cgal-discuss - Re: [cgal-discuss] Re: Bug in Polyhedron_incremental_builder_3::test_facet
  • To:
  • Subject: Re: [cgal-discuss] Re: Bug in Polyhedron_incremental_builder_3::test_facet
  • Date: Mon, 28 Jun 2010 14:49:23 +0200
Thanks for your bug report Jean-Philippe.
Here is a patch and the modified file that should fix the problem you
have encountered. Let me now whether you still have a problem.
This bug will be fixed in the 3.6.1 bug fix release of CGAL.
Best,
S.
Jean-Philippe Pons wrote:
Dear Sebastien,
No. The case you mention may easily happen during the construction of a
manifold mesh, depending on the order of insertion of facets. As
expected, it is accepted by test_facet and do not cause the failure of
add_facet either.
The case I have in mind is a little more complex: it happens when a
novel facet closes a cycle of facets while there already was another
facet incident to the central vertex of the created cycle.
You can reproduce the aforementioned case with the piece of code given
below. The "Error in polyhedron construction" message should never
happen since all facets are tested before being inserted. But it happens
in practice when adding the fourth facet.
Cheers,
Jean-Philippe
CGAL::Polyhedron_incremental_builder_3<HDS> B(hds, true);
int nb_vertices = 6;
int f[] = {0,1,2, 0,2,3, 0,4,5, 0,3,1};
int nb_triangles = sizeof(f) / sizeof(int) / 3;
B.begin_surface(nb_vertices, nb_triangles);
for (int i=0; i<nb_vertices; i++)
B.add_vertex(Point(0,0,0));
for (int i=0; i<nb_triangles; i++)
int *first = f+3*i, *beyond = first+3;
if (B.test_facet(first, beyond))
cout << "Facet can be added" << endl;
B.add_facet(first, beyond);
if (B.error())
cout << "Error in polyhedron construction" << endl;
break;
else
cout << "Facet cannot be added" << endl;
B.end_surface();
Sebastien Loriot (GeometryFactory) [via cgal-discuss] a écrit :
> Hello Jean-Philippe,
> > Dear CGAL developers,
> > test_facet may return 'true' when testing a facet which creates a
> > non-manifold vertex. So that a subsequent call to add_facet will
> > unexpectedly fail.
> > This is because test_facet only checks if one of the vertices of the
> novel
> > facet already has a full cycle of facets, which is not sufficient. It
> does
> > not check if the novel facet closes a cycle, while there is another
> > component of facets.
> Do you mean for example:
> the HDS contains only one triangle. Then we insert a new triangle
> incident to only one vertex of the first triangle?
> > I have checked that the problem still exists in the latest version.
> > Cheers,
> > Jean-Philippe
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> View message @
> http://cgal-discuss.949826.n4.nabble.com/Bug-in-Polyhedron-incremental-builder-3-test-facet-tp2265287p2267270.html <http://cgal-discuss.949826.n4.nabble.com/Bug-in-Polyhedron-incremental-builder-3-test-facet-tp2265287p2267270.html?by-user=t>
> To unsubscribe from Bug in Polyhedron_incremental_builder_3::test_facet,
> click here
> <<Link Removed>>.
View this message in context: Re: Bug in Polyhedron_incremental_builder_3::test_facet <http://cgal-discuss.949826.n4.nabble.com/Bug-in-Polyhedron-incremental-builder-3-test-facet-tp2265287p2268422.html>
Sent from the cgal-discuss mailing list archive <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
Modified: branches/CGAL-3.6-branch/Polyhedron/include/CGAL/Polyhedron_incremental_builder_3.h
--- branches/CGAL-3.6-branch/Polyhedron/include/CGAL/Polyhedron_incremental_builder_3.h	2010-06-28 12:38:58 UTC (rev 57148)
+++ branches/CGAL-3.6-branch/Polyhedron/include/CGAL/Polyhedron_incremental_builder_3.h	2010-06-28 12:39:16 UTC (rev 57149)
@@ -753,12 +753,12 @@
                 return false;
-    // Test non-manifold edges
+    // Test non-manifold halfedges
     for ( std::size_t i = 0; i < n; ++i) {
-        // edge goes from vertex indices[i] to indices[i+1]
-        // we know already that the edge is only once in the sequence
+        // halfedge goes from vertex indices[i] to indices[i+1]
+        // we know already that the halfedge is only once in the sequence
         // (otherwise the end-vertices would be twice in the sequence too)
-        // check if edge is already in the HDS and is not border edge
+        // check if halfedge is already in the HDS and is not border halfedge
         Halfedge_handle v = get_vertex_to_edge_map(indices[i]);
         Vertex_handle   w = index_to_vertex_map[indices[i+1]];
         if ( v != Halfedge_handle()
@@ -775,7 +775,7 @@
     // test non-manifold vertices
         // since we don't allow duplicates in indices[..] and we
-        // tested for non-manifold edges already, we just need to check
+        // tested for non-manifold halfedges already, we just need to check
         // if the vertex indices[i] is not a closed manifold yet.
