cgal-discuss - Re: [cgal-discuss] template <T> bool object.is(void) member function
  • To:
  • Subject: Re: [cgal-discuss] template <T> bool object.is(void) member function
  • Date: Thu, 10 Jun 2010 21:45:43 +0200
Le jeudi 10 juin 2010 19:10:29, Costas Tsirogiannis a écrit :
> > Well, this time it probably means that you are compiling with an old
> version
> > of CGAL, Which CGAL version are you using?
> 3.5.1 . Should I upgrade? :)
Search for the differences:
http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/STL_Extension_ref/Class_Object.html
http://www.cgal.org/Manual/3.6/doc_html/cgal_manual/STL_Extension_ref/Class_Object.html
Apart the release number in the footer (and numbers in links), there is only
one visible difference... Guess what is the difference?
You should upgrade to CGAL-3.6 (whose documentation you refer to), or not use
is<T>(). If you want to stick to CGAL-3.5.1, instead of:
obj.is<T>()
you can use:
CGAL::object_cast<T>(&obj) != NULL
Laurent Rineau, PhD
