- To:
- Subject: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example
- Date: Mon, 28 Jun 2010 12:15:40 -0700 (PDT)
Thank you for your answer, Laurent.
Here is what I get after I removed CMakeCache.txt.
abbotxie@abbotxie-laptop:~/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3$
rm CMakeCache.txt
cmake -DCGAL_DIR=/home/abbotxie/Programs/CGAL-3.6 .
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING EXEFLAGS = ' '
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- Looking for sgemm_
-- Looking for sgemm_ - not found
-- Looking for sgemm - not found
-- A library with BLAS API not found. Please specify library location.
-- LAPACK requires BLAS.
-- TAUCS requires LAPACK and BLAS.
-- NOTICE: Some of the executables in this directory need the TAUCS library
and will not be compiled.
-- Configuring done
-- Generating done
-- Build files have been written to:
/home/abbotxie/Programs/CGAL-3.6/examples/Surface_reconstruction_points_3
Here is what I get with make in Taucs folder:
abbotxie@abbotxie-laptop:~/Programs/taucs_full$
make
mkdir obj
mkdir: cannot create directory `obj': File exists
make: [obj/linux/exists.log] Error 1 (ignored)
mkdir obj/linux/
echo exists > obj/linux/exists.log
cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I
external/src/ \
progs/taucs_blas_underscore_test.c \
-o ./obj/linux/taucs_blas_underscore_test.o
cc \
-o ./obj/linux/taucs_blas_underscore_test \
obj/linux/taucs_blas_underscore_test.o -L external/lib/linux
-llapack -L external/lib/linux -lf77blas -lcblas -latlas -L
external/lib/linux -lmetis -lg2c -lm
obj/linux/taucs_blas_underscore_test build/linux/taucs_config_tests.h
Linking with dgemm_ succedded
external/src/ \
progs/taucs_blas_nounderscore_test.c \
-o ./obj/linux/taucs_blas_nounderscore_test.o
cc \
-o ./obj/linux/taucs_blas_nounderscore_test \
obj/linux/taucs_blas_nounderscore_test.o -L external/lib/linux
obj/linux/taucs_blas_nounderscore_test.o: In function `main':
taucs_blas_nounderscore_test.c:(.text+0xa4): undefined reference to `dgemm'
collect2: ld returned 1 exit status
make: [build/linux/taucs_config_tests.h] Error 1 (ignored)
obj/linux/taucs_blas_nounderscore_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_blas_nounderscore_test: Command not found
make: [build/linux/taucs_config_tests.h] Error 127 (ignored)
external/src/ \
progs/taucs_c99_complex_test.c \
-o ./obj/linux/taucs_c99_complex_test.o
cc \
-o ./obj/linux/taucs_c99_complex_test \
obj/linux/taucs_c99_complex_test.o -L external/lib/linux -llapack
-L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux
-lmetis -lg2c -lm
obj/linux/taucs_c99_complex_test build/linux/taucs_config_tests.h
C99 complex numbers seem to be supported, 1+sqrt(-1)=-1.000000+1.000000i
external/src/ \
progs/taucs_cilk_test.c \
-o ./obj/linux/taucs_cilk_test.o
progs/taucs_cilk_test.c:8:19: error: cilk.h: No such file or directory
progs/taucs_cilk_test.c:10: warning: ignoring #pragma lang
progs/taucs_cilk_test.c:12: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
‘__attribute__’ before ‘int’
progs/taucs_cilk_test.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or
cc \
-o ./obj/linux/taucs_cilk_test \
obj/linux/taucs_cilk_test.o -L external/lib/linux -llapack -L
external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux -lmetis
-lg2c -lm
cc: obj/linux/taucs_cilk_test.o: No such file or directory
obj/linux/taucs_cilk_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_cilk_test: Command not found
mkdir bin
mkdir: cannot create directory `bin': File exists
make: [bin/linux/exists.log] Error 1 (ignored)
mkdir bin/linux/
echo exists > bin/linux/exists.log
mkdir lib
mkdir: cannot create directory `lib': File exists
make: [lib/linux/exists.log] Error 1 (ignored)
mkdir lib/linux/
echo exists > lib/linux/exists.log
external/src/ \
-DTAUCS_CORE_GENERAL \
src/taucs_sn_llt.c \
-o ./obj/linux/taucs_sn_llt.o
