- To:
- Subject: Re: [cgal-discuss] Bug in Polyhedron_incremental_builder_3::test_facet
- Date: Thu, 24 Jun 2010 18:41:35 +0200
Hello Jean-Philippe,
Jean-Philippe Pons wrote:
Dear CGAL developers,Do you mean for example:
test_facet may return 'true' when testing a facet which creates a
non-manifold vertex. So that a subsequent call to add_facet will
unexpectedly fail.
This is because test_facet only checks if one of the vertices of the novel
facet already has a full cycle of facets, which is not sufficient. It does
not check if the novel facet closes a cycle, while there is another
component of facets.
the HDS contains only one triangle. Then we insert a new triangle
incident to only one vertex of the first triangle?
I have checked that the problem still exists in the latest version.
Cheers,
Jean-Philippe
- [cgal-discuss] Bug in Polyhedron_incremental_builder_3::test_facet, Jean-Philippe Pons, 06/23/2010
- Re: [cgal-discuss] Bug in Polyhedron_incremental_builder_3::test_facet, Sebastien Loriot (GeometryFactory), 06/24/2010
- [cgal-discuss] Re: Bug in Polyhedron_incremental_builder_3::test_facet, Jean-Philippe Pons, 06/25/2010
- Re: [cgal-discuss] Re: Bug in Polyhedron_incremental_builder_3::test_facet, Sebastien Loriot (GeometryFactory), 06/28/2010
- Re: [cgal-discuss] Re: Bug in Polyhedron_incremental_builder_3::test_facet, Jean-Philippe Pons, 06/29/2010
