- To:
- Subject: Re: [cgal-discuss] template <T> bool object.is(void) member function
- Date: Thu, 10 Jun 2010 19:10:29 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=xXk3SS8+8QsqLzijH/DueXpEaMmNe6F4ZmHRiQqgX2K2A6dc5bS6Rc9JFkhanVT2R0 4CNuuNXlAv0CB4gfSUGmrKUxE3WohsBAZqRBVR8XIdaDFeN0rIeXPpCv4kpTV/qjIf0g VHEOO7dBEbKsBdWxmULbaELdWG6bhuo6hPrNE=
> Well, this time it probably means that you are compiling with an old version
> of CGAL, Which CGAL version are you using?
3.5.1 . Should I upgrade? :)
On Thu, Jun 10, 2010 at 7:07 PM, Laurent Rineau (GeometryFactory) <> wrote:
On Thursday 10 June 2010 18:23:48 Costas Tsirogiannis wrote:Well, this time it probably means that you are compiling with an old version
> > Is your "Object" type equal to K::Object_2 (or Object_3) with K passed
> > as
> template
> > parameter?
> Yes, something quite similar to that. Thanks for the clarification.
> While this part of this code does not pop any compilation errors, I now
> get at a totally different point an error for a similar call:
> ‘class CGAL::Object’ has no member named ‘is’
> Though there I put again `template' in front of 'is'. Any suggestion as to
> what causes that?
of CGAL, when CGAL::Object had not the template member function 'is'. :-)
Laurent Rineau, PhD
- [cgal-discuss] template <T> bool object.is(void) member function, Costas Tsirogiannis, 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Sylvain Pion, 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Andreas Fabri, 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Costas Tsirogiannis, 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Laurent Rineau (GeometryFactory), 06/10/2010
- Re: [cgal-discuss] template <T> bool object.is(void) member function, Costas Tsirogiannis, 06/11/2010
