cgal-discuss - Re: [cgal-discuss] including optimize_mesh_3.h produces compile error
  • To:
  • Subject: Re: [cgal-discuss] including optimize_mesh_3.h produces compile error
  • Date: Mon, 07 Jun 2010 16:28:01 +0200
Ramin H wrote:
Hi Stephane,
Thanks for the patches. I applied both patches (patch -p0 < filename.diff)
in CGAL-3.6/include/CGAL but I am still getting the same error. (I checked
the files and the changes are applied).
It's strange that these patches fixed the problem for you but I still have
the same error. Should I compile CGAL again after applying these patches?
I am going to copy/paste the full error list from compiling the little cpp I
sent you.
Thanks,
-Ramin
Hi Ramin,
You're right, the fix does not work with MSVS compiler (checked locally). I'll try to have a look at this asap.
Regards,
Stéphane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