         if ( v != Halfedge_handle()) {
@@ -787,6 +787,75 @@
                 return false;
+    //Test if all halfedges of the new face
+    //are possibly consecutive border halfedges in the HDS.
+    //Possibly because it may be not directly encoded in the HDS
+    //(using next() function ). This situation can occur when one or
+    //more facets share only a vertex: For example, the new facet we try to add
+    //would make the vertex indices[i] a manifold but this should be forbidden
+    //if a facet only incident to that vertex has already been inserted.
+    //We check this for each vertex of the sequence.
+    for ( std::size_t i = 0; i < n; ++i) {
+      std::size_t prev_index=indices[ (i-1+n)%n];
+      std::size_t next_index=indices[ (i+1)%n];
+      Vertex_handle   previous_vertex = index_to_vertex_map[ prev_index ];
+      Vertex_handle   next_vertex     = index_to_vertex_map[ next_index ];
+      Halfedge_handle v = get_vertex_to_edge_map(indices[i]);
+      if ( v == Halfedge_handle() ||
+           get_vertex_to_edge_map(prev_index) == Halfedge_handle() ||
+           get_vertex_to_edge_map(next_index) == Halfedge_handle()
+         ) continue;
+      Halfedge_handle start=v;
+      //halfedges pointing to/running out from vertex indices[i]
+      //and that need to be possibly consecutive
+      Halfedge_handle previous=Halfedge_handle(),next=Halfedge_handle();
+      //look for a halfedge incident to vertex indices[i]
+      //and which opposite is incident to previous_vertex
+      do{
+        if (v->opposite()->vertex()==previous_vertex){
+          previous=v;
+          CGAL_precondition(previous->is_border());
+          break;
+        v = v->next()->opposite();
+      while (v!=start);
+      if (previous!=Halfedge_handle()){
+        v=v->next()->opposite();
+        //previous and next are already consecutive in the HDS
+        if (v->opposite()->vertex()==next_vertex) continue;
+        //look for a border halfedge which opposite is
+        //incident to next_vertex: set next halfedge
+        do
+          if (v->opposite()->vertex()==next_vertex){
+            next=v->opposite();
+            break;
+        while(v!=previous);
+        if (next==Halfedge_handle()) continue;
+        //check if no constraint prevents
+        //previous and next to be adjacent:
+        do{
+          if ( v->opposite()->is_border() ) break;
+        while (v!=previous);
+        if (v==previous) return false;
+        start=v;
     return true;
// Copyright (c) 1997  ETH Zurich (Switzerland).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL: svn+ssh:///svn/cgal/branches/CGAL-3.6-branch/Polyhedron/include/CGAL/Polyhedron_incremental_builder_3.h $
// $Id: Polyhedron_incremental_builder_3.h 57149 2010-06-28 12:39:16Z sloriot $
// Author(s)     : Lutz Kettner  <>)
#ifndef CGAL_POLYHEDRON_INCREMENTAL_BUILDER_3_H
#define CGAL_POLYHEDRON_INCREMENTAL_BUILDER_3_H 1
#include <CGAL/basic.h>
#include <CGAL/Random_access_adaptor.h>
#include <CGAL/HalfedgeDS_decorator.h>
#include <CGAL/Unique_hash_map.h>
#include <CGAL/IO/Verbose_ostream.h>
#include <vector>
#include <cstddef>
CGAL_BEGIN_NAMESPACE
template < class HalfedgeDS_>
class Polyhedron_incremental_builder_3 {
public:
    typedef HalfedgeDS_                     HDS; // internal
    typedef HalfedgeDS_                     HalfedgeDS;
    typedef typename HDS::Vertex            Vertex;
    typedef typename HDS::Halfedge          Halfedge;
    typedef typename HDS::Face              Face;
    typedef typename HDS::Vertex_handle     Vertex_handle;
    typedef typename HDS::Halfedge_handle   Halfedge_handle;
    typedef typename HDS::Face_handle       Face_handle;
