- To:
- Subject: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator
- Date: Fri, 21 May 2010 00:27:10 -0700 (PDT)
Hi Andreas,
I attached three OFF files. The remeshing tool crashes quickly when processing box.off and glass-mug.off, though it gets stuck instead with flash.off.
best,
/Yi Li
-- Yi Li LAAS - CNRS 7 avenue du Colonel Roche 31077 Toulouse, France
On 05/21/2010 09:13 AM, Andreas Fabri [via cgal-discuss] wrote:
Hello fp2008
Can you send us the data set, so that we can investigate.
andreas
On 21/05/2010 09:09, fp2008 wrote:
> There is a remeshing tool in the CGAL 3.6 demo app Polyhedron_3. It is not
> very stable and crashes often. It seems that this is a problem of the
> surface mesh generator.
> remesh with:
> angle=25
> sizing=10.8584
> approx=1.08584
> tag=1
> Build AABB tree...done (0.000999 ms)
> Insert initial point set... done (0.001 ms)
> Remesh...Legende of the following line: (#vertices,#steps,#facets,#bad
> edges,#bad vertices,)
> CGAL error: assertion violation!
> _expression_ :
> File : ../CGAL-3.6/include/CGAL/Surface_mesher/Surface_mesher.h
> Line : 400
> Explanation: Surface_mesher ERROR: A facet is not in conflict with its
> refinement point!
> Debugging informations:
> Facet: (0x7f49340252c0, 2) = (-28.5 70.3082 -22.5545, -28.5 87.8543
> -30.1016, -28.5 78.0193 -5.07986)
> Dual: (-8.49794e+17 20.3612 -162.845, -25.7086 82.8197 -17.6368)
> Refinement point: -0 82.8197 -17.6368
> Refer to the bug-reporting instructions at
> http://www.cgal.org/bug_report.html
> Abort (core dumped)
View message @ http://cgal-discuss.949826.n4.nabble.com/remeshing-crash-a-problem-of-the-surface-mesh-generator-tp2225698p2225702.html
To unsubscribe from remeshing crash: a problem of the surface mesh generator, click here.
View this message in context: Re: remeshing crash: a problem of the surface mesh generator
- [cgal-discuss] remeshing crash: a problem of the surface mesh generator, fp2008, 05/21/2010
- Re: [cgal-discuss] remeshing crash: a problem of the surface mesh generator, Andreas Fabri, 05/21/2010
- [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, fp2008, 05/21/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Laurent Rineau (GeometryFactory), 05/25/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Joe C, 05/25/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Joe C, 05/27/2010
- Re: [cgal-discuss] Re: remeshing crash: a problem of the surface mesh generator, Stephane Tayeb, 05/27/2010
