cgal-discuss - [cgal-discuss] Re: Neighbours list in 3D meshing
  • To:
  • Subject: [cgal-discuss] Re: Neighbours list in 3D meshing
  • Date: Mon, 3 May 2010 08:51:43 -0700 (PDT)
I am still in the process of getting the neighbors list for all cells and
facets of a 3D mesh. Here is the code that I've written (I simply added it
to an example with a liver image):
typedef Tr::Cell_handle Cell_handle;
typedef C3t3::Cell_iterator Cell_iterator;
typedef Tr::Facet Facet;
typedef C3t3::Facet_iterator Facet_iterator;
typedef Tr::Facet_circulator Facet_circulator;
typedef Tr::Edge Edge;
typedef Tr::Vertex_handle Vertex_handle;
// A mesh connectivity file
std::ofstream neigh_file;
neigh_file.open("liver.neigh");
// 1.0 Cell connectivity
// Enumerating cells
std::map<Cell_handle, int> C;
int icell = 1;
for( Cell_iterator cit = c3t3.cells_begin() ;
cit != c3t3.cells_end() ;
++cit )
C[cit] = icell++;
// Writing cell connectivity data
neigh_file << "Cell neighbours" << std::endl
<< c3t3.number_of_cells() << std::endl;
++cit ) {
const Cell_handle& c = cit;
for ( int i=0 ; i<4 ; ++i ) {
const Cell_handle& neighbor = c->neighbor(i);
if ( c3t3.is_in_complex(neighbor) )
neigh_file << C[neighbor] << " ";
else
neigh_file << -1 << " ";
neigh_file << std::endl;
// 2.0 Facet connectivity
// Enumerating facets
std::map<Facet, int> F;
int ifacet = 1;
for( Facet_iterator fit = c3t3.facets_begin() ;
fit != c3t3.facets_end() ;
++fit )
F[*fit] = ifacet++;
// Writing facet connectivity data
neigh_file << "Facet neighbours" << std::endl
<< c3t3.number_of_facets() << std::endl;
std::vector<int> vert;
vert.resize(3);
std::vector<Edge> edge;
edge.resize(3);
for( Facet_iterator fit = c3t3.facets_begin();
fit != c3t3.facets_end();
++fit ) {
const Cell_handle& cell = fit->first;
int indexInCell = fit->second;
vert[0] = (indexInCell+1)%4;
vert[1] = (indexInCell+2)%4;
vert[2] = (indexInCell+3)%4;
edge[0] = Edge(cell, vert[1], vert[2]);
edge[1] = Edge(cell, vert[2], vert[0]);
edge[2] = Edge(cell, vert[0], vert[1]);
for (unsigned int i = 0; i < edge.size(); ++i) {
Facet_circulator fc = c3t3.triangulation().incident_facets(edge[i],
*fit);
Facet_circulator done(fc);
do {
if ( c3t3.is_in_complex(*fc) )
neigh_file << F[*fc] << " ";
} while (++fc != done);
neigh_file << "End" << std::endl;
neigh_file.close();
The cell neighbors list seems to be correct, though I am still wondering
what the neighbor(i) holds for a boundary cell, a NULL pointer?
The facet code doesn't work. The idea essentially is that I take all 3 edges
of each facet, circulate over their incident facets that belong to a c3t3
complex (should be 2) and for each edge I write out the facet number which
is not the current one (this check is omitted in this code just now).
However, when I run this code, I get lots of zeros from this line:
Why does it happen? Can it be because I assign IDs to facets using typedef
C3t3::Facet_iterator, while when I go over the edge facets, I use typedef
Tr::Facet_circulator?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Neighbours-list-in-3D-meshing-tp2075323p2124179.html