    typedef typename HDS::Face_handle       Facet_handle;
    typedef typename Vertex::Base           VBase;
    typedef typename Halfedge::Base         HBase;
    typedef typename Vertex::Point          Point_3;
    typedef typename HDS::size_type         size_type;
protected:
    typedef typename HDS::Supports_vertex_halfedge  Supports_vertex_halfedge;
    typedef typename HDS::Supports_removal          Supports_removal;
    typedef typename HDS::Vertex_iterator           Vertex_iterator;
    typedef typename HDS::Halfedge_iterator         Halfedge_iterator;
    typedef Random_access_adaptor<Vertex_iterator>  Random_access_index;
    bool                      m_error;
    bool                      m_verbose;
    HDS&                      hds;
    size_type                 rollback_v;
    size_type                 rollback_f;
    size_type                 rollback_h;
    size_type                 new_vertices;
    size_type                 new_faces;
    size_type                 new_halfedges;
    Face_handle               current_face;
    Random_access_index       index_to_vertex_map;
    std::vector< Halfedge_handle>  vertex_to_edge_map;
    Halfedge_handle           g1;      // first halfedge, 0 denotes none.
    Halfedge_handle           gprime;
    Halfedge_handle           h1;      // current halfedge
    size_type                 w1;      // first vertex.
    size_type                 w2;      // second vertex.
    size_type                 v1;      // current vertex
    bool                      first_vertex;
    bool                      last_vertex;
    CGAL_assertion_code( int check_protocoll;)  // use to check protocoll.
    // states for checking: 0 = created, 1 = constructing, 2 = make face.
    // Implement the vertex_to_edge_map either with an array or
    // the halfedge pointer in the vertices (if supported).
    void initialize_vertex_to_edge_map( size_type  n, bool mode, Tag_true) {
        vertex_to_edge_map.clear();
        vertex_to_edge_map.resize(n);
        if ( mode) {
            // go through all halfedges and keep a halfedge for each
            // vertex found in a hashmap.
            size_type i = 0;
            for ( Vertex_iterator vi = hds.vertices_begin();
                  vi != hds.vertices_end();
                  ++vi) {
                set_vertex_to_edge_map( i, vi->halfedge());
                ++i;
    void initialize_vertex_to_edge_map( size_type n, bool mode, Tag_false){
        if ( mode) {
            typedef Unique_hash_map< Vertex_iterator, Halfedge_handle> V_map;
            Halfedge_handle hh;
            V_map v_map( hh, hds.size_of_vertices());
            for ( Halfedge_iterator hi = hds.halfedges_begin();
                  hi != hds.halfedges_end();
                  ++hi) {
                v_map[ hi->vertex()] = hi;
            size_type i = 0;
                  ++vi) {
                //set_vertex_to_edge_map( i, v_map[ index_to_vertex_map[i]]);
                set_vertex_to_edge_map( i, v_map[ vi]);
                ++i;
    void initialize_vertex_to_edge_map( size_type n, bool mode) {
        initialize_vertex_to_edge_map(n, mode, Supports_vertex_halfedge());
    void push_back_vertex_to_edge_map( Halfedge_handle h, Tag_true) {
        push_back_vertex_to_edge_map( h, Tag_false());
    void push_back_vertex_to_edge_map( Halfedge_handle h, Tag_false) {
        vertex_to_edge_map.push_back(h);
    void push_back_vertex_to_edge_map( Halfedge_handle h) {
        push_back_vertex_to_edge_map( h, Supports_vertex_halfedge());
    Halfedge_handle get_vertex_to_edge_map( size_type i, Tag_true) {
        // Use the halfedge pointer within the vertex.
