base_3.h>
#include <CGAL/Triangulation_cell_base_3.h>
#include <CGAL/Triangulation_vertex_base_3.h>
#include <CGAL/Periodic_3_triangulation_iterators_3.h>
#include <CGAL/Unique_hash_map.h>
CGAL_BEGIN_NAMESPACE
template < class GT, class TDS > class Periodic_3_triangulation_3;
template < class GT, class TDS > std::istream& operator>>
(std::istream& is, Periodic_3_triangulation_3<GT,TDS> &tr);
template < class GT, class TDS > std::ostream& operator<<
(std::ostream& os, const Periodic_3_triangulation_3<GT,TDS> &tr);
/**\class Periodic_3_triangulation_3
* \brief Implements functionality for computing in periodic space.
* There are several things that are special to computing in $\mathbb{T}^3$
* such as
* - periodicity --> offsets
* - no infinite vertex
* - no degenerate dimensions
* All functions that are affected can be found in this class. In case it is
* necessary to provide different implementations for Delaunay and regular
* triangulation, we work with visitors.
class TDS = Triangulation_data_structure_3 <
Triangulation_vertex_base_3<
GT, Periodic_3_triangulation_ds_vertex_base_3<>
Triangulation_cell_base_3<
GT, Periodic_3_triangulation_ds_cell_base_3<>
: public Triangulation_utils_3
friend std::istream& operator>> <>
(std::istream& is, Periodic_3_triangulation_3<GT, TDS> &tr);
typedef Periodic_3_triangulation_3<GT,TDS> Self;
public:
typedef GT Geometric_traits;
typedef TDS Triangulation_data_structure;
typedef typename GT::Periodic_3_offset_3 Offset;
typedef typename GT::Iso_cuboid_3 Iso_cuboid;
typedef array<int, 3> Covering_sheets;
typedef typename GT::Point_3 Point;
typedef typename GT::Segment_3 Segment;
typedef typename GT::Triangle_3 Triangle;
typedef typename GT::Tetrahedron_3 Tetrahedron;
typedef std::pair<Point,Offset> Periodic_point;
typedef array< std::pair<Point,Offset>, 2> Periodic_segment;
typedef array< std::pair<Point,Offset>, 3> Periodic_triangle;
typedef array< std::pair<Point,Offset>, 4> Periodic_tetrahedron;
typedef typename TDS::Vertex Vertex;
typedef typename TDS::Cell Cell;
typedef typename TDS::Facet Facet;
typedef typename TDS::Edge Edge;
typedef typename TDS::Vertex_handle Vertex_handle;
typedef typename TDS::Cell_handle Cell_handle;
typedef typename TDS::size_type size_type;
typedef typename TDS::difference_type difference_type;
typedef typename TDS::Cell_iterator Cell_iterator;
typedef typename TDS::Facet_iterator Facet_iterator;
typedef typename TDS::Edge_iterator Edge_iterator;
typedef typename TDS::Vertex_iterator Vertex_iterator;
typedef typename TDS::Cell_circulator Cell_circulator;
typedef typename TDS::Facet_circulator Facet_circulator;
typedef Cell_iterator All_cells_iterator;
typedef Facet_iterator All_facets_iterator;
typedef Edge_iterator All_edges_iterator;
typedef Vertex_iterator All_vertices_iterator;
private:
typedef typename GT::FT FT;
typedef std::pair< Vertex_handle, Offset > Virtual_vertex;
typedef std::map<Vertex_handle, Virtual_vertex>
Virtual_vertex_map;
typedef typename Virtual_vertex_map::const_iterator
Virtual_vertex_map_it;
typedef std::map<Vertex_handle, std::vector<Vertex_handle > >
Virtual_vertex_reverse_map;
typedef typename Virtual_vertex_reverse_map::const_iterator
Virtual_vertex_reverse_map_it;
typedef Triple< Vertex_handle, Vertex_handle, Vertex_handle >
Vertex_triple;
public:
typedef Periodic_3_triangulation_tetrahedron_iterator_3<Self>
Periodic_tetrahedron_iterator;
typedef Periodic_3_triangulation_triangle_iterator_3<Self>
Periodic_triangle_iterator;
typedef Periodic_3_triangulation_segment_iterator_3<Self>
Periodic_segment_iterator;
typedef Periodic_3_triangulation_point_iterator_3<Self>
Periodic_point_iterator;
typedef Point value_type;
typedef const value_type& const_reference;
typedef Tag_false Weighted_tag;
public:
enum Iterator_type {
STORED=0,
UNIQUE, //1
STORED_COVER_DOMAIN, //2
UNIQUE_COVER_DOMAIN };//3
enum Locate_type {
VERTEX=0,
EDGE, //1
FACET, //2
CELL, //3
EMPTY , //4
OUTSIDE_CONVEX_HULL, // unused, for compatibility with Alpha_shape_3
OUTSIDE_AFFINE_HULL }; // unused, for compatibility with Alpha_shape_3
private:
Geometric_traits _gt;
Triangulation_data_structure _tds;
Iso_cuboid _domain;
/// This threshold should be chosen such that if all edges are shorter,
/// we can be sure that there are no self-edges anymore.
FT edge_length_threshold;
/// This adjacency list stores all edges that are longer than
/// edge_length_threshold.
std::map< Vertex_handle, std::list<Vertex_handle> > too_long_edges;
unsigned int too_long_edge_counter;
/// map of offsets for periodic copies of vertices
Virtual_vertex_map virtual_vertices;
Virtual_vertex_reverse_map virtual_vertices_reverse;
protected:
/// v_offsets temporarily stores all the vertices on the border of a
/// conflict region.
mutable std::vector<Vertex_handle> v_offsets;
private:
/// Determines if we currently compute in 3-cover or 1-cover.
Covering_sheets _cover;
public:
/** @name Creation */ //@{
Periodic_3_triangulation_3(
const Iso_cuboid & domain = Iso_cuboid(0,0,0,1,1,1),
const Geometric_traits & gt = Geometric_traits())
: _gt(gt), _tds(), _domain(domain), too_long_edge_counter(0) {
_gt.set_domain(_domain);
CGAL_triangulation_precondition(
_domain.xmax()-_domain.xmin() == _domain.ymax() - _domain.ymin());
_domain.ymax()-_domain.ymin() == _domain.zmax() - _domain.zmin());
_domain.zmax()-_domain.zmin() == _domain.xmax() - _domain.xmin());
_cover = make_array(3,3,3);
init_tds();
edge_length_threshold = FT(0.166) * (_domain.xmax()-_domain.xmin())
* (_domain.xmax()-_domain.xmin());
private:
// Copy constructor helpers
class Finder;
void copy_multiple_covering(const Periodic_3_triangulation_3 & tr);
public:
// Copy constructor duplicates vertices and cells
Periodic_3_triangulation_3(const Periodic_3_triangulation_3 & tr)
: _gt(tr.geom_traits()),
_domain(tr._domain),
edge_length_threshold(tr.edge_length_threshold),
_cover(tr._cover) {
if (is_1_cover()) {
_tds = tr.tds();
} else {
copy_multiple_covering(tr);
CGAL_triangulation_expensive_postcondition(*this == tr);
/** @name Assignment */ //@{
Periodic_3_triangulation_3 & operator=(Periodic_3_triangulation_3 tr) {
swap(tr);
return *this;
void swap(Periodic_3_triangulation_3 &tr) {
std::swap(tr._gt, _gt);
_tds.swap(tr._tds);
std::swap(_domain,tr._domain);
std::swap(edge_length_threshold,tr.edge_length_threshold);
std::swap(too_long_edges,tr.too_long_edges);
std::swap(too_long_edge_counter,tr.too_long_edge_counter);
std::swap(virtual_vertices,tr.virtual_vertices);
std::swap(virtual_vertices_reverse,tr.virtual_vertices_reverse);
std::swap(_cover, tr._cover);
/// Clears the triangulation and initializes it again.
void clear() {
_tds.clear();
init_tds();
too_long_edges.clear();
too_long_edge_counter = 0;
virtual_vertices.clear();
virtual_vertices_reverse.clear();
v_offsets.clear();
private:
/// Initializes the triangulation data structure
void init_tds() {
_tds.set_dimension(-2);
v_offsets.reserve(48);
public:
/** @name Access functions */ //@{
const Geometric_traits& geom_traits() const { return _gt; }
const TDS & tds() const { return _tds; }
TDS & tds() { return _tds; }
const Iso_cuboid & domain() const { return _domain; }
// TODO: Documentation and tests
void set_domain(const Iso_cuboid & domain) {
clear();
_domain = domain;
_gt.set_domain(domain);
const Covering_sheets & number_of_sheets() const { return _cover; }
const std::pair<Vertex_handle, Offset> original_vertex(
const Vertex_handle v) const {
return (virtual_vertices.find(v) == virtual_vertices.end()) ?
std::make_pair(v,Offset()) : virtual_vertices.find(v)->second;
const std::vector<Vertex_handle>& periodic_copies(
CGAL_triangulation_precondition(number_of_sheets() != make_array(1,1,1) );
virtual_vertices.find(v) == virtual_vertices.end());
CGAL_triangulation_assertion(
virtual_vertices_reverse.find(v) != virtual_vertices_reverse.end());
return virtual_vertices_reverse.find(v)->second;
bool is_extensible_triangulation_in_1_sheet_h1() const;
bool is_extensible_triangulation_in_1_sheet_h2() const;
bool is_triangulation_in_1_sheet() const;
void convert_to_1_sheeted_covering();
void convert_to_27_sheeted_covering();
size_type number_of_cells() const {
if (is_1_cover()) return _tds.number_of_cells();
else return _tds.number_of_cells()/27;
size_type number_of_facets() const {
if (is_1_cover()) return _tds.number_of_facets();
else return _tds.number_of_facets()/27;
size_type number_of_edges() const {
if (is_1_cover()) return _tds.number_of_edges();
else return _tds.number_of_edges()/27;
size_type number_of_vertices() const {
if (is_1_cover()) return _tds.number_of_vertices();
else return _tds.number_of_vertices()/27;
size_type number_of_stored_cells() const {
size_type number_of_stored_facets() const {
size_type number_of_stored_edges() const {
size_type number_of_stored_vertices() const {
protected:
bool is_1_cover() const {
bool flag;
flag = ((_cover[0] == 1) && (_cover[1] == 1) && (_cover[2] == 1));
return flag;
public:
bool is_virtual(Vertex_handle v) {
if (is_1_cover()) return false;
return (virtual_vertices.find(v) != virtual_vertices.end());
public:
// Offset converters
int off_to_int(const Offset & off) const {
CGAL_triangulation_assertion( off.x()==0 || off.x() ==1 );
CGAL_triangulation_assertion( off.y()==0 || off.y() ==1 );
CGAL_triangulation_assertion( off.z()==0 || off.z() ==1 );
int i = ((off.x()&1)<<2) + ((off.y()&1)<<1) + ((off.z()&1));
return i;
Offset int_to_off(int i) const {
return Offset((i>>2)&1,(i>>1)&1,i&1);
void set_offsets(Cell_handle c, int o0,int o1,int o2,int o3) {
int off0[3] = {(o0>>2)&1,(o0>>1)&1,(o0&1)};
int off1[3] = {(o1>>2)&1,(o1>>1)&1,(o1&1)};
int off2[3] = {(o2>>2)&1,(o2>>1)&1,(o2&1)};
int off3[3] = {(o3>>2)&1,(o3>>1)&1,(o3&1)};
for (int i=0; i<3; i++) {
int min_off = (std::min)((std::min)(off0[i],off1[i]),
(std::min)(off2[i],off3[i]));
if (min_off != 0) {
off0[i] -= min_off; off1[i] -= min_off;
off2[i] -= min_off; off3[i] -= min_off;
o0 = ((off0[0]&1)<<2)+((off0[1]&1)<<1)+(off0[2]&1);
o1 = ((off1[0]&1)<<2)+((off1[1]&1)<<1)+(off1[2]&1);
o2 = ((off2[0]&1)<<2)+((off2[1]&1)<<1)+(off2[2]&1);
o3 = ((off3[0]&1)<<2)+((off3[1]&1)<<1)+(off3[2]&1);
c->set_offsets(o0,o1,o2,o3);
template <class Offset>
void set_offsets(Cell_handle c, Offset o0,Offset o1,Offset o2,Offset o3) {
int off0[3] = {o0.x(),o0.y(),o0.z()};
int off1[3] = {o1.x(),o1.y(),o1.z()};
int off2[3] = {o2.x(),o2.y(),o2.z()};
int off3[3] = {o3.x(),o3.y(),o3.z()};
if (min_off != 0) {
CGAL_triangulation_assertion((std::min)((std::min)(off0[0],off1[0]),
(std::min)(off2[0],off3[0])) == 0);
CGAL_triangulation_assertion((std::min)((std::min)(off0[1],off1[1]),
(std::min)(off2[1],off3[1])) == 0);
CGAL_triangulation_assertion((std::min)((std::min)(off0[2],off1[2]),
(std::min)(off2[2],off3[2])) == 0);
CGAL_triangulation_assertion((0 <= off0[0]) && (off0[0] < 2));
CGAL_triangulation_assertion((0 <= off1[0]) && (off1[0] < 2));
CGAL_triangulation_assertion((0 <= off2[0]) && (off2[0] < 2));
CGAL_triangulation_assertion((0 <= off3[0]) && (off3[0] < 2));
CGAL_triangulation_assertion((0 <= off0[1]) && (off0[1] < 2));
CGAL_triangulation_assertion((0 <= off1[1]) && (off1[1] < 2));
CGAL_triangulation_assertion((0 <= off2[1]) && (off2[1] < 2));
CGAL_triangulation_assertion((0 <= off3[1]) && (off3[1] < 2));
CGAL_triangulation_assertion((0 <= off0[2]) && (off0[2] < 2));
CGAL_triangulation_assertion((0 <= off1[2]) && (off1[2] < 2));
CGAL_triangulation_assertion((0 <= off2[2]) && (off2[2] < 2));
CGAL_triangulation_assertion((0 <= off3[2]) && (off3[2] < 2));
int o0i = ((off0[0]&1)<<2)+((off0[1]&1)<<1)+(off0[2]&1);
int o1i = ((off1[0]&1)<<2)+((off1[1]&1)<<1)+(off1[2]&1);
int o2i = ((off2[0]&1)<<2)+((off2[1]&1)<<1)+(off2[2]&1);
int o3i = ((off3[0]&1)<<2)+((off3[1]&1)<<1)+(off3[2]&1);
c->set_offsets(o0i,o1i,o2i,o3i);
public:
/** @name Wrapping the traits */ //@{
Comparison_result compare_xyz(const Point &p1, const Point &p2) const {
return geom_traits().compare_xyz_3_object()(p1,p2);
Comparison_result compare_xyz(const Point &p1, const Point&p2,
const Offset &o1, const Offset &o2) const {
return geom_traits().compare_xyz_3_object()(p1,p2,o1,o2);
Orientation orientation(
const Point &p1, const Point &p2, const Point &p3, const Point &p4)
const {
return geom_traits().orientation_3_object()(p1,p2,p3,p4);
const Point &p1, const Point &p2, const Point &p3, const Point &p4,
const Offset &o1, const Offset &o2, const Offset &o3, const Offset &o4)
const {
return geom_traits().orientation_3_object()(p1,p2,p3,p4,o1,o2,o3,o4);
bool equal(const Point &p1, const Point &p2) const {
return compare_xyz(p1,p2) == EQUAL;
bool equal(const Point &p1, const Point &p2,
return compare_xyz(p1,p2,o1,o2) == EQUAL;
bool coplanar(
const {
return orientation(p1,p2,p3,p4) == COPLANAR;
bool coplanar(
const {
return orientation(p1,p2,p3,p4,o1,o2,o3,o4) == COPLANAR;
Periodic_tetrahedron construct_periodic_3_tetrahedron(
const {
return make_array(std::make_pair(p1,Offset()),
std::make_pair(p2,Offset()),
std::make_pair(p3,Offset()), std::make_pair(p4,Offset()));
const {
return make_array(std::make_pair(p1,o1), std::make_pair(p2,o2),
std::make_pair(p3,o3), std::make_pair(p4,o4));
Periodic_triangle construct_periodic_3_triangle(
const Point &p1, const Point &p2, const Point &p3) const {
std::make_pair(p2,Offset()), std::make_pair(p3,Offset()));
const Offset &o1, const Offset &o2, const Offset &o3) const {
std::make_pair(p3,o3));
Periodic_segment construct_periodic_3_segment(
std::make_pair(p2,Offset()));
return make_array(std::make_pair(p1,o1), std::make_pair(p2,o2));
Tetrahedron construct_tetrahedron(
const {
return geom_traits().construct_tetrahedron_3_object()(p1,p2,p3,p4);
const {
return geom_traits().construct_tetrahedron_3_object()(p1,p2,p3,p4,
o1,o2,o3,o4);
Tetrahedron construct_tetrahedron(const Periodic_tetrahedron& tet) {
return construct_tetrahedron(
tet[0].first, tet[1].first, tet[2].first, tet[3].first,
tet[0].second, tet[1].second, tet[2].second, tet[3].second);
Triangle construct_triangle(
return geom_traits().construct_triangle_3_object()(p1,p2,p3);
return geom_traits().construct_triangle_3_object()(p1,p2,p3,o1,o2,o3);
Triangle construct_triangle(const Periodic_triangle& tri) {
return construct_triangle(tri[0].first, tri[1].first, tri[2].first,
tri[0].second, tri[1].second, tri[2].second);
Segment construct_segment(const Point &p1, const Point &p2) const {
return geom_traits().construct_segment_3_object()(p1, p2);
Segment construct_segment(const Point &p1, const Point &p2,
return geom_traits().construct_segment_3_object()(p1,p2,o1,o2);
Segment construct_segment(const Periodic_segment& seg) const {
return construct_segment(seg[0].first, seg[1].first,
seg[0].second, seg[1].second);
Point construct_point(const Point& p, const Offset &o) const {
return geom_traits().construct_point_3_object()(p,o);
Point construct_point(const Periodic_point& pp) const {
return construct_point(pp.first, pp.second);
public:
/** @name Geometric access functions */ //@{
Periodic_point periodic_point( const Vertex_handle v ) const {
if (is_1_cover()) return std::make_pair(v->point(), Offset(0,0,0));
Virtual_vertex_map_it it = virtual_vertices.find(v);
if (it == virtual_vertices.end()) {
// if v is not contained in virtual_vertices, then it is in the
// original domain.
