- To:
- Subject: [cgal-discuss] Error by compiling poisson_reconstruction_example
- Date: Thu, 24 Jun 2010 10:21:04 -0700 (PDT)
Hi, everyone,
after Sebastien helped me, finally I installed taucs successfully. I'm only
one step away from compiling. I thought at least.
Now I have an error as follow:
abbotxie@abbotxie-laptop:~/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3$
cmake -DCGAL_DIR=$HOME/CGAL-3.6 .
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING EXEFLAGS = ' '
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- TAUCS include: /usr/local/include
-- TAUCS definitions:
-- TAUCS library directories: /usr/local/lib
-- TAUCS libraries: /usr/local/lib/libtaucs.a;/usr/local/lib/libmetis.a
-- LAPACK include:
-- LAPACK definitions:
-- LAPACK library directories: /usr/local/lib
-- LAPACK libraries: true
-- LAPACK link flags:
-- BLAS include:
-- BLAS definitions:
-- BLAS library directories: /usr/local/lib
-- BLAS libraries: true
-- BLAS link flags:
-- MKL not found. Please specify library location.
-- NOTICE: Some of the executables in this directory need the MKL library
and will not be compiled.
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3
make
Linking CXX executable poisson_reconstruction_example
/usr/bin/ld: cannot find -ltrue
collect2: ld returned 1 exit status
make[2]: *** [poisson_reconstruction_example] Error 1
make[1]: *** [CMakeFiles/poisson_reconstruction_example.dir/all] Error 2
make: *** [all] Error 2
I can't find anything about this -ltrue. Has anyone an idea about this?
Thank you.
Best regards
XIE Yi
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-by-compiling-poisson-reconstruction-example-tp2267331p2267331.html
- [cgal-discuss] Error by compiling poisson_reconstruction_example, Xie Yi, 06/24/2010
- Re: [cgal-discuss] Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Rineau (GeometryFactory), 06/25/2010