        //CGAL_assertion( index_to_vertex_map[i]->halfedge() == get_vertex_to_edge_map(i, Tag_false()));
        return index_to_vertex_map[i]->halfedge();
    Halfedge_handle get_vertex_to_edge_map( size_type i, Tag_false) {
        // Use the self-managed array vertex_to_edge_map.
        return vertex_to_edge_map[i];
    Halfedge_handle get_vertex_to_edge_map( size_type i) {
        return get_vertex_to_edge_map( i, Supports_vertex_halfedge());
    void set_vertex_to_edge_map( size_type i, Halfedge_handle h, Tag_true) {
        set_vertex_to_edge_map( i, h, Tag_false());
        index_to_vertex_map[i]->VBase::set_halfedge(h);
    void set_vertex_to_edge_map( size_type i, Halfedge_handle h, Tag_false) {
        CGAL_assertion(i < vertex_to_edge_map.size());
        vertex_to_edge_map[i] = h;
    void set_vertex_to_edge_map( size_type i, Halfedge_handle h) {
        set_vertex_to_edge_map( i, h, Supports_vertex_halfedge());
// An Incremental Builder for Polyhedral Surfaces
// DEFINITION
// Polyhedron_incremental_builder_3<HDS> is an auxiliary class that
// supports the incremental construction of polyhedral surfaces. This is
// for example convinient when constructing polyhedral surfaces from
// files. The incremental construction starts with a list of all point
// coordinates and concludes with a list of all facet polygons. Edges are
// not explicitly specified. They are derived from the incidence
// information provided from the facet polygons. These are given as a
// sequence of vertex indices. The correct protocol of method calls to
// build a polyhedral surface can be stated as regular expression:
// `begin_surface (add_vertex | (begin_facet add_vertex_to_facet*
//  end_facet))* end_surface '
// PARAMETERS
// `HDS' is the halfedge data structure used to represent the
// polyhedral surface that is to be constructed.
// CREATION
public:
    bool error() const { return m_error; }
    Polyhedron_incremental_builder_3( HDS& h, bool verbose = false)
        // stores a reference to the halfedge data structure `h' in the
        // internal state. The previous polyhedral surface in `h'
        // remains unchanged. The incremental builder adds the new
        // polyhedral surface to the old one.
      : m_error( false), m_verbose( verbose), hds(h) {
        CGAL_assertion_code(check_protocoll = 0;)
    ~Polyhedron_incremental_builder_3() {
        CGAL_assertion( check_protocoll == 0);
// OPERATIONS
    enum { RELATIVE_INDEXING = 0, ABSOLUTE_INDEXING = 1};
    void begin_surface( std::size_t v, std::size_t f, std::size_t h = 0,
                        int mode = RELATIVE_INDEXING);
        // starts the construction. v is the number of new
        // vertices to expect, f the number of new facets, and h the number of
        // new halfedges. If h is unspecified (`== 0') it is estimated using
        // Euler equations (plus 5% for the so far unkown holes and genus
        // of the object). These values are used to reserve space in the
        // polyhedron representation `HDS'. If the representation
        // supports insertion these values do not restrict the class of
        // readable polyhedrons. If the representation does not support
        // insertion the object must fit in the reserved sizes.
        //    If `mode' is set to ABSOLUTE_INDEXING the incremental builder
        // uses absolute indexing and the vertices of the old polyhedral
        // surface can be used in new facets. Otherwise relative indexing is
        // used starting with new indices for the new construction.
    Vertex_handle add_vertex( const Point_3& p) {
        // adds p to the vertex list.
        CGAL_assertion( check_protocoll == 1);
        if ( hds.size_of_vertices() >= hds.capacity_of_vertices()) {
            Verbose_ostream verr( m_verbose);
            verr << " " << std::endl;
            verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::"
                 << std::endl;
            verr << "add_vertex(): capacity error: more than " << new_vertices
                 << " vertices added." << std::endl;
            m_error = true;
            return Vertex_handle();
        HalfedgeDS_decorator<HDS> decorator(hds);
        Vertex_handle v = decorator.vertices_push_back( Vertex(p));
        index_to_vertex_map.push_back( v);
        decorator.set_vertex_halfedge( v, Halfedge_handle());
        push_back_vertex_to_edge_map( Halfedge_handle());
        ++new_vertices;
        return v;
    // returns handle for the vertex of index i
    Vertex_handle vertex( std::size_t i) {
        if ( i < new_vertices)
            return index_to_vertex_map[i];
    Facet_handle begin_facet() {
        // starts a facet.