} else {
// otherwise it has to be looked up as well as its offset.
return std::make_pair(it->second.first->point(), it->second.second);
Periodic_point periodic_point( const Cell_handle c, int i) const {
if (is_1_cover()) return std::make_pair(c->vertex(i)->point(),
int_to_off(c->offset(i)));
Virtual_vertex_map_it it = virtual_vertices.find(c->vertex(i));
// if c->vertex(i) is not contained in virtual_vertices, then it
// is in the original domain.
combine_offsets(Offset(),int_to_off(c->offset(i))) );
} else {
combine_offsets(it->second.second, int_to_off(c->offset(i))) );
Periodic_segment periodic_segment(const Cell_handle c, int i, int j) const {
CGAL_triangulation_precondition( i != j );
CGAL_triangulation_precondition( number_of_vertices() != 0 );
CGAL_triangulation_precondition( i >= 0 && i <= 3
&& j >= 0 && j <= 3 );
return make_array( std::make_pair(c->vertex(i)->point(),
get_offset(c,i)),
std::make_pair(c->vertex(j)->point(),
get_offset(c,j)) );
Periodic_segment periodic_segment(const Edge & e) const {
return periodic_segment(e.first,e.second,e.third);
Periodic_triangle periodic_triangle(const Cell_handle c, int i) const;
Periodic_triangle periodic_triangle(const Facet & f) const {
return periodic_triangle(f.first, f.second);
Periodic_tetrahedron periodic_tetrahedron(const Cell_handle c) const {
return make_array(
std::make_pair(c->vertex(0)->point(), get_offset(c,0)),
std::make_pair(c->vertex(1)->point(), get_offset(c,1)),
std::make_pair(c->vertex(2)->point(), get_offset(c,2)),
std::make_pair(c->vertex(3)->point(), get_offset(c,3)) );
Point point(const Periodic_point & pp) const {
Segment segment(const Periodic_segment & ps) const {
return
construct_segment(ps[0].first,ps[1].first,ps[0].second,ps[1].second);
Triangle triangle(const Periodic_triangle & pt) const {
return construct_triangle(pt[0].first, pt[1].first, pt[2].first,
pt[0].second,pt[1].second,pt[2].second);
Tetrahedron tetrahedron(const Periodic_tetrahedron & pt) const {
return construct_tetrahedron(pt[0].first, pt[1].first,
pt[2].first, pt[3].first,
pt[2].second,pt[3].second);
/** @name Queries */ //@{
bool is_vertex(const Point & p, Vertex_handle & v) const;
bool is_vertex(Vertex_handle v) const {
return _tds.is_vertex(v);
bool is_edge(Vertex_handle u, Vertex_handle v,
Cell_handle & c, int & i, int & j) const {
return _tds.is_edge(u, v, c, i, j);
bool is_edge(Vertex_handle u, const Offset & off_u,
Vertex_handle v, const Offset & off_v,
if (!_tds.is_edge(u,v,c,i,j)) return false;
if ((get_offset(c,i) == off_u) && (get_offset(c,j) == off_v))
return true;
// it might be that different cells containing (u,v) yield
// different offsets, which forces us to test for all possibilities.
else {
Cell_circulator ccirc = incident_cells(c,i,j,c);
while (++ccirc != c) {
i = ccirc->index(u);
j = ccirc->index(v);
if ((get_offset(ccirc,i) == off_u) && (get_offset(ccirc,j) == off_v))
c = ccirc;
return true;
return false;
bool is_facet(Vertex_handle u, Vertex_handle v, Vertex_handle w,
Cell_handle & c, int & i, int & j, int & k) const {
return _tds.is_facet(u, v, w, c, i, j, k);
bool is_facet(Vertex_handle u, const Offset & off_u,
Vertex_handle w, const Offset & off_w,
if (!_tds.is_facet(u,v,w,c,i,j,k)) return false;
&& (get_offset(c,k) == off_w) )
return true;
// it might be that c and c->neighbor(l) yield different offsets
// which forces us to test for both possibilities.
else {
int l = 6-i-j-k;
c = c->neighbor(l);
i = c->index(u);
j = c->index(v);
k = c->index(w);
return ((get_offset(c,i) == off_u)
&& (get_offset(c,k) == off_w) );
bool is_cell(Cell_handle c) const {
return _tds.is_cell(c);
bool is_cell(Vertex_handle u, Vertex_handle v,
Vertex_handle w, Vertex_handle t,
Cell_handle & c, int & i, int & j, int & k, int & l) const {
return _tds.is_cell(u, v, w, t, c, i, j, k, l);
bool is_cell(Vertex_handle u, Vertex_handle v, Vertex_handle w,
Vertex_handle t, Cell_handle & c) const {
int i,j,k,l;
bool is_cell(Vertex_handle u, const Offset & off_u,
Vertex_handle t, const Offset & off_t,
if (!_tds.is_cell(u,v,w,t,c,i,j,k,l)) return false;
&& (get_offset(c,l) == off_t) );
return false;
int i, j, k, l;
return is_cell(u,off_u,v,off_v,w,off_w,t,off_t,c,i,j,k,l);
bool has_vertex(const Facet & f, Vertex_handle v, int & j) const {
return _tds.has_vertex(f.first, f.second, v, j);
bool has_vertex(Cell_handle c, int i, Vertex_handle v, int & j) const {
return _tds.has_vertex(c, i, v, j);
bool has_vertex(const Facet & f, Vertex_handle v) const {
return _tds.has_vertex(f.first, f.second, v);
bool has_vertex(Cell_handle c, int i, Vertex_handle v) const {
return _tds.has_vertex(c, i, v);
bool are_equal(Cell_handle c, int i, Cell_handle n, int j) const {
return _tds.are_equal(c, i, n, j);
bool are_equal(const Facet & f, const Facet & g) const {
return _tds.are_equal(f.first, f.second, g.first, g.second);
bool are_equal(const Facet & f, Cell_handle n, int j) const {
return _tds.are_equal(f.first, f.second, n, j);
private:
/** @name Location helpers */ //@{
Cell_handle locate(const Point & p, const Offset &o_p, Locate_type & lt,
int & li, int & lj, Cell_handle start) const;
Bounded_side side_of_cell(const Point & p, const Offset &off,
Cell_handle c, Locate_type & lt, int & i, int & j) const;
public:
/** @name Point Location */ //@{
/** Wrapper function for locate if only the request point is given.
Cell_handle locate(const Point & p, Cell_handle start=Cell_handle()) const {
Locate_type lt;
int li, lj;
return locate( p, lt, li, lj, start);
/** Wrapper function calling locate with an empty offset if there was no
* offset given.
Cell_handle locate(const Point & p, Locate_type & lt, int & li, int & lj,
Cell_handle start = Cell_handle()) const {
return locate(p, Offset(), lt, li, lj, start);
Cell_handle c, Locate_type & lt, int & i, int & j) const {
if (number_of_vertices() == 0) {
lt = EMPTY;
return ON_UNBOUNDED_SIDE;
return side_of_cell(p,Offset(),c,lt,i,j);
private:
/** @name Insertion helpers */ //@{
template <class CellIt>
void insert_too_long_edges(Vertex_handle v,
const CellIt begin, const CellIt end);
void delete_too_long_edges(const CellIt begin, const CellIt end);
template < class Conflict_tester, class Point_hider >
Vertex_handle periodic_insert(const Point& p, const Offset& o, Locate_type
lt,
Cell_handle c, const Conflict_tester &tester,
Point_hider &hider, Vertex_handle vh = Vertex_handle());
template <class Point_iterator, class Offset_iterator>
void periodic_sort(Point_iterator p_begin, Point_iterator p_end,
Offset_iterator o_begin, Offset_iterator o_end) const {
std::cout << "Periodic_sort not yet implemented" << std::endl;
Vertex_handle create_initial_triangulation(const Point &p);
public:
std::vector<Vertex_handle> insert_dummy_points();
protected:
// this is needed for compatibility reasons
template <class Conflict_test, class OutputIteratorBoundaryFacets,
class OutputIteratorCells, class OutputIteratorInternalFacets>
Triple<OutputIteratorBoundaryFacets, OutputIteratorCells,
find_conflicts(Cell_handle c,
const Conflict_test &tester,
OutputIteratorInternalFacets> it) const {
Offset off = get_location_offset(tester.point(), tester.get_offset(),c);
return find_conflicts(c,off,tester,it);
find_conflicts(Cell_handle c, const Offset ¤t_off,
OutputIteratorInternalFacets> it) const;
protected:
// COMMON INSERTION for DELAUNAY and REGULAR TRIANGULATION
Vertex_handle insert_in_conflict(const Point & p, Cell_handle start,
const Conflict_tester &tester, Point_hider &hider) {
Locate_type lt = Locate_type();
int li=0, lj=0;
Cell_handle c = locate(p, Offset(), lt, li, lj, start);
return insert_in_conflict(p,lt,c,li,lj,tester,hider);
Vertex_handle insert_in_conflict(const Point & p, Locate_type lt,
Cell_handle c, int li, int lj, const Conflict_tester &tester,
Point_hider &hider);
template < class InputIterator, class Conflict_tester,
class Point_hider>
std::vector<Vertex_handle> insert_in_conflict(
InputIterator begin, InputIterator end, Cell_handle start,
Vertex_handle new_vertex;
std::vector<Vertex_handle> double_vertices;
int li=0, lj=0;
CGAL_triangulation_assertion_code( Locate_type lta = Locate_type(); )
CGAL_triangulation_assertion_code( int ia = 0; )
CGAL_triangulation_assertion_code( int ja = 0; )
Cell_handle hint;
while (begin!=end) {
tester.set_point(*begin);
hint = locate(*begin, Offset(), lt, li, lj, start);
CGAL_triangulation_assertion_code( if (number_of_vertices() != 0) { );
CGAL_triangulation_assertion(side_of_cell(
*begin,Offset(), hint, lta, ia, ja) != ON_UNBOUNDED_SIDE);
CGAL_triangulation_assertion(lta == lt);
CGAL_triangulation_assertion(ia == li);
CGAL_triangulation_assertion(ja == lj);
CGAL_triangulation_assertion_code( } );
new_vertex = insert_in_conflict(*begin,lt,hint,li,lj,tester,hider);
if (lt == VERTEX) double_vertices.push_back(new_vertex);
start = new_vertex->cell();
begin++;
return double_vertices;
private:
/** @name Removal helpers */ //@{
Vertex_triple make_vertex_triple(const Facet& f) const {
Cell_handle ch = f.first;
int i = f.second;
return Vertex_triple(ch->vertex(vertex_triple_index(i,0)),
ch->vertex(vertex_triple_index(i,1)),
ch->vertex(vertex_triple_index(i,2)));
void make_canonical(Vertex_triple& t) const;
void make_hole(Vertex_handle v, std::map<Vertex_triple,Facet> &outer_map,
std::vector<Cell_handle> &hole);
template < class PointRemover >
void periodic_remove(Vertex_handle v, PointRemover &remover);
protected:
/** @name Removal */ //@{
template < class PointRemover, class CT >
void remove(Vertex_handle v, PointRemover &remover, CT &ct);
public:
/** @name Traversal */ //@{
Cell_iterator cells_begin() const {
return _tds.cells_begin();
Cell_iterator cells_end() const {
return _tds.cells_end();
Vertex_iterator vertices_begin() const {
return _tds.vertices_begin();
Vertex_iterator vertices_end() const {
return _tds.vertices_end();
Edge_iterator edges_begin() const {
return _tds.edges_begin();
Edge_iterator edges_end() const {
return _tds.edges_end();
Facet_iterator facets_begin() const {
return _tds.facets_begin();
Facet_iterator facets_end() const {
return _tds.facets_end();
Cell_iterator finite_cells_begin() const {
Cell_iterator finite_cells_end() const {
Vertex_iterator finite_vertices_begin() const {
Vertex_iterator finite_vertices_end() const {
Edge_iterator finite_edges_begin() const {
Edge_iterator finite_edges_end() const {
Facet_iterator finite_facets_begin() const {
Facet_iterator finite_facets_end() const {
All_cells_iterator all_cells_begin() const {
All_cells_iterator all_cells_end() const {
All_vertices_iterator all_vertices_begin() const {
All_vertices_iterator all_vertices_end() const {
All_edges_iterator all_edges_begin() const {
All_edges_iterator all_edges_end() const {
All_facets_iterator all_facets_begin() const {
All_facets_iterator all_facets_end() const {
// Geometric iterators
Periodic_tetrahedron_iterator periodic_tetrahedra_begin(
Iterator_type it = STORED) const {
return Periodic_tetrahedron_iterator(this, it);
Periodic_tetrahedron_iterator periodic_tetrahedra_end(
return Periodic_tetrahedron_iterator(this, 1, it);
Periodic_triangle_iterator periodic_triangles_begin(
return Periodic_triangle_iterator(this, it);
Periodic_triangle_iterator periodic_triangles_end(
return Periodic_triangle_iterator(this, 1, it);
Periodic_segment_iterator periodic_segments_begin(
return Periodic_segment_iterator(this, it);
Periodic_segment_iterator periodic_segments_end(
return Periodic_segment_iterator(this, 1, it);
Periodic_point_iterator periodic_points_begin(
return Periodic_point_iterator(this, it);
Periodic_point_iterator periodic_points_end(
return Periodic_point_iterator(this, 1, it);
// Circulators
Cell_circulator incident_cells(const Edge & e) const {
return _tds.incident_cells(e);
Cell_circulator incident_cells(Cell_handle c, int i, int j) const {
return _tds.incident_cells(c, i, j);
Cell_circulator incident_cells(const Edge & e, Cell_handle start) const {
return _tds.incident_cells(e, start);
Cell_circulator incident_cells(Cell_handle c, int i, int j,
return _tds.incident_cells(c, i, j, start);
Facet_circulator incident_facets(const Edge & e) const {
return _tds.incident_facets(e);
Facet_circulator incident_facets(Cell_handle c, int i, int j) const {
return _tds.incident_facets(c, i, j);
Facet_circulator incident_facets(const Edge & e, const Facet & start) const
return _tds.incident_facets(e, start);
Facet_circulator incident_facets(Cell_handle c, int i, int j,
const Facet & start) const {
return _tds.incident_facets(c, i, j, start);
Cell_handle start, int f) const {
return _tds.incident_facets(e, start, f);
return _tds.incident_facets(c, i, j, start, f);
// around a vertex
template <class OutputIterator>
OutputIterator incident_cells(Vertex_handle v, OutputIterator cells) const {
return _tds.incident_cells(v, cells);
OutputIterator incident_facets(Vertex_handle v, OutputIterator facets)
const {
return _tds.incident_facets(v, facets);
OutputIterator incident_edges(
Vertex_handle v, OutputIterator edges) const {
return _tds.incident_edges(v, edges);
OutputIterator adjacent_vertices(
Vertex_handle v, OutputIterator vertices) const {
return _tds.adjacent_vertices(v, vertices);
//deprecated, don't use anymore
OutputIterator incident_vertices(
size_type degree(Vertex_handle v) const {
return _tds.degree(v);
// Functions forwarded from TDS.
int mirror_index(Cell_handle c, int i) const {
return _tds.mirror_index(c, i);
Vertex_handle mirror_vertex(Cell_handle c, int i) const {
return _tds.mirror_vertex(c, i);
Facet mirror_facet(Facet f) const {
return _tds.mirror_facet(f);
private:
/** @name Checking helpers */ //@{
/// calls has_self_edges for every cell of the triangulation
bool has_self_edges() const {
Cell_iterator it;
for ( it = all_cells_begin(); it != all_cells_end(); ++it )
if (has_self_edges(it)) return true;
return false;
bool has_self_edges(Cell_handle c) const;
public:
/** @name Checking */ //@{
bool is_valid(bool verbose = false, int level = 0) const;
bool is_valid(Cell_handle c, bool verbose = false, int level = 0) const;
protected:
template <class ConflictTester>
bool is_valid_conflict(ConflictTester &tester, bool verbose = false,
protected:
/** @name Functors */ //@{
template < class Cmp >
class Perturbation_order;
public:
// undocumented access functions
Offset get_offset(Cell_handle ch, int i) const {
if (is_1_cover()) return int_to_off(ch->offset(i));
Virtual_vertex_map_it it = virtual_vertices.find(ch->vertex(i));
if (it != virtual_vertices.end())
return combine_offsets(it->second.second, int_to_off(ch->offset(i)));
else return combine_offsets(Offset(), int_to_off(ch->offset(i)));
Offset get_offset(Vertex_handle vh) const {
if (is_1_cover()) return Offset();
Virtual_vertex_map_it it = virtual_vertices.find(vh);
if (it != virtual_vertices.end()) return it->second.second;
else return Offset();
Vertex_handle get_original_vertex(Vertex_handle vh) const {
if (is_1_cover()) return vh;
if (it != virtual_vertices.end()) return it->second.first;
else return vh;
Offset combine_offsets(const Offset& o_c, const Offset& o_t) const {
Offset o_ct(_cover[0]*o_t.x(),_cover[1]*o_t.y(),_cover[2]*o_t.z());
return o_c + o_ct;
// These functions give the pair (vertex, offset) that corresponds to the
// i-th vertex of cell ch or vertex vh, respectively.
