- To:
- Subject: Re: [cgal-discuss] including optimize_mesh_3.h produces compile error
- Date: Mon, 7 Jun 2010 10:49:11 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=tBGdZD05jhl/lbGFOAWutPdqQLWBswxMjvB0BClMBgDbSuEl0DGLDg+l2HnznHkDtO hggg6suAzVJVPhtN5PGUt5BpdM1239LQ2NSs11jMNH+xTHJAHQq98cnffAjOBPEciX2j 0RDF7swOhsJJVfhPM6Hec+T8hN0QIPDTBgtLc=
Hi Stephane,
I defined my own centroid functions and I am using them until this issue is resolved.
Thanks,
-Ramin
On Mon, Jun 7, 2010 at 10:28 AM, Stephane Tayeb <> wrote:
Ramin H wrote:Hi Ramin,
Hi Stephane,
Thanks for the patches. I applied both patches (patch -p0 < filename.diff)
in CGAL-3.6/include/CGAL but I am still getting the same error. (I checked
the files and the changes are applied).
It's strange that these patches fixed the problem for you but I still have
the same error. Should I compile CGAL again after applying these patches?
I am going to copy/paste the full error list from compiling the little cpp I
sent you.
Thanks,
-Ramin
You're right, the fix does not work with MSVS compiler (checked locally). I'll try to have a look at this asap.
Regards,
Stéphane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- Re: [cgal-discuss] including optimize_mesh_3.h produces compile error, (continued)
- Re: [cgal-discuss] including optimize_mesh_3.h produces compile error, Stephane Tayeb, 06/02/2010
- Re: [cgal-discuss] including optimize_mesh_3.h produces compile error, Ramin H, 06/03/2010
- Re: [cgal-discuss] including optimize_mesh_3.h produces compile error, Stephane Tayeb, 06/03/2010
- Re: [cgal-discuss] including optimize_mesh_3.h produces compile error, Stephane Tayeb, 06/07/2010
- Re: [cgal-discuss] including optimize_mesh_3.h produces compile error, Ramin H, 06/07/2010