        if ( m_error)
            return Facet_handle();
        CGAL_assertion_code( check_protocoll = 2;)
        if ( hds.size_of_faces() >= hds.capacity_of_faces()) {
                 << std::endl;
            verr << "begin_facet(): capacity error: more than " << new_vertices
                 << " facets added." << std::endl;
            m_error = true;
        // initialize all status variables.
        first_vertex = true;  // denotes 'no vertex yet'
        g1 =  Halfedge_handle();  // denotes 'no halfedge yet'
        last_vertex = false;
        current_face = decorator.faces_push_back( Face());
        return current_face;
    void add_vertex_to_facet( std::size_t i);
        // adds a vertex with index i to the current facet. The first
        // point added with `add_vertex()' has the index 0.
    Halfedge_handle end_facet() {
        // ends a facet.
        if ( m_error)
            return Halfedge_handle();
        CGAL_assertion( check_protocoll == 2);
        CGAL_assertion( ! first_vertex);
        // cleanup all static status variables
        add_vertex_to_facet( w1);
        if ( m_error)
        last_vertex = true;
        add_vertex_to_facet( w2);
        if ( m_error)
        CGAL_assertion_code( check_protocoll = 1;)
        HalfedgeDS_items_decorator<HDS> decorator;
        Halfedge_handle h = get_vertex_to_edge_map(w1);
        decorator.set_face_halfedge( current_face, h);
        ++new_faces;
        return h;
    template <class InputIterator>
    Halfedge_handle add_facet( InputIterator first, InputIterator beyond) {
        // synonym for begin_facet(), a call to add_vertex_to_facet() for each iterator
        // value type, and end_facet().
        begin_facet();
        for ( ; ! m_error && first != beyond; ++first)
            add_vertex_to_facet( *first);
        if ( m_error)
        return end_facet();
    bool test_facet( InputIterator first, InputIterator beyond) {
        // tests if the facet described by the vertex indices in the
        // range [first,beyond) can be inserted without creating a
        // a non-manifold (and therefore invalid) situation.
        // First, create a copy of the indices and close it cyclically
        std::vector< std::size_t> indices( first, beyond);
        if ( indices.size() < 3)
            return false;
        indices.push_back( indices[0]);
        return test_facet_indices( indices);
    bool test_facet_indices( std::vector< std::size_t> indices);
    void end_surface();
        // ends the construction.
    bool check_unconnected_vertices();
        // returns `true' if unconnected vertices are detected. If `verb'
        // is set to `true' debug information about the unconnected
        // vertices is printed.
    bool remove_unconnected_vertices( Tag_true);
    bool remove_unconnected_vertices( Tag_false) {
        return ! check_unconnected_vertices();
    bool remove_unconnected_vertices() {
        // returns `true' if all unconnected vertices could be removed
        // succesfully.
        return remove_unconnected_vertices( Supports_removal());
    void rollback();
protected:
    Halfedge_handle lookup_hole( std::size_t w) {
        CGAL_assertion( w < new_vertices);
        return lookup_hole( get_vertex_to_edge_map( w));
    size_type find_vertex( Vertex_handle v) {
        // Returns 0 if v == NULL.
        if ( v == Vertex_handle() )
            return 0;
        size_type n = 0;
        typename HDS::Vertex_iterator it = hds.vertices_begin();
        while ( it != v) {
            CGAL_assertion( it != hds.vertices_end());
            ++n;
            ++it;
        n = n - rollback_v;
        return n;
    size_type find_facet( Face_handle f) {
        // Returns 0 if f == NULL.
        if ( f == Face_handle())
            return 0;
        size_type n = 0;
        typename HDS::Face_iterator it = hds.faces_begin();
        while ( it != f) {
            CGAL_assertion( it != hds.faces_end());
            ++n;
            ++it;
        n = n - rollback_f;
        return n;
    Halfedge_handle lookup_halfedge( size_type w, size_type v) {
        // Pre: 0 <= w,v < new_vertices
        // Case a: It exists an halfedge g from w to v:
        //     g must be a border halfedge and the facet of g->opposite()
        //     must be set and different from the current facet.
        //     Set the facet of g to the current facet. Return the
        //     halfedge pointing to g.
        // Case b: It exists no halfedge from w to v:
        //     Create a new pair of halfedges g and g->opposite().