void get_vertex(Cell_handle ch, int i, Vertex_handle &vh, Offset &off)
const;
void get_vertex(Vertex_handle vh_i, Vertex_handle &vh, Offset &off) const;
protected:
// Auxiliary functions
int find_too_long_edges(std::map<Vertex_handle,
std::list<Vertex_handle> >& edges) const;
Cell_handle get_cell(const Vertex_handle* vh) const;
Offset get_location_offset(const Point & p, const Offset &o,
Offset get_neighbor_offset(Cell_handle ch, int i, Cell_handle nb) const;
/** @name Friends */ //@{
friend class Perturbation_order<typename GT::Compare_xyz_3>;
friend std::ostream& operator<< <>
// unused and undocumented function required to be compatible to
// Alpha_shape_3
public:
Point point(Cell_handle c, int idx) const {
// if (is_1_cover())
return point(periodic_point(c,idx));
Offset vec_off[4];
for (int i=0 ; i<4 ; i++) vec_off[i] = periodic_point(c,i).second;
int ox = vec_off[0].x();
int oy = vec_off[0].y();
int oz = vec_off[0].z();
for (int i=1 ; i<4 ; i++) {
ox = std::min(ox,vec_off[i].x());
oy = std::min(oy,vec_off[i].y());
oz = std::min(oz,vec_off[i].z());
Offset diff_off(-ox,-oy,-oz);
if (diff_off.is_null()) return point(periodic_point(c,idx));
for (unsigned int i=0 ; i<4 ; i++) vec_off[i] += diff_off;
Vertex_handle canonic_vh[4];
for (int i=0 ; i<4 ; i++) {
Virtual_vertex_map_it vvmit = virtual_vertices.find(c->vertex(i));
Vertex_handle orig_vh;
if (vvmit == virtual_vertices.end()) orig_vh = c->vertex(i);
else orig_vh = vvmit->second.first;
if (vec_off[i].is_null()) canonic_vh[i] = orig_vh;
else {
CGAL_assertion(virtual_vertices_reverse.find(orig_vh)
canonic_vh[i] = virtual_vertices_reverse.find(orig_vh)
->second[9*vec_off[i][0]+3*vec_off[i][1]+vec_off[i][2]-1];
std::vector<Cell_handle> cells;
incident_cells(canonic_vh[0], std::back_inserter(cells));
for (unsigned int i=0 ; i<cells.size() ; i++) {
CGAL_assertion(cells[i]->has_vertex(canonic_vh[0]));
if (cells[i]->has_vertex(canonic_vh[1])
&& cells[i]->has_vertex(canonic_vh[2])
&& cells[i]->has_vertex(canonic_vh[3]) )
return
point(periodic_point(cells[i],cells[i]->index(canonic_vh[idx])));
CGAL_assertion(false);
inline void
Periodic_3_triangulation_3<GT,TDS>::
copy_multiple_covering(const Periodic_3_triangulation_3<GT,TDS> & tr) {
// Write the respective offsets in the vertices to make them
// automatically copy with the tds.
for (Vertex_iterator vit = tr.vertices_begin() ;
vit != tr.vertices_end() ; ++vit) {
vit->set_offset(tr.get_offset(vit));
// copy the tds
_tds = tr.tds();
// make a list of all vertices that belong to the original
// domain and initialize the basic structure of
// virtual_vertices_reverse
std::list<Vertex_handle> vlist;
for (Vertex_iterator vit = vertices_begin() ;
vit != vertices_end() ; ++vit) {
if (vit->offset() == Offset()) {
vlist.push_back(vit);
virtual_vertices_reverse.insert(
std::make_pair(vit,std::vector<Vertex_handle>(26)));
CGAL_triangulation_assertion(virtual_vertices_reverse.find(vit)
->second.size() == 26);
// Iterate over all vertices that are not in the original domain
// and construct the respective entries to virtual_vertices and
for (Vertex_iterator vit2 = vertices_begin() ;
vit2 != vertices_end() ; ++vit2) {
if (vit2->offset() != Offset()) {
//TODO: use some binding, maybe boost instead of the Finder.
typename std::list<Vertex_handle>::iterator vlist_it
= std::find_if(vlist.begin(), vlist.end(),
Finder(this,vit2->point()));
Offset off = vit2->offset();
virtual_vertices.insert(std::make_pair(vit2,
std::make_pair(*vlist_it,off)));
virtual_vertices_reverse.find(*vlist_it)
->second[9*off[0]+3*off[1]+off[2]-1]=vit2;
CGAL_triangulation_assertion(get_offset(vit2) == off);
// Cleanup vertex offsets
vit->clear_offset();
// Build up the too_long_edges container
too_long_edges[vit] = std::list<Vertex_handle>();
std::pair<Vertex_handle, Vertex_handle> edge_to_add;
Point p1,p2;
int i,j;
for (Edge_iterator eit = edges_begin() ;
eit != edges_end() ; ++eit) {
if (&(eit->first->vertex(eit->second))
< &(eit->first->vertex(eit->third))) {
i = eit->second; j = eit->third;
} else {
i = eit->third; j = eit->second;
edge_to_add = std::make_pair(eit->first->vertex(i),
eit->first->vertex(j));
p1 = construct_point(eit->first->vertex(i)->point(),
get_offset(eit->first, i));
p2 = construct_point(eit->first->vertex(j)->point(),
get_offset(eit->first, j));
Vertex_handle v_no = eit->first->vertex(i);
if (squared_distance(p1,p2) > edge_length_threshold) {
find(too_long_edges[v_no].begin(),
too_long_edges[v_no].end(),
edge_to_add.second) == too_long_edges[v_no].end());
too_long_edges[v_no].push_back(edge_to_add.second);
too_long_edge_counter++;
inline bool
is_extensible_triangulation_in_1_sheet_h1() const {
if (!is_1_cover()) {
if (too_long_edge_counter == 0) return true;
else return false;
} else {
typename Geometric_traits::FT longest_edge_squared_length(0);
Segment s;
for (Periodic_segment_iterator psit = periodic_segments_begin(UNIQUE);
psit != periodic_segments_end(UNIQUE) ; ++psit) {
s = construct_segment(*psit);
longest_edge_squared_length = (std::max)(longest_edge_squared_length,
s.squared_length());
return (longest_edge_squared_length < edge_length_threshold);
inline bool
is_extensible_triangulation_in_1_sheet_h2() const {
typedef typename Geometric_traits::Construct_circumcenter_3
Construct_circumcenter;
typedef typename Geometric_traits::FT FT;
Construct_circumcenter construct_circumcenter
= _gt.construct_circumcenter_3_object();
for (Periodic_tetrahedron_iterator tit = periodic_tetrahedra_begin(UNIQUE) ;
tit != periodic_tetrahedra_end(UNIQUE) ; ++tit) {
Point cc = construct_circumcenter(
tit->at(0).first, tit->at(1).first,
tit->at(2).first, tit->at(3).first,
tit->at(0).second, tit->at(1).second,
tit->at(2).second, tit->at(3).second);
if ( !(FT(16)*squared_distance(cc,point(tit->at(0)))
(_domain.xmax()-_domain.xmin())*(_domain.xmax()-_domain.xmin())) )
return false;
return true;
inline bool
is_triangulation_in_1_sheet() const {
if (is_1_cover()) return true;
for (Vertex_iterator vit = vertices_begin(); vit != vertices_end(); ++vit) {
if (virtual_vertices.find(vit) == virtual_vertices.end()) continue;
std::vector<Vertex_handle> nb_v;
std::set<Vertex_handle> nb_v_odom;
Vertex_handle vh;
Offset off;
adjacent_vertices(vit, std::back_inserter(nb_v));
for (unsigned int i=0; i<nb_v.size(); i++) {
get_vertex(nb_v[i],vh,off);
nb_v_odom.insert(vh);
if (nb_v.size() != nb_v_odom.size())
return false;
return true;
inline bool
Locate_type lt;
int li, lj;
Cell_handle c = locate( p, lt, li, lj );
if ( lt != VERTEX )
return false;
v = c->vertex(li);
return true;
inline void
int i = (&*(t.first) < &*(t.second))? 0 : 1;
if(i==0) {
i = (&*(t.first) < &*(t.third))? 0 : 2;
} else {
i = (&*(t.second) < &*(t.third))? 1 : 2;
Vertex_handle tmp;
switch(i){
case 0: return;
case 1:
tmp = t.first;
t.first = t.second;
t.second = t.third;
t.third = tmp;
return;
default:
tmp = t.first;
t.first = t.third;
t.third = t.second;
t.second = tmp;
inline typename Periodic_3_triangulation_3<GT,TDS>::Periodic_triangle
CGAL_triangulation_precondition( i >= 0 && i <= 3 );
if ( (i&1)==0 )
return make_array(std::make_pair(c->vertex( (i+2)&3 )->point(),
get_offset(c,(i+2)&3)),
std::make_pair(c->vertex( (i+1)&3 )->point(),
get_offset(c,(i+1)&3)),
std::make_pair(c->vertex( (i+3)&3 )->point(),
get_offset(c,(i+3)&3)) );
return make_array(std::make_pair(c->vertex( (i+1)&3 )->point(),
/** Assumes a point, an offset, and a cell to start from.
* Gives the locate type and the simplex (cell and indices) containing p.
* Performs a remembering stochastic walk if the triangulation is not empty.
* After the walk the type of the simplex containing p is determined.
* returns the cell p lies in
* starts at cell "start"
* returns a cell Cell_handel if lt == CELL
* returns a facet (Cell_handle,li) if lt == FACET
* returns an edge (Cell_handle,li,lj) if lt == EDGE
* returns a vertex (Cell_handle,li) if lt == VERTEX
typename Periodic_3_triangulation_3<GT,TDS>::Cell_handle
Periodic_3_triangulation_3<GT,TDS>::locate(const Point & p, const Offset &o_p,
Locate_type & lt, int & li, int & lj, Cell_handle start) const {
int cumm_off = 0;
Offset off_query = o_p;
lt = EMPTY;
return Cell_handle();
CGAL_triangulation_assertion(number_of_vertices() != 0);
if (start == Cell_handle()) {
start = cells_begin();
cumm_off = start->offset(0) | start->offset(1)
| start->offset(2) | start->offset(3);
if (is_1_cover() && cumm_off != 0) {
if (((cumm_off & 4) == 4) &&
(FT(2)*p.x()<(_domain.xmax()-_domain.xmin())))
off_query += Offset(1,0,0);
if (((cumm_off & 2) == 2) &&
(FT(2)*p.y()<(_domain.ymax()-_domain.ymin())))
off_query += Offset(0,1,0);
if (((cumm_off & 1) == 1) &&
(FT(2)*p.z()<(_domain.zmax()-_domain.zmin())))
off_query += Offset(0,0,1);
CGAL_triangulation_postcondition(start!=Cell_handle());
CGAL_triangulation_assertion(start->neighbor(0)->neighbor(
start->neighbor(0)->index(start))==start);
CGAL_triangulation_assertion(start->neighbor(1)->neighbor(
start->neighbor(1)->index(start))==start);
CGAL_triangulation_assertion(start->neighbor(2)->neighbor(
start->neighbor(2)->index(start))==start);
CGAL_triangulation_assertion(start->neighbor(3)->neighbor(
start->neighbor(3)->index(start))==start);
// We implement the remembering visibility/stochastic walk.
// Remembers the previous cell to avoid useless orientation tests.
Cell_handle previous = Cell_handle();
Cell_handle c = start;
// Stores the results of the 4 orientation tests. It will be used
// at the end to decide if p lies on a face/edge/vertex/interior.
Orientation o[4];
boost::rand48 rng;
boost::uniform_smallint<> four(0, 3);
boost::variate_generator<boost::rand48&, boost::uniform_smallint<> >
die4(rng, four);
// Now treat the cell c.
try_next_cell:
// For the remembering stochastic walk,
// we need to start trying with a random index :
int i = die4();
// For the remembering visibility walk (Delaunay only), we don't :
// int i = 0;
cumm_off =
c->offset(0) | c->offset(1) | c->offset(2) | c->offset(3);
bool simplicity_criterion = (cumm_off == 0) && (off_query.is_null());
// We know that the 4 vertices of c are positively oriented.
// So, in order to test if p is seen outside from one of c's facets,
// we just replace the corresponding point by p in the orientation
// test. We do this using the arrays below.
Offset off[4];
const Point* pts[4] = { &(c->vertex(0)->point()),
&(c->vertex(1)->point()),
&(c->vertex(2)->point()),
&(c->vertex(3)->point()) };
if (!simplicity_criterion && is_1_cover() ) {
for (int i=0; i<4; i++) {
off[i] = int_to_off(c->offset(i));
// Just fetch the vertices of c as points with offsets
pts[i] = &(c->vertex(i)->point());
off[i] = get_offset(c,i);
for (int j=0; j != 4; ++j, i = (i+1)&3) {
Cell_handle next = c->neighbor(i);
if (previous == next) {
o[i] = POSITIVE;
continue;
CGAL_triangulation_assertion(next->neighbor(next->index(c)) == c);
// We temporarily put p at i's place in pts.
const Point* backup = pts[i];
pts[i] = &p;
if (simplicity_criterion && is_1_cover() ) {
o[i] = orientation(*pts[0], *pts[1], *pts[2], *pts[3]);
if ( o[i] != NEGATIVE ) {
pts[i] = backup;
continue;
else {
Offset backup_off;
backup_off = off[i];
off[i] = off_query;
o[i] = orientation(*pts[0], *pts[1], *pts[2], *pts[3],
off[0], off[1], off[2], off[3]);
pts[i] = backup;
off[i] = backup_off;
continue;
// Test whether we need to adapt the offset of the query point.
// This means, if we get out of the current cover.
off_query = combine_offsets(off_query, get_neighbor_offset(c,i,next));
previous = c;
c = next;
goto try_next_cell;
// Ok, now we have found the cell. It remains to find the dimension of the
// intersected simplex.
// now p is in c or on its boundary
int sum = ( o[0] == COPLANAR )
+ ( o[1] == COPLANAR )
+ ( o[2] == COPLANAR )
+ ( o[3] == COPLANAR );
switch (sum) {
case 0:
lt = CELL;
break;
case 1:
lt = FACET;
li = ( o[0] == COPLANAR ) ? 0 :
( o[1] == COPLANAR ) ? 1 :
( o[2] == COPLANAR ) ? 2 : 3;
break;
case 2:
lt = EDGE;
li = ( o[0] != COPLANAR ) ? 0 :
( o[1] != COPLANAR ) ? 1 : 2;
lj = ( o[li+1] != COPLANAR ) ? li+1 :
( o[li+2] != COPLANAR ) ? li+2 : li+3;
break;
case 3:
lt = VERTEX;
( o[2] != COPLANAR ) ? 2 : 3;
break;
default:
// Vertex can not lie on four facets
CGAL_triangulation_assertion(false);
return c;
* returns
* ON_BOUNDED_SIDE if p inside the cell
* (for an infinite cell this means that p lies strictly in the half space
* limited by its finite facet)
* ON_BOUNDARY if p on the boundary of the cell
* (for an infinite cell this means that p lies on the *finite* facet)
* ON_UNBOUNDED_SIDE if p lies outside the cell
* (for an infinite cell this means that p is not in the preceding
* two cases)
* lt has a meaning only when ON_BOUNDED_SIDE or ON_BOUNDARY
// TODO: currently off is not used. It could probably be optimized
// using off.
inline Bounded_side Periodic_3_triangulation_3<GT,TDS>::side_of_cell(
const Point & q, const Offset &off, Cell_handle c,
Orientation o0,o1,o2,o3;
o0 = o1 = o2 = o3 = ZERO;
int cumm_off = c->offset(0) | c->offset(1) | c->offset(2) | c->offset(3);
if ((cumm_off == 0) && (is_1_cover())) {
CGAL_triangulation_assertion(off == Offset());
const Point &p0 = c->vertex(0)->point();
const Point &p1 = c->vertex(1)->point();
const Point &p2 = c->vertex(2)->point();
const Point &p3 = c->vertex(3)->point();
if (((o0 = orientation(q ,p1,p2,p3)) == NEGATIVE) ||
((o1 = orientation(p0,q ,p2,p3)) == NEGATIVE) ||
((o2 = orientation(p0,p1,q ,p3)) == NEGATIVE) ||
((o3 = orientation(p0,p1,p2,q )) == NEGATIVE) ) {
} else { // Special case for the periodic space.
