cgal-discuss - Re: [cgal-discuss] including optimize_mesh_3.h produces compile error
  • To:
  • Subject: Re: [cgal-discuss] including optimize_mesh_3.h produces compile error
  • Date: Thu, 03 Jun 2010 11:16:56 +0200
Ramin H wrote:
Hi Stéphane,
It took a while to track down the problem. Please try the following and see
if you can reproduce the bug:
#include <CGAL/Mesh_3/global_parameters.h>
#include <CGAL/optimize_mesh_3.h>
int main( int argc, char *argv[] )
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Point_3<K> Point_3;
const Point_3 p, q, r, s;
const Point_3& volume_center = CGAL::centroid(p, q, r, s);
return 0;
1. I found out that:
#include <boost/ptr_container/ptr_vector.hpp>
is missing from
CGAL-3.6\include\CGAL\Mesh_3\Sliver_purturber.h
2. Also, the following error appears:
error C2039: 'iterator_category' : is not a member of 'CGAL::Point_3<R_>'
d:\Program Files\Microsoft Visual Studio 9.0\VC\include\xutility 764
Thanks,
-Ramin
Hi Ramin,
Thanks.
This will be fixed in the next bug-fix release (CGAL v3.6.1).
Best regards,
Stéphane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