        //     Set the facet of g to the current facet and g->opposite()
        //     to a border halfedge. Assign the vertex references.
        //     Set g->opposite()->next() to g. Return g->opposite().
        typedef typename HDS::Supports_halfedge_vertex
            Supports_halfedge_vertex;
        Assert_compile_time_tag( Supports_halfedge_vertex(), Tag_true());
        CGAL_assertion( v < new_vertices);
        CGAL_assertion( ! last_vertex);
        Halfedge_handle e = get_vertex_to_edge_map( w);
        if ( e != Halfedge_handle()) {
            CGAL_assertion( e->vertex() == index_to_vertex_map[w]);
            // check that the facet has no self intersections
            if ( current_face != Face_handle()
                 && current_face == decorator.get_face(e)) {
                     << std::endl;
                verr << "lookup_halfedge(): input error: facet "
                     << new_faces << " has a self intersection at vertex "
                     << w << "." << std::endl;
                m_error = true;
            Halfedge_handle start_edge( e);
            do {
                if ( e->next()->vertex() == index_to_vertex_map[v]) {
                    if ( ! e->next()->is_border()) {
                        verr << "CGAL::Polyhedron_incremental_builder_3"
                                "<HDS>::" << std::endl;
                             << new_faces << " shares a halfedge from "
                                "vertex " <<  w << " to vertex " << v
                             << " with";
                        if (  m_verbose && current_face != Face_handle())
                            verr << " facet "
                                 << find_facet( decorator.get_face(e->next()))
                                 << '.' << std::endl;
                        else
                            verr << " another facet." << std::endl;
                        m_error = true;
                    CGAL_assertion( ! e->next()->opposite()->is_border());
                    if ( current_face != Face_handle() && current_face ==
                         decorator.get_face( e->next()->opposite())) {
                             << new_faces << " has a self intersection "
                                "at the halfedge from vertex " << w
                             << " to vertex " << v << "." << std::endl;
                        m_error = true;
                    decorator.set_face( e->next(), current_face);
                    return e;
                e = e->next()->opposite();
            } while ( e != start_edge);
        // create a new halfedge
        if ( hds.size_of_halfedges() >= hds.capacity_of_halfedges()) {
                 << std::endl;
            verr << "lookup_halfedge(): capacity error: more than "
                 << new_halfedges << " halfedges added while creating facet"
                 << new_faces << '.' << std::endl;
            m_error = true;
        e = hds.edges_push_back( Halfedge(), Halfedge());
        new_halfedges++;
        new_halfedges++;
        decorator.set_face( e, current_face);
        e->HBase::set_vertex( index_to_vertex_map[v]);
        e->HBase::set_next( Halfedge_handle());
        decorator.set_prev( e, e->opposite());
        e = e->opposite();
        e->HBase::set_vertex( index_to_vertex_map[w]);
        e->HBase::set_next( e->opposite());
        return e;
    Halfedge_handle lookup_hole( Halfedge_handle e) {
        // Halfedge e points to a vertex w. Walk around w to find a hole
        // in the facet structure. Report an error if none exist. Return
        // the halfedge at this hole that points to the vertex w.