Offset off_q;
Offset offs[4];
const Point *p[4];
p[i] = &(c->vertex(i)->point());
offs[i] = get_offset(c,i);
CGAL_triangulation_assertion(orientation(*p[0], *p[1], *p[2], *p[3],
offs[0], offs[1], offs[2], offs[3]) == POSITIVE);
bool found=false;
for (int i=0; (i<8)&&(!found); i++) {
if ((cumm_off | ((~i)&7)) == 7) {
o0 = o1 = o2 = o3 = NEGATIVE;
off_q = combine_offsets(off, int_to_off(i));
if (((o0 = orientation( q, *p[1], *p[2], *p[3],
off_q ,offs[1],offs[2],offs[3])) != NEGATIVE)&&
((o1 = orientation( *p[0], q, *p[2], *p[3],
offs[0], off_q,offs[2],offs[3])) != NEGATIVE)&&
((o2 = orientation( *p[0], *p[1], q, *p[3],
offs[0],offs[1], off_q,offs[3])) != NEGATIVE)&&
((o3 = orientation( *p[0], *p[1], *p[2], q,
offs[0],offs[1],offs[2], off_q)) != NEGATIVE)) {
found = true;
if (!found) return ON_UNBOUNDED_SIDE;
// now all the oi's are >=0
// sum gives the number of facets p lies on
int sum = ( (o0 == ZERO) ? 1 : 0 )
+ ( (o1 == ZERO) ? 1 : 0 )
+ ( (o2 == ZERO) ? 1 : 0 )
+ ( (o3 == ZERO) ? 1 : 0 );
switch (sum) {
case 0:
lt = CELL;
return ON_BOUNDED_SIDE;
case 1:
lt = FACET;
// i = index such that p lies on facet(i)
i = ( o0 == ZERO ) ? 0 :
( o1 == ZERO ) ? 1 :
( o2 == ZERO ) ? 2 :
3;
return ON_BOUNDARY;
case 2:
lt = EDGE;
// i = smallest index such that p does not lie on facet(i)
// i must be < 3 since p lies on 2 facets
i = ( o0 == POSITIVE ) ? 0 :
( o1 == POSITIVE ) ? 1 :
2;
// j = larger index such that p not on facet(j)
// j must be > 0 since p lies on 2 facets
j = ( o3 == POSITIVE ) ? 3 :
( o2 == POSITIVE ) ? 2 :
1;
return ON_BOUNDARY;
case 3:
lt = VERTEX;
// i = index such that p does not lie on facet(i)
3;
return ON_BOUNDARY;
default:
// impossible : cannot be on 4 facets for a real tetrahedron
return ON_BOUNDARY;
} // side_of_cell
template< class GT, class TDS >
template< class CellIt >
inline void Periodic_3_triangulation_3<GT,TDS>::
const CellIt begin, const CellIt end) {
CGAL_triangulation_precondition(number_of_vertices() != 0);
// add newly added edges to too_long_edges, if necessary.
Point p1,p2;
Offset omin;
std::pair< Vertex_handle, Vertex_handle > edge_to_add;
std::pair< Offset, Offset > edge_to_add_off;
std::list<Vertex_handle> empty_list;
too_long_edges[v] = empty_list;
// Iterate over all cells of the new star.
for (CellIt it = begin ; it != end ; ++it) {
// Consider all possible vertex pairs.
for (int k=0; k<4 ; k++) {
for (int j=0; j<4 ; j++) {
if (j==k) continue;
if (&((*it)->vertex(j)) > &((*it)->vertex(k))) continue;
// make the offsets canonical (wrt. to some notion)
// add to too_long_edges, if not yet added and if "too long"
CGAL_triangulation_precondition(&((*it)->vertex(j))<
&((*it)->vertex(k)));
edge_to_add = std::make_pair((*it)->vertex(j), (*it)->vertex(k));
p1 = construct_point((*it)->vertex(j)->point(), get_offset(*it, j));
p2 = construct_point((*it)->vertex(k)->point(), get_offset(*it, k));
Vertex_handle v_no = (*it)->vertex(j);
if ((squared_distance(p1,p2) > edge_length_threshold)
&& (find(too_long_edges[(*it)->vertex(j)].begin(),
too_long_edges[(*it)->vertex(j)].end(),
edge_to_add.second)
== too_long_edges[(*it)->vertex(j)].end())
too_long_edges[(*it)->vertex(j)].push_back(edge_to_add.second);
template < class CellIt >
delete_too_long_edges(const CellIt begin, const CellIt end) {
std::pair< Vertex_handle, Vertex_handle > edge_to_delete, edge_to_delete2;
typename std::list< Vertex_handle >::iterator sit;
// Iterate over all cells that are in the star. That means that those cells
// are going to be deleted. Therefore, all of them have to be deleted from
// too_long_edges, if they are contained in it.
for (int k=0; k<4; k++) {
if (&((*it)->vertex(j)) < &((*it)->vertex(k))) {
edge_to_delete = std::make_pair((*it)->vertex(j),(*it)->vertex(k));
} else {
edge_to_delete = std::make_pair((*it)->vertex(k),(*it)->vertex(j));
Vertex_handle v_no = edge_to_delete.first;
sit = find(too_long_edges[v_no].begin(),
edge_to_delete.second);
if (sit != too_long_edges[v_no].end()) {
too_long_edges[v_no].erase(sit);
too_long_edge_counter--;
/*! \brief Insert point.
* Inserts the point p into the triangulation. It assumes that
* the cell c containing p is already known.
* Implementation:
* - some precondition checking
* - find and mark conflicting cells --> find_conflicts
* Conflicting cells are stored in the vector cells.
* - backup hidden points
* - Delete the edges of the marked cells from too_long_edges
* - Insert the new vertex in the hole obtained by removing the
* conflicting cells (star-approach) --> _tds._insert_in_hole
* - find out about offsets
* - Insert the newly added edges that are "too long"
* to too_long_edges
* - reinsert hidden points
inline typename Periodic_3_triangulation_3<GT,TDS>::Vertex_handle
Periodic_3_triangulation_3<GT,TDS>::periodic_insert(
const Point & p, const Offset& o,
Locate_type lt, Cell_handle c, const Conflict_tester &tester,
Point_hider &hider, Vertex_handle vh)
Vertex_handle v;
CGAL_triangulation_precondition_code(
Locate_type lt_assert; int i_assert; int j_assert;);
CGAL_triangulation_assertion(side_of_cell(tester.point(),o, c,
lt_assert, i_assert, j_assert) != ON_UNBOUNDED_SIDE);
tester.set_offset(o);
// This only holds for Delaunay
CGAL_triangulation_assertion(lt != VERTEX);
// Choose the periodic copy of tester.point() that is inside c.
Offset current_off = get_location_offset(tester.point(), o, c);
combine_offsets(o,current_off),c,lt_assert,i_assert,j_assert)
// If the new point is not in conflict with its cell, it is hidden.
if (!tester.test_initial_cell(c, current_off)) {
hider.hide_point(c,p);
return Vertex_handle();
// Ok, we really insert the point now.
// First, find the conflict region.
cells.reserve(32);
Facet facet;
find_conflicts(c, current_off, tester,
make_triple(Oneset_iterator<Facet>(facet),
std::back_inserter(cells),
Emptyset_iterator()));
// Remember the points that are hidden by the conflicting cells,
// as they will be deleted during the insertion.
hider.set_vertices(cells.begin(), cells.end());
if (!is_1_cover())
delete_too_long_edges(cells.begin(), cells.end());
// Insertion. Attention: facets[0].first MUST be in conflict!
// Compute the star and put it into the data structure.
// Store the new cells from the star in nbs.
v = _tds._insert_in_hole(cells.begin(), cells.end(),
facet.first, facet.second);
v->set_point(p);
//TODO: this could be done within the _insert_in_hole without losing any
//time because each cell is visited in any case.
//- Do timings to argue to modify _insert_in_conflicts if need be
//- Find the modified _insert_in_hole in the branch svn history of TDS
std::vector<Cell_handle> nbs;
incident_cells(v, std::back_inserter(nbs));
// For all neighbors of the newly added vertex v: fetch their offsets from
// the tester and reset them in the triangulation data structure.
for (typename std::vector<Cell_handle>::iterator cit = nbs.begin();
cit != nbs.end(); cit++) {
Offset off[4];
off[i] = (*cit)->vertex(i)->offset();
set_offsets(*cit, off[0], off[1], off[2], off[3]);
for (typename std::vector<Vertex_handle>::iterator voit = v_offsets.begin();
voit != v_offsets.end() ; ++voit) {
(*voit)->clear_offset();
v_offsets.clear();
if (vh != Vertex_handle()) {
virtual_vertices[v] = Virtual_vertex(vh,o);
virtual_vertices_reverse[vh].push_back(v);
if (!is_1_cover())
insert_too_long_edges(v, nbs.begin(), nbs.end());
// Store the hidden points in their new cells.
hider.reinsert_vertices(v);
return v;
/** Inserts the first point to a triangulation.
* With inserting the first point the 3-sheeted covering is constructed.
* So first, the 27 vertices are inserted and are added to virtual_vertices
* Then 6*27 cells are created.
* Then all links are set.
Periodic_3_triangulation_3<GT,TDS>::create_initial_triangulation(
const Point &p) {
/// Virtual vertices, one per periodic domain
Vertex_handle vir_vertices[3][3][3];
/// Virtual cells, 6 per periodic domain
Cell_handle cells[3][3][3][6];
// Initialise vertices:
vir_vertices[0][0][0] = _tds.create_vertex();
vir_vertices[0][0][0]->set_point(p);
virtual_vertices_reverse[vir_vertices[0][0][0]] =
std::vector<Vertex_handle>();
for (int i=0; i<_cover[0]; i++) {
for (int j=0; j<_cover[1]; j++) {
for (int k=0; k<_cover[2]; k++) {
if ((i!=0)||(j!=0)||(k!=0)) {
// Initialise virtual vertices out of the domain for debugging
vir_vertices[i][j][k] =
vir_vertices[i][j][k]->set_point(p); //+Offset(i,j,k));
virtual_vertices[vir_vertices[i][j][k]] =
Virtual_vertex(vir_vertices[0][0][0], Offset(i,j,k));
virtual_vertices_reverse[vir_vertices[0][0][0]].push_back(
vir_vertices[i][j][k]);
CGAL_triangulation_assertion(vir_vertices[i][j][k] !=
Vertex_handle());
CGAL_triangulation_assertion(vir_vertices[0][0][0]->point() == p);
// Create cells:
for (int l=0; l<6; l++) {
// 6 cells per 'cube'
cells[i][j][k][l] = _tds.create_cell();
for (int n=0; n<4; n++)
CGAL_triangulation_assertion(cells[i][j][k][l] != Cell_handle());
// set vertex and neighbor information
// index to the right vertex: [number of cells][vertex][offset]
int vertex_ind[6][4][3] = {
{ {0, 0, 0}, {0, 1, 0}, {0, 0, 1}, {1, 0, 0} },
{ {1, 1, 0}, {0, 1, 1}, {1, 0, 1}, {1, 1, 1} },
{ {1, 0, 0}, {0, 1, 1}, {0, 1, 0}, {0, 0, 1} },
{ {1, 0, 0}, {0, 1, 1}, {0, 0, 1}, {1, 0, 1} },
{ {1, 0, 0}, {0, 1, 1}, {1, 0, 1}, {1, 1, 0} },
{ {1, 0, 0}, {0, 1, 1}, {1, 1, 0}, {0, 1, 0} }
int neighb_ind[6][4][4] = {
{ { 0, 0, 0, 2}, { 0,-1, 0, 5}, { 0, 0,-1, 3}, {-1, 0, 0, 4} },
{ { 0, 0, 1, 5}, { 1, 0, 0, 2}, { 0, 1, 0, 3}, { 0, 0, 0, 4} },
{ {-1, 0, 0, 1}, { 0, 0, 0, 0}, { 0, 0, 0, 3}, { 0, 0, 0, 5} },
{ { 0, 0, 1, 0}, { 0,-1, 0, 1}, { 0, 0, 0, 4}, { 0, 0, 0, 2} },
{ { 0, 0, 0, 1}, { 1, 0, 0, 0}, { 0, 0, 0, 5}, { 0, 0, 0, 3} },
{ { 0, 1, 0, 0}, { 0, 0,-1, 1}, { 0, 0, 0, 2}, { 0, 0, 0, 4} }
int offset =
(i==_cover[0]-1 ? 4 : 0) |
(j==_cover[1]-1 ? 2 : 0) |
(k==_cover[2]-1 ? 1 : 0);
// cell 0:
cells[i][j][k][l]->set_vertices(
vir_vertices
[(i+vertex_ind[l][0][0])%_cover[0]]
[(j+vertex_ind[l][0][1])%_cover[1]]
[(k+vertex_ind[l][0][2])%_cover[2]],
vir_vertices
[(i+vertex_ind[l][1][0])%_cover[0]]
[(j+vertex_ind[l][1][1])%_cover[1]]
[(k+vertex_ind[l][1][2])%_cover[2]],
vir_vertices
[(i+vertex_ind[l][2][0])%_cover[0]]
[(j+vertex_ind[l][2][1])%_cover[1]]
[(k+vertex_ind[l][2][2])%_cover[2]],
vir_vertices
[(i+vertex_ind[l][3][0])%_cover[0]]
[(j+vertex_ind[l][3][1])%_cover[1]]
[(k+vertex_ind[l][3][2])%_cover[2]]);
set_offsets(cells[i][j][k][l],
offset & (vertex_ind[l][0][0]*4 +
vertex_ind[l][0][1]*2 +
vertex_ind[l][0][2]*1),
offset & (vertex_ind[l][1][0]*4 +
vertex_ind[l][1][1]*2 +
vertex_ind[l][1][2]*1),
offset & (vertex_ind[l][2][0]*4 +
vertex_ind[l][2][1]*2 +
vertex_ind[l][2][2]*1),
offset & (vertex_ind[l][3][0]*4 +
vertex_ind[l][3][1]*2 +
vertex_ind[l][3][2]*1));
cells[i][j][k][l]->set_neighbors(
cells [(i+_cover[0]+neighb_ind[l][0][0])%_cover[0]]
[(j+_cover[1]+neighb_ind[l][0][1])%_cover[1]]
[(k+_cover[2]+neighb_ind[l][0][2])%_cover[2]]
[ neighb_ind[l][0][3] ],
cells [(i+_cover[0]+neighb_ind[l][1][0])%_cover[0]]
[(j+_cover[1]+neighb_ind[l][1][1])%_cover[1]]
[(k+_cover[2]+neighb_ind[l][1][2])%_cover[2]]
[ neighb_ind[l][1][3] ],
cells [(i+_cover[0]+neighb_ind[l][2][0])%_cover[0]]
[(j+_cover[1]+neighb_ind[l][2][1])%_cover[1]]
[(k+_cover[2]+neighb_ind[l][2][2])%_cover[2]]
[ neighb_ind[l][2][3] ],
cells [(i+_cover[0]+neighb_ind[l][3][0])%_cover[0]]
[(j+_cover[1]+neighb_ind[l][3][1])%_cover[1]]
[(k+_cover[2]+neighb_ind[l][3][2])%_cover[2]]
[ neighb_ind[l][3][3] ]
// set pointers from the vertices to incident cells.
vir_vertices[i][j][k]->set_cell(cells[i][j][k][0]);
_tds.set_dimension(3);
// create the base for too_long_edges;
CGAL_triangulation_assertion( too_long_edges.empty() );
CGAL_triangulation_assertion(too_long_edge_counter == 0);
int k=0;
vit !=vertices_end() ; ++vit ) {
too_long_edges[vit] = empty_list;
k++;
std::vector<Cell_handle> temp_inc_cells;
temp_inc_cells.clear();
incident_cells(vit, std::back_inserter(temp_inc_cells));
for (unsigned int i=0 ; i<temp_inc_cells.size() ; i++) {
int k = temp_inc_cells[i]->index(vit);
if (j==k) continue;
if (&vit > &(temp_inc_cells[i]->vertex(j))) continue;
if ((find(too_long_edges[vit].begin(),
too_long_edges[vit].end(),
temp_inc_cells[i]->vertex(j)) ==
too_long_edges[vit].end())
too_long_edges[vit].push_back(temp_inc_cells[i]->vertex(j));
return vir_vertices[0][0][0];
#include <CGAL/Periodic_3_triangulation_dummy_36.h>
/** finds all cells that are in conflict with the currently added point
* (stored in tester).
* The result will be a hole of which the following data is returned:
* - boundary facets
* - cells
* - internal facets.
* c is the current cell, which must be in conflict.
* tester is the function object that tests if a cell is in conflict.
template <class GT, class TDS>
CGAL_triangulation_precondition( tester(c, current_off) );
c->tds_data().mark_in_conflict();
*it.second++ = c;
for (int i=0; i< 4; ++i) {
Cell_handle test = c->neighbor(i);
if (test->tds_data().is_in_conflict()) {
if (c < test) {
*it.third++ = Facet(c, i); // Internal facet.
continue; // test was already in conflict.
if (!test->tds_data().is_in_conflict()) {
Offset o_test = current_off + get_neighbor_offset(c, i, test);
if (tester(test,o_test)) {
if (c < test)
it = find_conflicts(test, o_test, tester, it);
continue;
test->tds_data().mark_on_boundary(); // test is on the boundary.
*it.first++ = Facet(c, i);
for (int j = 0 ; j<4 ; j++){
if (j==i) continue;
if (!c->vertex(j)->get_offset_flag()) {
c->vertex(j)->set_offset(int_to_off(c->offset(j))-current_off);
v_offsets.push_back(c->vertex(j));
return it;
/*! \brief Insert point into triangulation.
* Inserts the point p into the triangulation. It expects
* - a cell to start the point location
* - a testing function to determine cells in conflict
* - a testing function to determine if a vertex is hidden.
* Implementation:
* - If the triangulation is empty call a special function
* (create_initial_triangulation) to construct the basic
* triangulation.
* - Run point location to get the cell c containing point p.
* - Call periodic_insert to insert p into the 3-cover.
* - Also insert the eight periodic copies of p.
