- To:
- Subject: Re: [cgal-discuss] template <T> bool object.is(void) member function
- Date: Thu, 10 Jun 2010 16:07:19 +0200
On Thursday 10 June 2010 15:47:58 Costas Tsirogiannis wrote:
> Indeed, this extra "template" before "is" made it work.
> Why is this needed in the present case?
> Normally a templated member function can be called without it.
Normally, this keyword is only required to call template member functions of
types whose identifier is a dependent name (a name whose semantic may depend
on the template parameters). Is your "Object" type equal to K::Object_2 (or
Object_3) with K passed as template parameter?
Laurent Rineau, PhD
- [cgal-discuss] template <T> bool object.is(void) member function, Costas Tsirogiannis, 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Sylvain Pion, 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Andreas Fabri, 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Costas Tsirogiannis, 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Laurent Rineau (GeometryFactory), 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Costas Tsirogiannis, 06/11/2010