        CGAL_assertion( e != Halfedge_handle());
        do {
            if ( e->next()->is_border()) {
                return e;
        verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::" << std::endl;
        verr << "lookup_hole(): input error: at vertex "
             << find_vertex( e->vertex())
             << " a closed surface already exists and facet "
             << new_faces << " is nonetheless adjacent." << std::endl;
        if (  m_verbose && current_face != Face_handle()) {
            verr << "             The closed cycle of facets is:";
            do {
                if ( ! e->is_border())
                    verr << " " << find_facet( decorator.get_face(e));
            verr << '.' << std::endl;
        m_error = true;
template < class HDS>
void
rollback() {
    CGAL_assertion( rollback_v <= hds.size_of_vertices());
    CGAL_assertion( rollback_h <= hds.size_of_halfedges());
    CGAL_assertion( rollback_f <= hds.size_of_faces());
    if ( rollback_v == 0 && rollback_h == 0 && rollback_f == 0) {
        hds.clear();
    } else {
        while ( rollback_v != hds.size_of_vertices())
            hds.vertices_pop_back();
        CGAL_assertion((( hds.size_of_halfedges() - rollback_h) & 1) == 0);
        while ( rollback_h != hds.size_of_halfedges())
            hds.edges_pop_back();
        while ( rollback_f != hds.size_of_faces())
            hds.faces_pop_back();
    m_error = false;
    CGAL_assertion_code( check_protocoll = 0;)
template < class HDS>  CGAL_MEDIUM_INLINE
void
begin_surface( std::size_t v, std::size_t f, std::size_t h, int mode) {
    CGAL_assertion( ! m_error);
    if ( mode == RELATIVE_INDEXING) {
        new_vertices  = 0;
        new_faces     = 0;
        new_halfedges = 0;
        rollback_v    = hds.size_of_vertices();
        rollback_f    = hds.size_of_faces();
        rollback_h    = hds.size_of_halfedges();
    } else {
        new_vertices  = hds.size_of_vertices();
        new_faces     = hds.size_of_faces();
        new_halfedges = hds.size_of_halfedges();
        rollback_v    = 0;
        rollback_f    = 0;
        rollback_h    = 0;
    if ( h == 0) {
        // Use the Eulerian equation for connected planar graphs. We do
        // not know the number of facets that are holes and we do not
        // know the genus of the surface. So we add 12 and a factor of
        // 5 percent.
        h = int((v + f - 2 + 12) * 2.1);
    hds.reserve( hds.size_of_vertices()  + v,
                 hds.size_of_halfedges() + h,
                 hds.size_of_faces()     + f);
        index_to_vertex_map = Random_access_index( hds.vertices_end());
        index_to_vertex_map.reserve(v);
        initialize_vertex_to_edge_map( v, false);
    } else {
        index_to_vertex_map = Random_access_index( hds.vertices_begin(),
        index_to_vertex_map.reserve( hds.size_of_vertices() + v);
        initialize_vertex_to_edge_map( hds.size_of_vertices() + v, true);
void
add_vertex_to_facet( std::size_t v2) {
    if ( m_error)
        return;
    if ( v2 >= new_vertices) {
             << std::endl;
        verr << "add_vertex_to_facet(): vertex index " << v2
             << " is out-of-range [0," << new_vertices-1 << "]."
             << std::endl;
        m_error = true;
        return;
    if ( first_vertex) {
        w1 = v2;
        first_vertex = false;
        return;
    if ( g1 == Halfedge_handle()) {
        gprime  = lookup_halfedge( w1, v2);
        if ( m_error)
            return;
        h1 = g1 = gprime->next();
        v1 = w2 = v2;
        return;
    // g1, h1, v1, w1, w2 are set. Insert halfedge.
    // Lookup v1-->v2
    Halfedge_handle hprime;
    if ( last_vertex)
        hprime = gprime;
    else {
        hprime = lookup_halfedge( v1, v2);
        if ( m_error)
            return;
    Halfedge_handle h2 = hprime->next();
    CGAL_assertion( ! last_vertex || h2 == g1);
    Halfedge_handle prev = h1->next();
    h1->HBase::set_next( h2);
    decorator.set_prev( h2, h1);
    if ( get_vertex_to_edge_map( v1) == Halfedge_handle()) {  // case 1:
        h2->opposite()->HBase::set_next( h1->opposite());
        decorator.set_prev( h1->opposite(), h2->opposite());
    } else {                                                  // case 2:
        bool b1 = h1->opposite()->is_border();
        bool b2 = h2->opposite()->is_border();
        if ( b1 && b2) {
            Halfedge_handle hole = lookup_hole( v1);
            if ( m_error)
                return;
            CGAL_assertion( hole != Halfedge_handle());
            h2->opposite()->HBase::set_next( hole->next());
            decorator.set_prev( hole->next(), h2->opposite());
            hole->HBase::set_next( h1->opposite());
            decorator.set_prev( h1->opposite(), hole);
        } else if ( b2) {                                     // case 2.b:
            CGAL_assertion( prev->is_border());
            h2->opposite()->HBase::set_next( prev);
            decorator.set_prev( prev, h2->opposite());
        } else if ( b1) {                                     // case 2.c:
            CGAL_assertion( hprime->is_border());
            hprime->HBase::set_next( h1->opposite());
            decorator.set_prev( h1->opposite(), hprime);
        } else if ( h2->opposite()->next() == h1->opposite()) {// case 2.d:
            // f1 == f2
            CGAL_assertion( decorator.get_face( h1->opposite()) ==
                       decorator.get_face( h2->opposite()));
        } else {                                              // case 2.e:
            if ( prev == h2) {                                // case _i:
                // nothing to be done, hole is closed.