Periodic_3_triangulation_3<GT,TDS>::insert_in_conflict(const Point & p,
Locate_type lt, Cell_handle c, int li, int lj,
if (!((_domain.xmin() <= p.x()) && (p.x() < _domain.xmax()))
|| !((_domain.ymin() <= p.y()) && (p.y() < _domain.ymax()))
|| !((_domain.zmin() <= p.z()) && (p.z() < _domain.zmax())))
CGAL_triangulation_assertion((_domain.xmin() <= p.x())
&& (p.x() < _domain.xmax()));
CGAL_triangulation_assertion((_domain.ymin() <= p.y())
&& (p.y() < _domain.ymax()));
CGAL_triangulation_assertion((_domain.zmin() <= p.z())
&& (p.z() < _domain.zmax()));
return create_initial_triangulation(p);
if ((lt == VERTEX) &&
(tester.compare_weight(c->vertex(li)->point(),p)==0) ) {
return c->vertex(li);
Vertex_handle vstart;
Virtual_vertex_map_it vvmit = virtual_vertices.find(c->vertex(0));
vstart = c->vertex(0);
else
vstart = vvmit->second.first;
CGAL_triangulation_assertion(virtual_vertices.find(vstart)
==virtual_vertices.end());
CGAL_triangulation_assertion(virtual_vertices_reverse.find(vstart)
CGAL_triangulation_assertion( number_of_vertices() != 0 );
CGAL_triangulation_expensive_assertion(is_valid());
Vertex_handle vh = periodic_insert(p, Offset(), lt, c, tester, hider);
if (is_1_cover()) {
return vh;
for (Cell_iterator it = all_cells_begin() ;
it != all_cells_end() ; it++){
CGAL_triangulation_assertion(it->neighbor(0)->neighbor(
it->neighbor(0)->index(it))==it);
CGAL_triangulation_assertion(it->neighbor(1)->neighbor(
it->neighbor(1)->index(it))==it);
CGAL_triangulation_assertion(it->neighbor(2)->neighbor(
it->neighbor(2)->index(it))==it);
CGAL_triangulation_assertion(it->neighbor(3)->neighbor(
it->neighbor(3)->index(it))==it);
std::vector<Vertex_handle> start_vertices
= virtual_vertices_reverse.find(vstart)->second;
Cell_handle start;
virtual_vertices_reverse[vh] = std::vector<Vertex_handle>();
// insert 26 periodic copies
start = start_vertices[i*9+j*3+k-1]->cell();
c = locate(p, Offset(i,j,k), lt, li, lj, start);
Vertex_handle vh2 = periodic_insert(p, Offset(i,j,k), lt, c,
tester, hider,vh);
// Fall back to 1-cover if the criterion that the longest edge is shorter
// than sqrt(0.166) is fulfilled.
if ( too_long_edge_counter == 0 ) {
CGAL_triangulation_expensive_assertion( is_valid() );
return vh;
/// tests if two vertices of one cell are just periodic copies of each other
inline bool Periodic_3_triangulation_3<GT,TDS>::has_self_edges(Cell_handle c)
const {
CGAL_triangulation_assertion((c->vertex(0) != c->vertex(1)) ||
(c->offset(0) != c->offset(1)));
CGAL_triangulation_assertion((c->vertex(0) != c->vertex(2)) ||
(c->offset(0) != c->offset(2)));
CGAL_triangulation_assertion((c->vertex(0) != c->vertex(3)) ||
(c->offset(0) != c->offset(3)));
CGAL_triangulation_assertion((c->vertex(1) != c->vertex(2)) ||
(c->offset(1) != c->offset(2)));
CGAL_triangulation_assertion((c->vertex(1) != c->vertex(3)) ||
(c->offset(1) != c->offset(3)));
CGAL_triangulation_assertion((c->vertex(2) != c->vertex(3)) ||
(c->offset(2) != c->offset(3)));
return ((c->vertex(0) == c->vertex(1)) ||
(c->vertex(0) == c->vertex(2)) ||
(c->vertex(0) == c->vertex(3)) ||
(c->vertex(1) == c->vertex(2)) ||
(c->vertex(1) == c->vertex(3)) ||
(c->vertex(2) == c->vertex(3)));
/*! \brief Tests if the triangulation is valid.
* A triangulation is valid if
* - A cell is not its own neighbor.
* - A cell has no two equal neighbors
* - A cell has no two equal vertex-offset pairs
* - A cell is positively oriented.
* - The point of a neighbor of cell c that does not belong to c is not inside
* the circumcircle of c.
template < class GT, class TDS >
bool
is_valid(bool verbose, int level) const {
bool error = false;
for (Cell_iterator cit = cells_begin();
cit != cells_end(); ++cit) {
CGAL_triangulation_assertion(cit != cit->neighbor(i));
for (int j=i+1; j<4; j++) {
CGAL_triangulation_assertion(cit->neighbor(i) != cit->neighbor(j));
CGAL_triangulation_assertion(cit->vertex(i) != cit->vertex(j));
// Check positive orientation:
const Point *p[4]; Offset off[4];
p[i] = &cit->vertex(i)->point();
off[i] = get_offset(cit,i);
if (orientation(*p[0], *p[1], *p[2], *p[3],
off[0], off[1], off[2], off[3]) != POSITIVE) {
if (verbose) {
std::cerr<<"Periodic_3_triangulation_3: wrong
orientation:"<<std::endl;
std::cerr<<off[0]<<'\t'<<*p[0]<<'\n'
<<off[1]<<'\t'<<*p[1]<<'\n'
<<off[2]<<'\t'<<*p[2]<<'\n'
<<off[3]<<'\t'<<*p[3]<<std::endl;
error = true;
if (!has_self_edges()) {
if (! _tds.is_valid(verbose, level) ) {
return false;
return !error;
bool Periodic_3_triangulation_3<GT,TDS>::is_valid(Cell_handle ch,
if ( ! _tds.is_valid(ch,verbose,level) )
return false;
bool error = false;
p[i] = &ch->vertex(i)->point();
off[i] = get_offset(ch,i);
error = true;
return !error;
template < class ConflictTester >
is_valid_conflict(ConflictTester &tester, bool verbose, int level) const {
Cell_iterator it;
for ( it = cells_begin(); it != cells_end(); ++it ) {
is_valid(it, verbose, level);
for (int i=0; i<4; i++ ) {
Offset o_nb = get_neighbor_offset(it,i,it->neighbor(i));
Offset o_vt = get_offset(it->neighbor(i),
it->neighbor(i)->index(it));
if (tester(it,
it->neighbor(i)->vertex(it->neighbor(i)->index(it))->point(),
o_vt-o_nb)) {
if (verbose)
std::cerr << "non-empty sphere: "
<<it->vertex(0)->point()<<'\t'
<<it->vertex(1)->point()<<'\t'
<<it->vertex(2)->point()<<'\t'
<<it->vertex(3)->point()<<'\n'
<<it->neighbor(i)->vertex(it->neighbor(i)->index(it))->point()
<<'\t'<<o_vt-o_nb
<< std::endl;
return false;
return true;
inline void Periodic_3_triangulation_3<GT,TDS>::make_hole(Vertex_handle v,
std::map<Vertex_triple,Facet> &outer_map, std::vector<Cell_handle> &hole)
//CGAL_triangulation_precondition( all_vertices_begin()++
// != all_vertices_end() );
incident_cells(v, std::back_inserter(hole));
for (typename std::vector<Cell_handle>::iterator cit = hole.begin();
cit != hole.end(); ++cit) {
int indv = (*cit)->index(v);
Cell_handle opp_cit = (*cit)->neighbor( indv );
Facet f(opp_cit, opp_cit->index(*cit));
Vertex_triple vt = make_vertex_triple(f);
make_canonical(vt);
outer_map[vt] = f;
if ( i != indv )
(*cit)->vertex(i)->set_cell(opp_cit);
/*! \brief Remove a vertex from the triangulation.
* Removes vertex v from the triangulation.
template < class PointRemover, class Conflict_tester>
inline void Periodic_3_triangulation_3<GT,TDS>::remove(Vertex_handle v,
PointRemover &r, Conflict_tester &t) {
CGAL_expensive_precondition(is_vertex(v));
std::vector<Vertex_handle> vhrem;
if (number_of_vertices() == 1) {
clear();
return;
Virtual_vertex_map_it vvmit = virtual_vertices.find(v);
if (vvmit != virtual_vertices.end()) v = vvmit->second.first;
CGAL_triangulation_assertion(virtual_vertices_reverse.find(v)
vhrem = virtual_vertices_reverse.find(v)->second;
virtual_vertices_reverse.erase(v);
CGAL_triangulation_assertion(vhrem.size()==26);
for (int i=0 ; i<26 ; i++) {
periodic_remove(vhrem[i],r);
virtual_vertices.erase(vhrem[i]);
periodic_remove(v,r);
} else {
if (!is_1_cover()) remove(v,r,t);
* It expects a reference to an instance of a PointRemover.
* Implementation:
* - Compute the hole, that is, all cells incident to v. Cells outside of
* this hole are not affected by the deletion of v.
* - Triangulate the hole. This is done computing the triangulation
* in Euclidean space for the points on the border of the hole.
* - Sew this triangulation into the hole.
* - Test for all newly added edges, whether they are shorter than the
* edge_length_threshold. If not, convert to 3-cover.
inline void Periodic_3_triangulation_3<GT,TDS>::periodic_remove(Vertex_handle
v,
PointRemover &remover) {
// Construct the set of vertex triples on the boundary
// with the facet just behind
typedef std::map<Vertex_triple,Facet> Vertex_triple_Facet_map;
typedef PointRemover Point_remover;
typedef typename Point_remover::TDSE TDSE;
typedef typename Point_remover::CellE_handle CellE_handle;
typedef typename Point_remover::VertexE_handle VertexE_handle;
typedef typename Point_remover::FacetE FacetE;
typedef typename Point_remover::VertexE_triple VertexE_triple;
typedef typename Point_remover::Finite_cellsE_iterator
Finite_cellsE_iterator;
typedef typename Point_remover::Vertex_triple_FacetE_map
Vertex_triple_FacetE_map;
typedef typename Point_remover::Vertex_triple_FacetE_map_it
Vertex_triple_FacetE_map_it;
// First compute the hole and its boundary vertices.
std::vector<Cell_handle> hole;
hole.reserve(64);
Vertex_triple_Facet_map outer_map;
Vertex_triple_FacetE_map inner_map;
make_hole(v, outer_map, hole);
CGAL_triangulation_assertion(outer_map.size()==hole.size());
CGAL_triangulation_assertion(remover.hidden_points_begin() ==
remover.hidden_points_end());
delete_too_long_edges(hole.begin(), hole.end());
// Output the hidden points.
hi = hole.begin(), hend = hole.end(); hi != hend; ++hi)
remover.add_hidden_points(*hi);
// Build up the map between Vertices on the boundary and offsets
// collect all vertices on the boundary
std::vector<Vertex_handle> vertices;
vertices.reserve(64);
// The set is needed to ensure that each vertex is inserted only once.
std::set<Vertex_handle> tmp_vertices;
// The map connects vertices to offsets in the hole
std::map<Vertex_handle, Offset> vh_off_map;
for(typename std::vector<Cell_handle>::iterator cit = hole.begin();
// Put all incident vertices in tmp_vertices.
for (int j=0; j<4; ++j){
if ((*cit)->vertex(j) != v){
tmp_vertices.insert((*cit)->vertex(j));
vh_off_map[(*cit)->vertex(j)] = int_to_off((*cit)->offset(j))
- int_to_off((*cit)->offset((*cit)->index(v)));
// Now output the vertices.
std::copy(tmp_vertices.begin(), tmp_vertices.end(),
std::back_inserter(vertices));
// create a Delaunay/Regular triangulation of the points on the boundary
// in Euclidean space and make a map from the vertices in remover.tmp
// towards the vertices in *this
Unique_hash_map<VertexE_handle,Vertex_handle> vmap;
CellE_handle ch;
remover.tmp.clear();
for(unsigned int i=0; i < vertices.size(); i++){
typedef typename Point_remover::Triangulation_R3::Point TRPoint;
CGAL_triangulation_assertion(get_offset(vertices[i])
+ combine_offsets(Offset(), vh_off_map[vertices[i]])
== combine_offsets(get_offset(vertices[i]),vh_off_map[vertices[i]]));
TRPoint trp = std::make_pair(vertices[i]->point(),
combine_offsets( get_offset(vertices[i]), vh_off_map[vertices[i]]) );
VertexE_handle vh = remover.tmp.insert(trp, ch);
vmap[vh] = vertices[i];
CGAL_triangulation_assertion(vmap.is_defined(vh));
CGAL_triangulation_assertion(remover.tmp.number_of_vertices() != 0);
// Construct the set of vertex triples of tmp
// We reorient the vertex triple so that it matches those from outer_map
// Also note that we use the vertices of *this, not of tmp
for(Finite_cellsE_iterator it = remover.tmp.finite_cells_begin();
it != remover.tmp.finite_cells_end();
++it){
VertexE_triple vt_aux;
for(int i=0; i < 4; i++){
FacetE f = std::pair<CellE_handle,int>(it,i);
vt_aux = VertexE_triple(
f.first->vertex(vertex_triple_index(f.second,0)),
f.first->vertex(vertex_triple_index(f.second,1)),
f.first->vertex(vertex_triple_index(f.second,2)));
if (vmap.is_defined(vt_aux.first)
&& vmap.is_defined(vt_aux.second)
&& vmap.is_defined(vt_aux.third) ) {
Vertex_triple vt(vmap[vt_aux.first],vmap[vt_aux.third],
vmap[vt_aux.second]);
make_canonical(vt);
inner_map[vt]= f;
// A structure for storing the new neighboring relations
typedef boost::tuple<Cell_handle, int, Cell_handle> Neighbor_relation;
std::vector<Neighbor_relation> nr_vec;
std::vector<Cell_handle> new_cells;
// Grow inside the hole, by extending the surface
while(! outer_map.empty()){
typename Vertex_triple_Facet_map::iterator oit = outer_map.begin();
typename Vertex_triple_Facet_map::value_type o_vt_f_pair = *oit;
Cell_handle o_ch = o_vt_f_pair.second.first;
unsigned int o_i = o_vt_f_pair.second.second;
typename Vertex_triple_FacetE_map::iterator iit =
inner_map.find(o_vt_f_pair.first);
CGAL_triangulation_assertion(iit != inner_map.end());
typename Vertex_triple_FacetE_map::value_type i_vt_f_pair = *iit;
CellE_handle i_ch = i_vt_f_pair.second.first;
unsigned int i_i = i_vt_f_pair.second.second;
// create a new cell to glue to the outer surface
Cell_handle new_ch = _tds.create_cell();
new_cells.push_back(new_ch);
new_ch->set_vertices(vmap[i_ch->vertex(0)], vmap[i_ch->vertex(1)],
vmap[i_ch->vertex(2)], vmap[i_ch->vertex(3)]);
set_offsets(new_ch, vh_off_map[vmap[i_ch->vertex(0)]],
vh_off_map[vmap[i_ch->vertex(1)]],
vh_off_map[vmap[i_ch->vertex(2)]],
vh_off_map[vmap[i_ch->vertex(3)]]);
// Update the edge length management
for( int i=0 ; i < 4 ; i++ ) {
for (int j=0 ; j < 4 ; j++) {
if (j==i) continue;
if (&(new_ch->vertex(i)) > &(new_ch->vertex(j))) continue;
Point p1 = construct_point(new_ch->vertex(i)->point(),
get_offset(new_ch, i));
Point p2 = construct_point(new_ch->vertex(j)->point(),
get_offset(new_ch, j));
Vertex_handle v_no = new_ch->vertex(i);
// If the cell does not fulfill the edge-length criterion
// revert all changes to the triangulation and transform it
// to a triangulation in the needed covering space.
if (is_1_cover()) {
_tds.delete_cells(new_cells.begin(), new_cells.end());
convert_to_27_sheeted_covering();
return;
else if (find(too_long_edges[v_no].begin(),
new_ch->vertex(j))
== too_long_edges[v_no].end()) {
too_long_edges[v_no].push_back(new_ch->vertex(j));
// The neighboring relation needs to be stored temporarily in
// nr_vec. It cannot be applied directly because then we could not
// easily cancel the removing process if a cell is encountered
// that does not obey the edge-length criterion.
nr_vec.push_back(boost::make_tuple(o_ch,o_i,new_ch));
nr_vec.push_back(boost::make_tuple(new_ch,i_i,o_ch));
// for the other faces check, if they can also be glued
for(unsigned int i = 0; i < 4; i++){
if(i != i_i){
Facet f = std::pair<Cell_handle,int>(new_ch,i);
make_canonical(vt);
std::swap(vt.second,vt.third);
typename Vertex_triple_Facet_map::iterator oit2 = outer_map.find(vt);
if(oit2 == outer_map.end()){
outer_map[vt]= f;
} else {
// glue the faces
typename Vertex_triple_Facet_map::value_type o_vt_f_pair2 = *oit2;
Cell_handle o_ch2 = o_vt_f_pair2.second.first;
int o_i2 = o_vt_f_pair2.second.second;
nr_vec.push_back(boost::make_tuple(o_ch2,o_i2,new_ch));
nr_vec.push_back(boost::make_tuple(new_ch,i,o_ch2));
outer_map.erase(oit2);
outer_map.erase(oit);
// finally set the neighboring relations
for (unsigned int i=0 ; i<nr_vec.size() ; i++) {
nr_vec[i].get<0>()->set_neighbor(nr_vec[i].get<1>(),nr_vec[i].get<2>());
_tds.delete_vertex(v);
_tds.delete_cells(hole.begin(), hole.end());
class Periodic_3_triangulation_3<GT, TDS>::Perturbation_order {
typedef GT Geometric_traits;
typedef typename Geometric_traits::Point_3 Point;
typedef typename Geometric_traits::Compare_xyz_3 Compare_xyz_3;
typedef typename Periodic_3_triangulation_3<GT, TDS>::Periodic_point
Periodic_point;
Cmp _cmp;
public:
Perturbation_order(const Cmp & cmp) : _cmp(cmp) {}
bool operator()(const Periodic_point *p, const Periodic_point *q) const {
return (_cmp(p->first, q->first, p->second, q->second) == SMALLER);
/** \brief Delete each redundant cell and the not anymore needed data
* structures.
