- To:
- Subject: [cgal-discuss] 3D multi-domain meshes
- Date: Mon, 21 Jun 2010 09:38:05 -0700 (PDT)
Hello,
I generate a multi-domain 3D tetrahedral mesh from a 3D labeled image and I
would like to use CGAL mesh data structure to maintain and process it.
Ideally I would like to have a MeshComplex_3InTriangulation_3 like class.
From what I have understood from the forum and user manual, not every
triangulation of a domain can be loaded in a c3t3 object, it should be a
delaunay one and mine is not.
Is the solution reimplementing a MeshComplex_3InTriangulation_3 that has a
Triangulation_3 type of triangulation and a MeshDomain_3 to go along with
it?
Or using Triangulation_cell_base_with_info_3 object with the info being the
subdomain index? In that case I would not have the iterators to go over
every subdomain independently.
Is there a straight forward way that I missed?
Thank you for your attention,
Noura FARAJ
PhD student
Telecom ParisTech, CG Group
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-multi-domain-meshes-tp2262914p2262914.html
- [cgal-discuss] 3D multi-domain meshes, Noura, 06/21/2010
- [cgal-discuss] Display selected faces of polyhedra, Youssef ALJ, 06/21/2010
- Re: [cgal-discuss] 3D multi-domain meshes, Mariette Yvinec, 06/22/2010