            } else {                                          // case _ii:
                hprime->HBase::set_next( prev);
                decorator.set_prev( prev, hprime);
                // Check whether the halfedges around v1 are connected.
                // It is sufficient to check it for h1 to prev.
                // Assert loop termination:
                CGAL_assertion_code( std::size_t k = 0;)
                // Look for a hole in the facet complex starting at h1.
                Halfedge_handle hole;
                Halfedge_handle e = h1;
                do {
                    if ( e->is_border())
                        hole = e;
                    CGAL_assertion( k++ < hds.size_of_halfedges());
                } while ( e->next() != prev && e != h1);
                if ( e == h1) {
                    // disconnected facet complexes
                    if ( hole != Halfedge_handle()) {
                        // The complex can be connected with
                        // the hole at hprime.
                        hprime->HBase::set_next( hole->next());
                        decorator.set_prev( hole->next(), hprime);
                        hole->HBase::set_next( prev);
                        decorator.set_prev( prev, hole);
                    } else {
                        verr << "CGAL::Polyhedron_incremental_builder_3<"
                                "HDS>::" << std::endl;
                        verr << "add_vertex_to_facet(): input error: "
                                "disconnected facet complexes at vertex "
                             << v1 << ":" << std::endl;
                            verr << "           involved facets are:";
                            do {
                            } while ( e != h1);
                            verr << " (closed cycle) and";
                            e = hprime;
                            do {
                            } while ( e != hprime);
                            verr << "." << std::endl;
                        m_error = true;
                        return;
    if ( h1->vertex() == index_to_vertex_map[v1])
        set_vertex_to_edge_map( v1, h1);
    CGAL_assertion( h1->vertex() == index_to_vertex_map[v1]);
    h1 = h2;
    v1 = v2;
bool
test_facet_indices( std::vector< std::size_t> indices) {
    typedef typename HDS::Supports_halfedge_vertex Supports_halfedge_vertex;
    // tests if the facet described by the vertex indices can be inserted
    // without creating a a non-manifold (and therefore invalid) situation.
    // indices are cyclically closed once.
    std::size_t n = indices.size() - 1;
    // Test if a vertex is not twice in the indices
        CGAL_precondition( indices[i] < new_vertices);
        // check if vertex indices[i] is already in the sequence [0..i-1]
        for ( std::size_t k = 0; k+1 < i; ++k) {
            if ( indices[k] == indices[i])
                return false;
             && get_vertex_to_edge_map(indices[i+1]) != Halfedge_handle()) {
            // cycle through halfedge-loop and find edge to indices[i+1]
            Halfedge_handle vstart = v;
            do {
            } while ( v->next()->vertex() != w && v != vstart);
            if ( v->next()->vertex() == w && ! v->next()->is_border())
                return false;
            do {
            } while ( ! v->is_border() && v != vstart);
            if ( ! v->is_border())
                return false;
         ) continue;
      do{
          previous=v;
          break;
      while (v!=start);
        do
            next=v->opposite();
            break;
        while(v!=previous);
        do{
        start=v;
    return true;
void
end_surface() {
    if ( m_error)
        return;
bool
check_unconnected_vertices() {
    if ( m_error)
        return false;
    bool unconnected = false;
    for ( std::size_t i = 0; i < new_vertices; i++) {
        if ( get_vertex_to_edge_map( i) == Halfedge_handle()) {
            verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::\n"
                 << "check_unconnected_vertices( verb = true): "
                 << "vertex " << i << " is unconnected." << std::endl;
            unconnected = true;
    return unconnected;
bool
remove_unconnected_vertices( Tag_true) {
    if ( m_error)
        return true;
    for( std::size_t i = 0; i < new_vertices; i++) {
        if( get_vertex_to_edge_map( i) == Halfedge_handle()) {
            hds.vertices_erase( index_to_vertex_map[i]);
    return true;
CGAL_END_NAMESPACE
#endif // CGAL_POLYHEDRON_INCREMENTAL_BUILDER_3_H //
// EOF //