* This function consists of four iterations over all cells and one
* iteration over all vertices:
* 1. cell iteration: mark all cells that are to delete
* 2. cell iteration: redirect neighbors of remaining cells
* 3. cell iteration: redirect vertices of remaining cells
* 4. cell iteration: delete all cells marked in the 1. iteration
* Vertex iteration: delete all vertices outside the original domain.
inline void
Periodic_3_triangulation_3<GT,TDS>::convert_to_1_sheeted_covering() {
// ### First cell iteration ##########################################
if (is_1_cover()) return;
bool to_delete, has_simplifiable_offset;
Virtual_vertex_map_it vvmit;
// First iteration over all cells: Mark the cells that are to delete.
// Cells are to delete if they cannot be translated anymore in the
// direction of one of the axes without yielding negative offsets.
for( Cell_iterator it = all_cells_begin() ;
it != all_cells_end() ; ++it ) {
to_delete = false;
// for all directions in 3D Space
for( int j=0 ; j<3 ; j++ ) {
has_simplifiable_offset = true;
// for all vertices of cell it
for( int i=0 ; i<4 ; i++ ) {
vvmit = virtual_vertices.find(it->vertex(i));
// if it->vertex(i) lies inside the original domain:
if (vvmit == virtual_vertices.end()) {
// the cell cannot be moved any more because if we did, then
// it->vertex(i) will get at least one negative offset.
has_simplifiable_offset = false;
// if it->vertex(i) lies outside the original domain:
} else {
// The cell can certainly be deleted if the offset contains a 2
to_delete = to_delete
|| (vvmit->second.second[j] == 2) ;
// The cell can be moved into one direction only if the offset of
// all for vertices is >=1 for this direction. Since we already
// tested for 2 it is sufficient to test here for 1.
has_simplifiable_offset = has_simplifiable_offset
&& (vvmit->second.second[j] == 1) ;
// if the offset can be simplified, i.e. the cell can be moved, then
// it can be deleted.
if (has_simplifiable_offset)
to_delete = true;
// Mark all cells that are to delete. They cannot be deleted yet,
// because neighboring information still needs to be extracted.
if (to_delete) {
it->set_additional_flag(1);
// ### Second cell iteration #########################################
Vertex_handle vert[4], nbv[4];
Offset off[4];
Cell_handle nb, new_neighbor;
std::vector<Triple<Cell_handle, int, Cell_handle> >
new_neighbor_relations;
// Second iteration over all cells: redirect neighbors where necessary
it != all_cells_end() ; ++it) {
// Skip all cells that are to delete.
if (it->get_additional_flag() == 1) continue;
// Redirect neighbors: Only neighbors that are marked by the
// additional_flag have to be substituted by one of their periodic
// copies. The unmarked neighbors stay the same.
for ( int i = 0 ; i < 4 ; i++ ) {
if ( it->neighbor(i)->get_additional_flag() != 1 ) continue;
nb = it->neighbor(i);
for ( int j = 0 ; j < 4 ; j++ ) {
off[j] = Offset();
get_vertex( nb, j, vert[j], off[j]);
int x,y,z;
x = (std::min) ( (std::min) ( off[0][0], off[1][0] ),
(std::min) ( off[2][0], off[3][0] ) );
y = (std::min) ( (std::min) ( off[0][1], off[1][1] ),
(std::min) ( off[2][1], off[3][1] ) );
z = (std::min) ( (std::min) ( off[0][2], off[1][2] ),
(std::min) ( off[2][2], off[3][2] ) );
// The vector from nb to the "original" periodic copy of nb, that is
// the copy that will not be deleted.
Offset difference_offset(x,y,z);
CGAL_triangulation_assertion( !difference_offset.is_null() );
// We now have to find the "original" periodic copy of nb from
// its vertices. Therefore, we first have to find the vertices.
CGAL_triangulation_assertion( (off[j]-difference_offset)[0] >= 0);
CGAL_triangulation_assertion( (off[j]-difference_offset)[1] >= 0);
CGAL_triangulation_assertion( (off[j]-difference_offset)[2] >= 0);
CGAL_triangulation_assertion( (off[j]-difference_offset)[0] < 3);
CGAL_triangulation_assertion( (off[j]-difference_offset)[1] < 3);
CGAL_triangulation_assertion( (off[j]-difference_offset)[2] < 3);
// find the Vertex_handles of the vertices of the "original"
// periodic copy of nb. If the vertex is inside the original
// domain, there is nothing to do
if ( (off[j]-difference_offset).is_null() ) {
nbv[j] = vert[j];
// If the vertex is outside the original domain, we have to search
// in virtual_vertices in the "wrong" direction. That means, we
// cannot use virtual_vertices.find but have to use
// virtual_vertices_reverse.
} else {
Offset nbo = off[j]-difference_offset;
nbv[j] = virtual_vertices_reverse.find(vert[j])
->second[nbo[0]*9+nbo[1]*3+nbo[2]-1];
// Find the new neighbor by its 4 vertices
new_neighbor = get_cell( nbv );
// Store the new neighbor relation. This cannot be applied yet because
// it would disturb the functioning of get_cell( ... )
new_neighbor_relations.push_back(make_triple(it, i, new_neighbor));
// Apply the new neighbor relations now.
for (unsigned int i=0 ; i<new_neighbor_relations.size() ; i++){
new_neighbor_relations[i].first->set_neighbor(
new_neighbor_relations[i].second,
new_neighbor_relations[i].third);
// ### Third cell iteration ##########################################
Vertex_handle vert[4];
Offset off[4];
// Third iteration over all cells: redirect vertices where necessary
// Skip all cells that are marked to delete
// Find the corresponding vertices of it in the original domain
// and set them as new vertices of it.
off[i] = Offset();
get_vertex( it, i, vert[i], off[i]);
it->set_vertex( i, vert[i]);
CGAL_triangulation_assertion(vert[i]->point()[0] < _domain.xmax());
CGAL_triangulation_assertion(vert[i]->point()[1] < _domain.ymax());
CGAL_triangulation_assertion(vert[i]->point()[2] < _domain.zmax());
CGAL_triangulation_assertion(vert[i]->point()[0] >= _domain.xmin());
CGAL_triangulation_assertion(vert[i]->point()[1] >= _domain.ymin());
CGAL_triangulation_assertion(vert[i]->point()[2] >= _domain.zmin());
// redirect also the cell pointer of the vertex.
it->vertex(i)->set_cell(it);
// Set the offsets.
set_offsets(it, off[0], off[1], off[2], off[3] );
CGAL_triangulation_assertion( int_to_off(it->offset(0)) == off[0] );
CGAL_triangulation_assertion( int_to_off(it->offset(1)) == off[1] );
CGAL_triangulation_assertion( int_to_off(it->offset(2)) == off[2] );
CGAL_triangulation_assertion( int_to_off(it->offset(3)) == off[3] );
// ### Fourth cell iteration #########################################
// Delete the marked cells.
std::vector<Cell_handle> cells_to_delete;
for ( Cell_iterator cit = all_cells_begin() ;
cit != all_cells_end() ; ++cit ) {
if ( cit->get_additional_flag() == 1 )
cells_to_delete.push_back( cit );
_tds.delete_cells(cells_to_delete.begin(), cells_to_delete.end());
// ### Vertex iteration ##############################################
// Delete all the vertices in virtual_vertices, that is all vertices
// outside the original domain.
std::vector<Vertex_handle> vertices_to_delete;
for ( Vertex_iterator vit = all_vertices_begin() ;
vit != all_vertices_end() ; ++vit ) {
if ( virtual_vertices.count( vit ) != 0 ) {
CGAL_triangulation_assertion( virtual_vertices.count( vit ) == 1 );
vertices_to_delete.push_back( vit ) ;
_tds.delete_vertices(vertices_to_delete.begin(),
vertices_to_delete.end());
_cover = make_array(1,1,1);
virtual_vertices.clear();
virtual_vertices_reverse.clear();
inline void
Periodic_3_triangulation_3<GT,TDS>::convert_to_27_sheeted_covering() {
if (_cover == make_array(3,3,3)) return;
CGAL_triangulation_precondition(is_1_cover());
// Create 27 copies of each vertex and write virtual_vertices and
std::list<Vertex_handle> original_vertices;
// try to use std::copy instead of the following loop.
for (Vertex_iterator vit = vertices_begin() ; vit != vertices_end() ; ++vit)
original_vertices.push_back(vit);
for (typename std::list<Vertex_handle>::iterator vit
= original_vertices.begin() ; vit != original_vertices.end() ;
++vit) {
Vertex_handle v_cp;
std::vector<Vertex_handle> copies;
for (int i=0; i<3; i++)
for (int j=0; j<3; j++)
for (int k=0; k<3; k++) {
if (i==0 && j==0 && k==0) continue;
v_cp = _tds.create_vertex(*vit);
copies.push_back(v_cp);
virtual_vertices.insert(std::make_pair(v_cp,
std::make_pair(*vit,Offset(i,j,k))));
virtual_vertices_reverse.insert(std::make_pair(*vit,copies));
// Create 27 copies of each cell from the respective copies of the
// vertices and write virtual_cells and virtual_cells_reverse.
typedef std::map<Cell_handle, std::pair<Cell_handle, Offset> >
Virtual_cell_map;
typedef std::map<Cell_handle, std::vector<Cell_handle > >
Virtual_cell_reverse_map;
typedef typename Virtual_cell_map::const_iterator VCMIT;
typedef typename Virtual_cell_reverse_map::const_iterator VCRMIT;
Virtual_cell_map virtual_cells;
Virtual_cell_reverse_map virtual_cells_reverse;
std::list<Cell_handle> original_cells;
for (Cell_iterator cit = cells_begin() ; cit != cells_end() ; ++cit)
original_cells.push_back(cit);
// Store vertex offsets in a separate data structure
std::list< Offset > off_v;
++vit) {
Cell_handle ccc = (*vit)->cell();
int v_index = ccc->index(*vit);
off_v.push_back(int_to_off(ccc->offset(v_index)));
// Store neighboring offsets in a separate data structure
std::list< array<Offset,4> > off_nb;
for (typename std::list<Cell_handle>::iterator cit = original_cells.begin()
cit != original_cells.end() ; ++cit) {
array<Offset,4> off_nb_c;
for (int i=0; i<4; i++){
Cell_handle ccc = *cit;
Cell_handle nnn = ccc->neighbor(i);
off_nb_c[i] = get_neighbor_offset(ccc,i,nnn);
off_nb.push_back(off_nb_c);
// Create copies of cells
Cell_handle c_cp;
Vertex_handle v0,v1,v2,v3;
std::vector<Cell_handle> copies;
Virtual_vertex_reverse_map_it vvrmit[4];
Offset vvoff[4];
vvrmit[i] = virtual_vertices_reverse.find((*cit)->vertex(i));
vvrmit[i] != virtual_vertices_reverse.end());
vvoff[i] = int_to_off((*cit)->offset(i));
Vertex_handle vvh[4];
for (int n=0; n<26; n++) {
// Decomposition of n into an offset (nx,ny,nz):
// nx = (n+1)/9, ny = ((n+1)/3)%3, nz = (n+1)%3
int o_i = ((n+1)/9+vvoff[i].x()+3)%3;
int o_j = ((n+1)/3+vvoff[i].y()+3)%3;
int o_k = ((n+1)+vvoff[i].z()+3)%3;
int n_c = 9*o_i+3*o_j+o_k-1;
CGAL_triangulation_assertion(n_c >= -1);
if (n_c == -1) vvh[i] = (*cit)->vertex(i);
else vvh[i] = vvrmit[i]->second[n_c];
c_cp = _tds.create_cell(vvh[0], vvh[1], vvh[2], vvh[3]);
copies.push_back(c_cp);
virtual_cells_reverse.insert(std::make_pair(*cit,copies));
// Set new vertices of boundary cells of the original domain.
CGAL_triangulation_assertion(vvrmit != virtual_vertices_reverse.end());
Offset vvoff = int_to_off((*cit)->offset(i));
if (!vvoff.is_null()) {
int n_c = 9*vvoff.x()+3*vvoff.y()+vvoff.z()-1;
CGAL_triangulation_assertion(n_c >= 0);
CGAL_triangulation_assertion(static_cast<unsigned int>(n_c)
< vvrmit->second.size());
(*cit)->set_vertex(i,vvrmit->second[n_c]);
// Set neighboring relations of cell copies
typename std::list< array<Offset,4> >::iterator oit = off_nb.begin() ;
for (typename std::list<Cell_handle>::iterator cit = original_cells.begin();
cit != original_cells.end() ; ++cit, ++oit) {
CGAL_triangulation_assertion( oit != off_nb.end() );
VCRMIT c_cp = virtual_cells_reverse.find(*cit);
CGAL_triangulation_assertion(c_cp != virtual_cells_reverse.end());
Cell_handle cit_nb = (*cit)->neighbor(i);
VCRMIT c_cp_nb = virtual_cells_reverse.find(cit_nb);
CGAL_triangulation_assertion(c_cp_nb != virtual_cells_reverse.end());
Offset nboff = (*oit)[i];
int n_nb;
if (nboff.is_null()) n_nb = n;
else {
int o_i = ((n+1)/9-nboff.x()+3)%3;
int o_j = ((n+1)/3-nboff.y()+3)%3;
int o_k = (n+1-nboff.z()+3)%3;
n_nb = 9*o_i+3*o_j+o_k-1;
if (n_nb == -1) {
CGAL_triangulation_assertion(cit_nb->has_vertex(
c_cp->second[n]->vertex((i+1)%4)) );
c_cp->second[n]->vertex((i+2)%4)) );
c_cp->second[n]->vertex((i+3)%4)) );
c_cp->second[n]->set_neighbor(i,cit_nb);
else {
CGAL_triangulation_assertion(n_nb >= 0);
CGAL_triangulation_assertion(static_cast<unsigned int>(n_nb)
<= c_cp_nb->second.size());
CGAL_triangulation_assertion(c_cp_nb->second[n_nb]
->has_vertex(c_cp->second[n]->vertex((i+1)%4)) );
->has_vertex(c_cp->second[n]->vertex((i+2)%4)) );
->has_vertex(c_cp->second[n]->vertex((i+3)%4)) );
c_cp->second[n]->set_neighbor(i,c_cp_nb->second[n_nb]);
// Set neighboring relations of original cells
oit = off_nb.begin();
if (!nboff.is_null()) {
int o_i = (3-nboff.x())%3;
int o_j = (3-nboff.y())%3;
int o_k = (3-nboff.z())%3;
int n_nb = 9*o_i+3*o_j+o_k-1;
->has_vertex((*cit)->vertex((i+1)%4)) );
->has_vertex((*cit)->vertex((i+2)%4)) );
->has_vertex((*cit)->vertex((i+3)%4)) );
(*cit)->set_neighbor(i,c_cp_nb->second[n_nb]);
// Set incident cells
for (Cell_iterator cit = cells_begin() ; cit != cells_end() ; ++cit) {
cit->vertex(i)->set_cell(cit);
// Set offsets where necessary
CGAL_triangulation_assertion( c_cp != virtual_cells_reverse.end());
Offset off[4];
if (off[0].is_null() && off[1].is_null()
&& off[2].is_null() && off[3].is_null()) continue;
Offset off_cp[4];
int o_i = (n+1)/9;
int o_j = ((n+1)/3)%3;
int o_k = (n+1)%3;
if (o_i!=2 && o_j!=2 && o_k !=2) continue;
off_cp[i] = Offset((o_i==2)?off[i].x():0,
(o_j==2)?off[i].y():0,
(o_k==2)?off[i].z():0);
CGAL_triangulation_assertion(off_cp[i].x() == 0 || off_cp[i].x() ==
1);
CGAL_triangulation_assertion(off_cp[i].y() == 0 || off_cp[i].y() ==
1);
CGAL_triangulation_assertion(off_cp[i].z() == 0 || off_cp[i].z() ==
1);
set_offsets(c_cp->second[n],off_cp[0],off_cp[1],off_cp[2],off_cp[3]);
// Iterate over all original cells and reset offsets.
