cgal-discuss - Re: [cgal-discuss] Partition a polygon
  • To:
  • Subject: Re: [cgal-discuss] Partition a polygon
  • Date: Mon, 21 Jun 2010 18:23:26 +0200
Francesc Vila wrote:
Hi all,
I am using CGAL to make some transformations on a GDSII (stream format) file. Within this file, I can read polygons that aren't always simple. Is there any way to partition a polygon that is not simple? In fact, the polygon is weakly simple (has a coincident edge).
Thanks in advance,
Francesc Vila
I think you will need to use a pre-processing step to extract simple polygons from each weakly simple polygon.
S.
I thought so..... :(
Further reading this list, I found a method to create polygons with holes from Polygon_2. But it is dated 2009 and the code doesn't compile on my system.... Maybe it is my fault, but I think I can benefit from the general idea it implements.
Regards,
Francesc Vila
An alternative that may fit you need is to use a constrained
triangulation to partition your weakly simple polygon,
constraints being polygon edges.
S.
