cgal-discuss - Re: [cgal-discuss] Partition a polygon
  • To:
  • Subject: Re: [cgal-discuss] Partition a polygon
  • Date: Tue, 22 Jun 2010 08:56:54 -0600
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=JXjcg1Llf6GGeNqZfewA4tSvYaKo8TaCTYelxcpVES+GtivY8++l19WpiFllxastWi gY6F/R34Bcpn5GbS3Hb555jub0lcJobRXyILTqgRPWnJFCRNrwCbZ2WHKEm/CnPjMf4k 6HdzjU2ue9zhhILWc1DC+LxbRbddJpSaSnCUs=
On 22 June 2010 07:43, Francesc Vila
wrote:
> El 21/06/2010 18:23, Sebastien Loriot (GeometryFactory) escribió:
>> Francesc Vila wrote:
>>>>> Hi all,
>>>>> I am using CGAL to make some transformations on a GDSII (stream format)
>>>>> file. Within this file, I can read polygons that aren't always simple.
>>>>> Is
>>>>> there any way to partition a polygon that is not simple? In fact, the
>>>>> polygon is weakly simple (has a coincident edge).
>>>>> Thanks in advance,
>>>>> Francesc Vila
>>>> I think you will need to use a pre-processing step to extract simple
>>>> polygons from each weakly simple polygon.
>>>> S.
There is a paper which describes how to to decompose a self overlapping
polygon
into trapezoids O(n^3) time. Sorry I don't have the reference right
now but I could look it up.
You can still compute the "Area" of the polygon by a straightforward
algorithm in linear
time though. If all you have are weakly coincident polygons then many
triangulation algorithms
should still work or work with only simple modifications; e.g. plane
sweep based algorithms or
the sinuosity based algorithm (my favourite).
Regards,
Ralph Boland
>>> I thought so..... :(
>>> Further reading this list, I found a method to create polygons with holes
>>> from Polygon_2. But it is dated 2009 and the code doesn't compile on my
>>> system.... Maybe it is my fault, but I think I can benefit from the
>>> general
>>> idea it implements.
>>> Regards,
>>> Francesc Vila
>> An alternative that may fit you need is to use a constrained
>> triangulation to partition your weakly simple polygon,
>> constraints being polygon edges.
>> S.
> Hi,
> I tried the constrained triangulation, but some of the triangles it
> generated were part of the hole and not the polygon. Finally I preprocessed
> the polygon to make it simple. I have iterated through all vertices, and
> once I find a repeated one, I create a new polygon and save into a list.
> When I have finished I join all polygons in that list to obtain the polygon
> with holes.
> Best regards,
> Francesc
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Quantum Theory cannot save us from the tyranny of a deterministic universe
but it does give God something to do