//This statement does not seem to have any effect
set_offsets(*cit, 0,0,0,0);
CGAL_triangulation_assertion((*cit)->offset(0) == 0);
CGAL_triangulation_assertion((*cit)->offset(1) == 0);
CGAL_triangulation_assertion((*cit)->offset(2) == 0);
CGAL_triangulation_assertion((*cit)->offset(3) == 0);
_cover = make_array(3,3,3);
// Set up too long edges data structure
int i=0;
++i;
too_long_edge_counter = find_too_long_edges(too_long_edges);
// iterate over all edges and store the ones that are longer than
// edge_length_threshold in edges. Return the number of too long edges.
inline int
Periodic_3_triangulation_3<GT,TDS>::find_too_long_edges(
std::map<Vertex_handle, std::list<Vertex_handle> >& edges)
const {
Point p1, p2;
int counter = 0;
Vertex_handle v_no,vh;
for (Edge_iterator eit = edges_begin();
eit != edges_end() ; eit++) {
p1 = construct_point(eit->first->vertex(eit->second)->point(),
get_offset(eit->first, eit->second));
p2 = construct_point(eit->first->vertex(eit->third)->point(),
get_offset(eit->first, eit->third));
if (&(eit->first->vertex(eit->second)) <
v_no = eit->first->vertex(eit->second);
vh = eit->first->vertex(eit->third);
} else {
v_no = eit->first->vertex(eit->third);
vh = eit->first->vertex(eit->second);
edges[v_no].push_back(vh);
counter++;
return counter;
class Periodic_3_triangulation_3<GT,TDS>::Finder {
const Self* _t;
const Point & _p;
public:
Finder(const Self* t, const Point &p) : _t(t), _p(p) {}
bool operator()(const Vertex_handle v) {
return _t->equal(v->point(), _p);
/** Find the cell that consists of the four given vertices
* Iterates over all cells and compare the four vertices of each cell
* with the four vertices in vh.
inline typename Periodic_3_triangulation_3<GT,TDS>::Cell_handle
Periodic_3_triangulation_3<GT,TDS>::get_cell(const Vertex_handle* vh) const {
bool contains_v[4];
incident_cells(vh[3],std::back_inserter(cells));
for ( typename std::vector<Cell_handle>::iterator it = cells.begin();
it != cells.end(); it++ ) {
(*it)->vertex(0) == vh[3] || (*it)->vertex(1) == vh[3]
||(*it)->vertex(2) == vh[3] || (*it)->vertex(3) == vh[3]) ;
for ( int j=0 ; j<3 ; j++ ) {
contains_v[j] = false;
contains_v[j] = ( (*it)->vertex(0) == vh[j] )
|| ( (*it)->vertex(1) == vh[j] )
|| ( (*it)->vertex(2) == vh[j] )
|| ( (*it)->vertex(3) == vh[j] );
if (contains_v[0] && contains_v[1] && contains_v[2]) {
return (*it);
/*! \brief Get the offset of q such that q is inside c w.r.t o.
* If there is no such offset then return -1.
* Implementation: Just try all eight possibilities.
inline typename Periodic_3_triangulation_3<GT,TDS>::Offset
Periodic_3_triangulation_3<GT,TDS>::get_location_offset(
const Point & q, const Offset &o, Cell_handle c) const {
CGAL_triangulation_precondition( number_of_vertices() != 0 );
// CGAL_triangulation_precondition_code(Locate_type lt; int i; int j;);
// CGAL_triangulation_precondition(side_of_cell(q,o,c,lt,i,j)
// != ON_UNBOUNDED_SIDE);
if (cumm_off == 0) {
// default case:
return Offset();
} else {
// Fetch vertices and respective offsets of c from virtual_vertices
const Point *p[4];
Offset off[4];
// Main idea seems to just test all possibilities.
for (int i=0; i<8; i++) {
if (((cumm_off | (~i))&7) == 7) {
if ((orientation(q ,*p[1],*p[2],*p[3],
combine_offsets(o,int_to_off(i)), off[1], off[2], off[3])
!= NEGATIVE) &&
(orientation(*p[0],q ,*p[2],*p[3],
off[0], combine_offsets(o,int_to_off(i)) ,off[2], off[3])
!= NEGATIVE) &&
(orientation(*p[0],*p[1],q ,*p[3],
off[0], off[1], combine_offsets(o,int_to_off(i)), off[3])
!= NEGATIVE) &&
(orientation(*p[0],*p[1],*p[2],q ,
off[0], off[1], off[2], combine_offsets(o,int_to_off(i)))
!= NEGATIVE) ) {
return int_to_off(i);
return Offset();
/** Get the offset between the origins of the internal offset coordinate
* systems of two neighboring cells with respect from ch to nb.
* - Find two corresponding vertices from each cell
* - Return the difference of their offsets.
Periodic_3_triangulation_3<GT,TDS>::get_neighbor_offset(
Cell_handle ch, int i, Cell_handle nb) const {
// Redundance in the signature!
CGAL_triangulation_precondition(ch->neighbor(i) == nb);
CGAL_triangulation_precondition(nb->neighbor(nb->index(ch)) == ch);
Vertex_handle vertex_ch;
int index_ch, index_nb;
// ensure that vertex_ch \in nb and vertex_nb \in ch
index_ch = (i==0? 1 : 0);
vertex_ch = ch->vertex(index_ch);
index_nb = nb->index(vertex_ch);
return int_to_off(nb->offset(index_nb)) - int_to_off(ch->offset(index_ch));
* - ch->offset(i) is an bit triple encapsulated in an integer. Each bit
* represents the offset in one direction --> 2-cover!
* - it_to_off(int) decodes this again.
* - Finally the offset vector is multiplied by cover.
* So if we are working in 3-cover we translate it to the neighboring
* 3-cover and not only to the neighboring domain.
inline void Periodic_3_triangulation_3<GT, TDS>::get_vertex(
Cell_handle ch, int i, Vertex_handle &vh, Offset &off) const {
off = combine_offsets(Offset(),int_to_off(ch->offset(i)));
vh = ch->vertex(i);
Vertex_handle vh_i = vh;
get_vertex(vh_i, vh, off);
return;
Vertex_handle vh_i, Vertex_handle &vh, Offset &off) const {
Virtual_vertex_map_it it = virtual_vertices.find(vh_i);
if (it == virtual_vertices.end()) {
// if ch->vertex(i) is not contained in virtual_vertices, then it is in
// the original domain.
vh = vh_i;
CGAL_triangulation_assertion(vh != Vertex_handle());
} else {
// otherwise it has to be looked up as well as its offset.
vh = it->second.first;
off += it->second.second;
CGAL_triangulation_assertion(vh->point().x() < _domain.xmax());
CGAL_triangulation_assertion(vh->point().y() < _domain.ymax());
CGAL_triangulation_assertion(vh->point().z() < _domain.zmax());
CGAL_triangulation_assertion(vh->point().x() >= _domain.xmin());
CGAL_triangulation_assertion(vh->point().y() >= _domain.ymin());
CGAL_triangulation_assertion(vh->point().z() >= _domain.zmin());
std::istream &
operator>> (std::istream& is, Periodic_3_triangulation_3<GT,TDS> &tr)
// reads
// the current covering that guarantees the triangulation to be a
// simplicial complex
// the number of vertices
// the non combinatorial information on vertices (points in case of
1-sheeted
// covering, point-offset pairs otherwise)
// ALL PERIODIC COPIES OF ONE VERTEX MUST BE STORED CONSECUTIVELY
// the number of cells
// the cells by the indices of their vertices in the preceding list
// of vertices, plus the non combinatorial information on each cell
// the neighbors of each cell by their index in the preceding list of cells
CGAL_triangulation_precondition(is.good());
typedef Periodic_3_triangulation_3<GT,TDS> Triangulation;
typedef typename GT::FT FT;
typedef typename Triangulation::Vertex_handle Vertex_handle;
typedef typename Triangulation::Cell_handle Cell_handle;
typedef typename Triangulation::Offset Offset;
typedef typename Triangulation::Iso_cuboid Iso_cuboid;
tr.clear();
Iso_cuboid domain(0,0,0,1,1,1);
int cx=0, cy=0, cz=0;
unsigned int n=0;
if (is_ascii(is)) {
is >> domain;
is >> cx >> cy >> cz;
is >> n;
else {
is >> domain;
read(is,cx);
read(is,cy);
read(is,cz);
read(is,n);
CGAL_triangulation_assertion((n/(cx*cy*cz))*cx*cy*cz == n);
tr.tds().set_dimension((n==0?-2:3));
tr._domain = domain;
tr._gt.set_domain(domain);
tr._cover = make_array(cx,cy,cz);
if ( n==0 ) return is;
std::map< int, Vertex_handle > V;
if (cx==1 && cy==1 && cz==1) {
for (unsigned int i=0; i < n; i++) {
V[i] = tr.tds().create_vertex();
is >> *V[i];
} else {
Vertex_handle v,w;
std::vector<Vertex_handle> vv;
Offset off;
v = tr.tds().create_vertex();
V[i] = v;
is >> *V[i] >> off;
vv.clear();
for (int j=1; j<cx*cy*cz; j++) {
i++;
w = tr.tds().create_vertex();
V[i] = w;
is >> *V[i] >> off;
vv.push_back(w);
tr.virtual_vertices[w]=std::make_pair(v,off);
tr.virtual_vertices_reverse[v]=vv;
std::map< int, Cell_handle > C;
int m;
tr._tds.read_cells(is, V, m, C);
// read offsets
int off[4] = {0,0,0,0};
for (int j=0 ; j < m; j++) {
if (is_ascii(is))
is >> off[0] >> off[1] >> off[2] >> off[3];
else {
read(is,off[0]);
read(is,off[1]);
read(is,off[2]);
read(is,off[3]);
tr.set_offsets(C[j],off[0],off[1],off[2],off[3]);
// read potential other information
is >> *(C[j]);
typedef typename Triangulation::Vertex_iterator VI;
int i=0;
for (VI vi = tr.vertices_begin();
vi != tr.vertices_end(); ++vi) {
tr.too_long_edges[vi]=std::list<Vertex_handle>();
++i;
tr.edge_length_threshold = FT(0.166) * (tr._domain.xmax()-tr._domain.xmin())
(tr._domain.xmax()-tr._domain.xmin());
tr.too_long_edge_counter = tr.find_too_long_edges(tr.too_long_edges);
CGAL_triangulation_expensive_assertion( tr.is_valid() );
return is;
std::ostream &
operator<< (std::ostream& os,const Periodic_3_triangulation_3<GT,TDS> &tr)
// writes :
// the domain as six coordinates: xmin ymin zmin xmax ymax zmax
// the non combinatorial information on vertices (points in case of 1-sheeted
typedef typename Triangulation::Vertex_iterator Vertex_iterator;
typedef typename Triangulation::Cell_iterator Cell_iterator;
typedef typename Triangulation::Edge_iterator Edge_iterator;
typedef typename Triangulation::Facet_iterator Facet_iterator;
typedef typename Triangulation::Covering_sheets Covering_sheets;
typedef typename Triangulation::Virtual_vertex_map_it Virtual_vertex_map_it;
// outputs dimension, domain and number of vertices
Iso_cuboid domain = tr.domain();
Covering_sheets cover = tr.number_of_sheets();
unsigned int n = tr.number_of_vertices();
if (is_ascii(os))
os << domain << std::endl
<< cover[0] << " " << cover[1] << " " << cover[2] << std::endl
<< n*cover[0]*cover[1]*cover[2] << std::endl;
else {
os << domain;
write(os,cover[0]);
write(os,cover[1]);
write(os,cover[2]);
write(os,n*cover[0]*cover[1]*cover[2]);
if (n == 0)
return os;
// write the vertices
std::map<Vertex_handle, int > V;
unsigned int i=0;
if (tr.is_1_cover()) {
for (Vertex_iterator it=tr.vertices_begin(); it!=tr.vertices_end(); ++it)
V[it] = i++;
os << it->point();
if (is_ascii(os))
os << std::endl;
} else {
Virtual_vertex_map_it vit, vvit;
vit = tr.virtual_vertices.find(it);
if (vit != tr.virtual_vertices.end()) continue;
V[it]=i++;
if (is_ascii(os))
os << it->point() << std::endl
<< Offset(0,0,0) << std::endl;
else os << it->point() << Offset(0,0,0);
CGAL_triangulation_assertion(tr.virtual_vertices_reverse.find(it)
!= tr.virtual_vertices_reverse.end());
vv = tr.virtual_vertices_reverse.find(it)->second;
CGAL_triangulation_assertion(vv.size() == 26);
for (unsigned int j=0; j<vv.size(); j++) {
vvit = tr.virtual_vertices.find(vv[j]);
CGAL_triangulation_assertion(vvit != tr.virtual_vertices.end());
V[vv[j]] = i++;
if (is_ascii(os))
os << vv[j]->point() << std::endl
<< vvit->second.second << std::endl;
else os << vv[j]->point() << vvit->second.second;
CGAL_triangulation_postcondition(i==tr._cover[0]*tr._cover[1]*tr._cover[2]*n);
// asks the tds for the combinatorial information
tr.tds().print_cells(os, V);
// write offsets
//for (unsigned int i=0 ; i<tr.number_of_cells() ; i++) {
for (Cell_iterator it=tr.cells_begin(); it!=tr.cells_end(); ++it) {
//Cell_handle ch = std::find(tr.cells_begin(), tr.cells_end(), i);
Cell_handle ch(it);
for (int j=0; j<4; j++) {
if(is_ascii(os)) {
os << ch->offset(j);
if ( j==3 )
os << std::endl;
else
os << ' ';
else write(os,ch->offset(j));
// write the non combinatorial information on the cells
// using the << operator of Cell
// works because the iterator of the tds traverses the cells in the
// same order as the iterator of the triangulation
if(tr.number_of_vertices() != 0) {
for(Cell_iterator it=tr.cells_begin(); it != tr.cells_end(); ++it) {
os << *it; // other information
if(is_ascii(os))
os << std::endl;
return os ;
namespace internal {
/// Internal function used by operator==.
//TODO: introduce offsets
template <class GT, class TDS1, class TDS2>
bool
test_next(const Periodic_3_triangulation_3<GT, TDS1> &t1,
const Periodic_3_triangulation_3<GT, TDS2> &t2,
typename Periodic_3_triangulation_3<GT, TDS1>::Cell_handle c1,
typename Periodic_3_triangulation_3<GT, TDS2>::Cell_handle c2,
std::map<typename Periodic_3_triangulation_3<GT, TDS1>::Cell_handle,
typename Periodic_3_triangulation_3<GT, TDS2>::Cell_handle> &Cmap,
std::map<typename Periodic_3_triangulation_3<GT, TDS1>::Vertex_handle,
typename Periodic_3_triangulation_3<GT, TDS2>::Vertex_handle> &Vmap)
// This function tests and registers the 4 neighbors of c1/c2,
// and recursively calls itself over them.
// Returns false if an inequality has been found.
// Precondition: c1, c2 have been registered as well as their 4 vertices.
CGAL_triangulation_precondition(t1.number_of_vertices() != 0);
CGAL_triangulation_precondition(Cmap[c1] == c2);
CGAL_triangulation_precondition(Vmap.find(c1->vertex(0)) != Vmap.end());
CGAL_triangulation_precondition(Vmap.find(c1->vertex(1)) != Vmap.end());
CGAL_triangulation_precondition(Vmap.find(c1->vertex(2)) != Vmap.end());
CGAL_triangulation_precondition(Vmap.find(c1->vertex(3)) != Vmap.end());
typedef Periodic_3_triangulation_3<GT, TDS1> Tr1;
typedef Periodic_3_triangulation_3<GT, TDS2> Tr2;
typedef typename Tr1::Vertex_handle Vertex_handle1;
typedef typename Tr1::Cell_handle Cell_handle1;
typedef typename Tr2::Vertex_handle Vertex_handle2;
typedef typename Tr2::Cell_handle Cell_handle2;
typedef typename std::map<Cell_handle1, Cell_handle2>::const_iterator
Cit;
typedef typename std::map<Vertex_handle1,
Vertex_handle2>::const_iterator Vit;
for (int i=0; i <= 3; ++i) {
Cell_handle1 n1 = c1->neighbor(i);
Cit cit = Cmap.find(n1);
Vertex_handle1 v1 = c1->vertex(i);
Vertex_handle2 v2 = Vmap[v1];
Cell_handle2 n2 = c2->neighbor(c2->index(v2));
if (cit != Cmap.end()) {
// n1 was already registered.
if (cit->second != n2)
return false;
continue;
// n1 has not yet been registered.
// We check that the new vertices match geometrically.
// And we register them.
Vertex_handle1 vn1 = n1->vertex(n1->index(c1));
Vertex_handle2 vn2 = n2->vertex(n2->index(c2));
Vit vit = Vmap.find(vn1);
if (vit != Vmap.end()) {
// vn1 already registered
if (vit->second != vn2)
return false;
else {
if (t1.geom_traits().compare_xyz_3_object()(vn1->point(),
vn2->point()) != 0)
return false;
// We register vn1/vn2.
Vmap.insert(std::make_pair(vn1, vn2));
// We register n1/n2.
Cmap.insert(std::make_pair(n1, n2));
// We recurse on n1/n2.
if (!test_next(t1, t2, n1, n2, Cmap, Vmap))
return false;
return true;
} // namespace internal
template < class GT, class TDS1, class TDS2 >
bool
operator==(const Periodic_3_triangulation_3<GT,TDS1> &t1,
const Periodic_3_triangulation_3<GT,TDS2> &t2)
typedef typename Periodic_3_triangulation_3<GT,TDS1>::Vertex_handle
Vertex_handle1;
typedef typename Periodic_3_triangulation_3<GT,TDS1>::Cell_handle
Cell_handle1;
typedef typename Periodic_3_triangulation_3<GT,TDS2>::Vertex_handle
Vertex_handle2;
Vertex_iterator2;
typedef typename Periodic_3_triangulation_3<GT,TDS2>::Cell_handle
Cell_handle2;
typedef typename Periodic_3_triangulation_3<GT,TDS1>::Point Point;
typedef typename Periodic_3_triangulation_3<GT,TDS1>::Offset Offset;
::Geometric_traits::Compare_xyz_3 Compare_xyz_3;
Compare_xyz_3 cmp1 = t1.geom_traits().compare_xyz_3_object();
Compare_xyz_3 cmp2 = t2.geom_traits().compare_xyz_3_object();
// Some quick checks.
if ( t1.domain() != t2.domain()
|| t1.number_of_sheets() != t2.number_of_sheets())
return false;
if ( t1.number_of_vertices() != t2.number_of_vertices()
|| t1.number_of_cells() != t2.number_of_cells())
return false;
// Special case for empty triangulations
if (t1.number_of_vertices() == 0)
return true;
// We will store the mapping between the 2 triangulations vertices and
// cells in 2 maps.
std::map<Vertex_handle1, Vertex_handle2> Vmap;
std::map<Cell_handle1, Cell_handle2> Cmap;
// find a common point
Vertex_handle1 v1 = static_cast<Vertex_handle1>(t1.vertices_begin());
Vertex_handle2 iv2;
for (Vertex_iterator2 vit2 = t2.vertices_begin() ;
vit2 != t2.vertices_end(); ++vit2) {
if (!t1.equal(vit2->point(), v1->point(),
t2.get_offset(vit2), t1.get_offset(v1)))
continue;
iv2 = static_cast<Vertex_handle2>(vit2);
break;
if (iv2 == Vertex_handle2())
return false;
Vmap.insert(std::make_pair(v1, iv2));
// We pick one cell of t1, and try to match it against the
// cells of t2.
Cell_handle1 c = v1->cell();
Vertex_handle1 v2 = c->vertex((c->index(v1)+1)%4);
Vertex_handle1 v3 = c->vertex((c->index(v1)+2)%4);
Vertex_handle1 v4 = c->vertex((c->index(v1)+3)%4);
Point p2 = v2->point();
Point p3 = v3->point();
Point p4 = v4->point();
Offset o2 = t1.get_offset(v2);
Offset o3 = t1.get_offset(v3);
Offset o4 = t1.get_offset(v4);
std::vector<Cell_handle2> ics;
t2.incident_cells(iv2, std::back_inserter(ics));
for (typename std::vector<Cell_handle2>::const_iterator cit = ics.begin();
cit != ics.end(); ++cit) {
int inf = (*cit)->index(iv2);
if (t1.equal(p2, (*cit)->vertex((inf+1)%4)->point(),
o2, t2.get_offset((*cit)->vertex((inf+1)%4))))
Vmap.insert(std::make_pair(v2, (*cit)->vertex((inf+1)%4)));
else if (t1.equal(p2, (*cit)->vertex((inf+2)%4)->point(),
o2, t2.get_offset((*cit)->vertex((inf+2)%4))))
Vmap.insert(std::make_pair(v2, (*cit)->vertex((inf+2)%4)));
else if (t1.equal(p2, (*cit)->vertex((inf+3)%4)->point(),
o2, t2.get_offset((*cit)->vertex((inf+3)%4))))
Vmap.insert(std::make_pair(v2, (*cit)->vertex((inf+3)%4)));
else
continue; // None matched v2.
if (t1.equal(p3, (*cit)->vertex((inf+1)%4)->point(),
o3, t2.get_offset((*cit)->vertex((inf+1)%4))))
Vmap.insert(std::make_pair(v3, (*cit)->vertex((inf+1)%4)));
else if (t1.equal(p3, (*cit)->vertex((inf+2)%4)->point(),
o3, t2.get_offset((*cit)->vertex((inf+2)%4))))
Vmap.insert(std::make_pair(v3, (*cit)->vertex((inf+2)%4)));
else if (t1.equal(p3, (*cit)->vertex((inf+3)%4)->point(),
o3, t2.get_offset((*cit)->vertex((inf+3)%4))))
Vmap.insert(std::make_pair(v3, (*cit)->vertex((inf+3)%4)));
else
continue; // None matched v3.
if (t1.equal(p4, (*cit)->vertex((inf+1)%4)->point(),
o4, t2.get_offset((*cit)->vertex((inf+1)%4))))
Vmap.insert(std::make_pair(v4,(*cit)->vertex((inf+1)%4)));
else if (t1.equal(p4, (*cit)->vertex((inf+2)%4)->point(),
o4, t2.get_offset((*cit)->vertex((inf+2)%4))))
Vmap.insert(std::make_pair(v4,(*cit)->vertex((inf+2)%4)));
else if (t1.equal(p4, (*cit)->vertex((inf+3)%4)->point(),
o4, t2.get_offset((*cit)->vertex((inf+3)%4))))
Vmap.insert(std::make_pair(v4,(*cit)->vertex((inf+3)%4)));
else
continue; // None matched v4.
// Found it !
Cmap.insert(std::make_pair(c, *cit));
break;
if (Cmap.size() == 0)
return false;
// We now have one cell, we need to propagate recursively.
return internal::test_next(t1, t2,
Cmap.begin()->first, Cmap.begin()->second, Cmap, Vmap);
inline
bool
operator!=(const Periodic_3_triangulation_3<GT,TDS1> &t1,
return ! (t1 == t2);
CGAL_END_NAMESPACE
#endif // CGAL_PERIODIC_3_TRIANGULATION_3_H
// Copyright (c) 1998, 2001, 2003, 2009 INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL:
svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.6-branch/Periodic_3_triangulation_3/include/CGAL/Periodic_3_triangulation_hierarchy_3.h
// $Id: Periodic_3_triangulation_hierarchy_3.h 53876 2010-01-28 15:32:06Z
lrineau $
// Author(s) : Olivier Devillers
// Sylvain Pion
// Manuel Caroli
#ifndef CGAL_PERIODIC_3_TRIANGULATION_HIERARCHY_3_H
#define CGAL_PERIODIC_3_TRIANGULATION_HIERARCHY_3_H
#include <CGAL/basic.h>
#include <CGAL/Triangulation_hierarchy_vertex_base_3.h>
#include <boost/random/linear_congruential.hpp>
#include <boost/random/geometric_distribution.hpp>
#include <boost/random/variate_generator.hpp>
CGAL_BEGIN_NAMESPACE
template < class PTr >
class Periodic_3_triangulation_hierarchy_3
: public PTr
// parameterization of the hierarchy
// maximal number of points is 30^5 = 24 millions !
enum { ratio = 30 };
enum { minsize = 20};
enum { maxlevel = 5};
public:
typedef PTr PTr_Base;
typedef typename PTr_Base::Geom_traits Geom_traits;
typedef typename PTr_Base::Point Point;
typedef typename PTr_Base::Iso_cuboid Iso_cuboid;
typedef typename PTr_Base::size_type size_type;
typedef typename PTr_Base::Vertex_handle Vertex_handle;
typedef typename PTr_Base::Cell_handle Cell_handle;
typedef typename PTr_Base::Vertex_iterator Vertex_iterator;
typedef typename PTr_Base::Vertex Vertex;
typedef typename PTr_Base::Locate_type Locate_type;
typedef typename PTr_Base::Cell_iterator Cell_iterator;
typedef typename PTr_Base::Facet_iterator Facet_iterator;
typedef typename PTr_Base::Edge_iterator Edge_iterator;
#ifndef CGAL_CFG_USING_BASE_MEMBER_BUG_2
using PTr_Base::number_of_vertices;
using PTr_Base::geom_traits;
using PTr_Base::is_virtual;
#endif
private:
// here is the stack of triangulations which form the hierarchy
PTr_Base* hierarchy[maxlevel];
boost::rand48 random;
int level_mult_cover;
public:
Periodic_3_triangulation_hierarchy_3(
const Iso_cuboid& domain = Iso_cuboid(0,0,0,1,1,1),
const Geom_traits& traits = Geom_traits());
const Periodic_3_triangulation_hierarchy_3& tr);
template < typename InputIterator >
Periodic_3_triangulation_hierarchy_3(InputIterator first, InputIterator
last,
: PTr_Base(domain,traits), level_mult_cover(0)
hierarchy[0] = this;
for(int i=1; i<maxlevel; ++i)
hierarchy[i] = new PTr_Base(domain,traits);
insert(first, last);
Periodic_3_triangulation_hierarchy_3 & operator=(
Periodic_3_triangulation_hierarchy_3 tmp(tr);
swap(tmp);
return *this;
~Periodic_3_triangulation_hierarchy_3();
void swap(Periodic_3_triangulation_hierarchy_3 &tr);
void clear();
// CHECKING
bool is_valid(bool verbose = false, int level = 0) const;
// INSERT REMOVE
Vertex_handle insert(const Point &p, Cell_handle start = Cell_handle ());
Vertex_handle insert(const Point &p, Locate_type lt, Cell_handle loc,
int li, int lj);
template < class InputIterator >
int insert(InputIterator first, InputIterator last, bool = false)
int n = number_of_vertices();
std::vector<Point> points (first, last);
std::random_shuffle (points.begin(), points.end());
spatial_sort (points.begin(), points.end(), geom_traits());
// hints[i] is the cell of the previously inserted point in level i.
// Thanks to spatial sort, they are better hints than what the hierarchy
// would give us.
Cell_handle hints[maxlevel];
for (typename std::vector<Point>::const_iterator p = points.begin(),
end = points.end(); p != end; ++p) {
int vertex_level = random_level();
Vertex_handle v = hierarchy[0]->insert (*p, hints[0]);
hints[0] = v->cell();
Vertex_handle prev = v;
for (int level = 1; level <= vertex_level; ++level) {
v = hierarchy[level]->insert (*p, hints[level]);
hints[level] = v->cell();
v->set_down (prev);
if (hierarchy[level]->number_of_sheets()[0] != 1) {
std::vector<Vertex_handle> vtc
= hierarchy[level]->periodic_copies(v);
for (int i=0 ; i<vtc.size() ; i++) vtc[i]->set_down(prev);
prev->set_up (v);
prev = v;
return number_of_vertices() - n;
void remove(Vertex_handle v);
Vertex_handle move_point(Vertex_handle v, const Point & p);
//LOCATE
Cell_handle locate(const Point& p, Locate_type& lt, int& li, int& lj,
Cell_handle start = Cell_handle ()) const;
Cell_handle locate(const Point& p, Cell_handle start = Cell_handle ())
const;
Vertex_handle
nearest_vertex(const Point& p, Cell_handle start = Cell_handle()) const;
private:
struct locs {
Cell_handle pos;
int li, lj;
Locate_type lt;
void locate(const Point& p, Locate_type& lt, int& li, int& lj,
locs pos[maxlevel], Cell_handle start = Cell_handle ()) const;
int random_level();
// added to make the test program of usual triangulations work
// undocumented
public:
template <class PTr >
Periodic_3_triangulation_hierarchy_3<PTr>::
const Iso_cuboid& domain, const Geom_traits& traits)
: PTr_Base(domain, traits), level_mult_cover(0)
for(int i=1;i<maxlevel;++i)
// copy constructor duplicates vertices and cells
template <class PTr>
const Periodic_3_triangulation_hierarchy_3<PTr> &tr)
: PTr_Base(tr), level_mult_cover(tr.level_mult_cover)
hierarchy[i] = new PTr_Base(*tr.hierarchy[i]);
// up and down have been copied in straightforward way
// compute a map at lower level
std::map< Vertex_handle, Vertex_handle > V;
for( Vertex_iterator it=hierarchy[0]->vertices_begin();
it != hierarchy[0]->vertices_end(); ++it) {
if (hierarchy[0]->is_virtual(it)) continue;
if (it->up() != Vertex_handle())
V[ it->up()->down() ] = it;
for(int j=1; j<maxlevel; ++j) {
for( Vertex_iterator it=hierarchy[j]->vertices_begin();
it != hierarchy[j]->vertices_end(); ++it) {
if (hierarchy[j]->is_virtual(it)) {
// down pointer goes in original instead in copied triangulation
it->set_down(V[it->down()]);
// make reverse link
it->down()->set_up( it );
// make map for next level
void
swap(Periodic_3_triangulation_hierarchy_3<PTr> &tr)
PTr_Base::swap(tr);
std::swap(hierarchy[i], tr.hierarchy[i]);
clear();
delete hierarchy[i];
void
clear()
for(int i=0;i<maxlevel;++i)
hierarchy[i]->clear();
bool
bool result = true;
// verify correctness of triangulation at all levels
for(int i=0; i<maxlevel; ++i)
result = result && hierarchy[i]->is_valid(verbose, level);
// verify that lower level has no down pointers
for( Vertex_iterator it = hierarchy[0]->vertices_begin();
if (!hierarchy[0]->is_virtual(it))
result = result && (it->down() == Vertex_handle());
// verify that other levels has down pointer and reciprocal link is fine
for( Vertex_iterator it = hierarchy[j]->vertices_begin();
if (!hierarchy[j]->is_virtual(it))
result = result && &*(it) == &*(it->down()->up());
for(int k=0; k<maxlevel-1; ++k)
for( Vertex_iterator it = hierarchy[k]->vertices_begin();
it != hierarchy[k]->vertices_end(); ++it)
if (!hierarchy[k]->is_virtual(it))
result = result && ( it->up() == Vertex_handle() ||
&*it == &*(it->up())->down() );
return result;
typename Periodic_3_triangulation_hierarchy_3<PTr>::Vertex_handle
insert(const Point &p, Cell_handle start)
Locate_type lt;
int i, j;
// locate using hierarchy
locs positions[maxlevel];
locate(p, lt, i, j, positions, start);
// insert at level 0
Vertex_handle vertex = hierarchy[0]->insert(p,
positions[0].lt,
positions[0].pos,
positions[0].li,
positions[0].lj);
Vertex_handle previous = vertex;
Vertex_handle first = vertex;
int level = 1;
while (level <= vertex_level ){
if (positions[level].pos == Cell_handle())
vertex = hierarchy[level]->insert(p);
else
vertex = hierarchy[level]->insert(p,
positions[level].lt,
positions[level].pos,
positions[level].li,
positions[level].lj);
vertex->set_down(previous);// link with level above
= hierarchy[level]->periodic_copies(vertex);
for (int i=0 ; i<vtc.size() ; i++) vtc[i]->set_down(previous);
previous->set_up(vertex);
previous=vertex;
level++;
return first;
insert(const Point &p, Locate_type lt, Cell_handle loc, int li, int lj)
Vertex_handle vertex = hierarchy[0]->insert(p,lt,loc,li,lj);
if (vertex_level > 0) {
Locate_type lt;
int i, j;
locate(p, lt, i, j, positions, loc);
int level = 1;
else
previous=vertex;
level++;
return first;
void
CGAL_triangulation_precondition(v != Vertex_handle());
for (int l = 0; l < maxlevel; ++l) {
Vertex_handle u = v->up();
hierarchy[l]->remove(v);
if (u == Vertex_handle())
break;
v = u;
Vertex_handle old, ret;
CGAL_triangulation_assertion(hierarchy[l]->is_valid());
Vertex_handle w = hierarchy[l]->move_point(v, p);
if (l == 0) {
ret = w;
else {
old->set_up(w);
w->set_down(old);
if (hierarchy[l]->number_of_sheets()[0] != 1) {
std::vector<Vertex_handle> vtc = hierarchy[l]->periodic_copies(w);
for (int i=0 ; i<vtc.size() ; i++) vtc[i]->set_down(old);
break;
old = w;
v = u;
return ret;
inline
typename Periodic_3_triangulation_hierarchy_3<PTr>::Cell_handle
locate(const Point& p, Locate_type& lt, int& li, int& lj, Cell_handle start)
const
if (start != Cell_handle ()) return PTr_Base::locate (p, lt, li, lj, start);
locate(p, lt, li, lj, positions);
return positions[0].pos;
inline
locate(const Point& p, Cell_handle start) const
if (start != Cell_handle ()) return PTr_Base::locate (p, start);
Locate_type lt;
int li, lj;
return locate(p, lt, li, lj);
void
locs pos[maxlevel], Cell_handle start) const
int level = maxlevel;
// find the highest level with enough vertices
while (hierarchy[--level]->number_of_vertices() < (size_type) minsize) {
if ( ! level)
break; // do not go below 0
for (int i=level+1; i<maxlevel; ++i)
pos[i].pos = Cell_handle();
Cell_handle position = Cell_handle();
while(level > 0) {
// locate at that level from "position"
// result is stored in "position" for the next level
pos[level].pos = position = hierarchy[level]->locate(p,
pos[level].lt,
pos[level].li,
pos[level].lj,
position);
// find the nearest vertex.
Vertex_handle nearest =
hierarchy[level]->nearest_vertex_in_cell(position,p);
// go at the same vertex on level below
nearest = nearest->down();
position = nearest->cell(); // incident cell
--level;
if (start != Cell_handle ()) position = start;
pos[0].pos = hierarchy[0]->locate(p, lt, li, lj, position); // at level 0
pos[0].lt = lt;
pos[0].li = li;
pos[0].lj = lj;
nearest_vertex(const Point& p, Cell_handle start) const
return PTr_Base::nearest_vertex(p, start != Cell_handle() ? start
: locate(p));
int
random_level()
if ( level_mult_cover < maxlevel
&& hierarchy[level_mult_cover]->number_of_sheets() == make_array(1,1,1)
++level_mult_cover;
boost::geometric_distribution<> proba(1.0/ratio);
boost::variate_generator<boost::rand48&, boost::geometric_distribution<> >
die(random, proba);
return std::min(die()-1, level_mult_cover);
CGAL_END_NAMESPACE
#endif // CGAL_PERIODIC_3_TRIANGULATION_HIERARCHY_3_H
- Re: [cgal-discuss] Re: is fast location for periodic Delaunay broken?, Manuel Caroli, 05/03/2010
- <Possible follow-up(s)>