src/taucs_sn_llt.c:1339: warning: ‘tree_first_descendant’ defined but not
used
external/src/ \
-DTAUCS_CORE_DOUBLE \
-o ./obj/linux/taucs_sn_llt_D.o
external/src/ \
-DTAUCS_CORE_SINGLE \
-o ./obj/linux/taucs_sn_llt_S.o
external/src/ \
-DTAUCS_CORE_DCOMPLEX \
-o ./obj/linux/taucs_sn_llt_Z.o
external/src/ \
-DTAUCS_CORE_SCOMPLEX \
-o ./obj/linux/taucs_sn_llt_C.o
external/src/ \
src/taucs_linsolve.c \
-o ./obj/linux/taucs_linsolve.o
external/src/ \
src/taucs_logging.c \
-o ./obj/linux/taucs_logging.o
external/src/ \
src/taucs_memory.c \
-o ./obj/linux/taucs_memory.o
external/src/ \
src/taucs_timer.c \
-o ./obj/linux/taucs_timer.o
external/src/ \
src/taucs_ccs_base.c \
-o ./obj/linux/taucs_ccs_base.o
external/src/ \
-o ./obj/linux/taucs_ccs_base_D.o
external/src/ \
-o ./obj/linux/taucs_ccs_base_S.o
external/src/ \
-o ./obj/linux/taucs_ccs_base_Z.o
external/src/ \
-o ./obj/linux/taucs_ccs_base_C.o
external/src/ \
src/taucs_vec_base.c \
-o ./obj/linux/taucs_vec_base.o
external/src/ \
-o ./obj/linux/taucs_vec_base_D.o
external/src/ \
-o ./obj/linux/taucs_vec_base_S.o
external/src/ \
-o ./obj/linux/taucs_vec_base_Z.o
external/src/ \
-o ./obj/linux/taucs_vec_base_C.o
external/src/ \
src/taucs_ccs_ops.c \
-o ./obj/linux/taucs_ccs_ops.o
external/src/ \
-o ./obj/linux/taucs_ccs_ops_D.o
external/src/ \
-o ./obj/linux/taucs_ccs_ops_S.o
external/src/ \
-o ./obj/linux/taucs_ccs_ops_Z.o
external/src/ \
-o ./obj/linux/taucs_ccs_ops_C.o
external/src/ \
src/taucs_ccs_io.c \
-o ./obj/linux/taucs_ccs_io.o
external/src/ \
-o ./obj/linux/taucs_ccs_io_D.o
src/taucs_ccs_io.c: In function ‘taucs_dccs_read_ccs’:
src/taucs_ccs_io.c:884: warning: ignoring return value of ‘fscanf’, declared
with attribute warn_unused_result
src/taucs_ccs_io.c:888: warning: ignoring return value of ‘fscanf’, declared
src/taucs_ccs_io.c:895: warning: ignoring return value of ‘fscanf’, declared
src/taucs_ccs_io.c:899: warning: ignoring return value of ‘fscanf’, declared
external/src/ \
-o ./obj/linux/taucs_ccs_io_S.o
src/taucs_ccs_io.c: In function ‘taucs_sccs_read_ccs’:
src/taucs_ccs_io.c:904: warning: ignoring return value of ‘fscanf’, declared
external/src/ \
-o ./obj/linux/taucs_ccs_io_Z.o
src/taucs_ccs_io.c: In function ‘taucs_zccs_read_ccs’:
src/taucs_ccs_io.c:911: warning: ignoring return value of ‘fscanf’, declared
external/src/ \
-o ./obj/linux/taucs_ccs_io_C.o
src/taucs_ccs_io.c: In function ‘taucs_cccs_read_ccs’:
src/taucs_ccs_io.c:920: warning: ignoring return value of ‘fscanf’, declared
external/src/ \
src/taucs_ccs_order.c \
-o ./obj/linux/taucs_ccs_order.o
external/src/ \
src/taucs_ccs_factor_llt.c \
-o ./obj/linux/taucs_ccs_factor_llt.o
external/src/ \
-o ./obj/linux/taucs_ccs_factor_llt_D.o
external/src/ \
-o ./obj/linux/taucs_ccs_factor_llt_S.o
external/src/ \
-o ./obj/linux/taucs_ccs_factor_llt_Z.o
external/src/ \
-o ./obj/linux/taucs_ccs_factor_llt_C.o
external/src/ \
src/taucs_ccs_solve_llt.c \
-o ./obj/linux/taucs_ccs_solve_llt.o
external/src/ \
-o ./obj/linux/taucs_ccs_solve_llt_D.o
external/src/ \
-o ./obj/linux/taucs_ccs_solve_llt_S.o
external/src/ \
-o ./obj/linux/taucs_ccs_solve_llt_Z.o
external/src/ \
-o ./obj/linux/taucs_ccs_solve_llt_C.o
external/src/ \
src/taucs_complex.c \
-o ./obj/linux/taucs_complex.o
external/src/ \
-o ./obj/linux/taucs_complex_D.o
external/src/ \
-o ./obj/linux/taucs_complex_S.o
external/src/ \
-o ./obj/linux/taucs_complex_Z.o
external/src/ \
-o ./obj/linux/taucs_complex_C.o
external/src/ \
src/taucs_ccs_ooc_llt.c \
-o ./obj/linux/taucs_ccs_ooc_llt.o
external/src/ \
-o ./obj/linux/taucs_ccs_ooc_llt_D.o
src/taucs_ccs_ooc_llt.c:1096: warning: ‘recursive_read_L’ defined but not
used
src/taucs_ccs_ooc_llt.c:1161: warning:
‘recursive_leftlooking_supernodal_factor_llt_ooc’ defined but not used
src/taucs_ccs_ooc_llt.c:1308: warning:
‘recursive_compute_supernodes_in_core_old’ defined but not used
src/taucs_ccs_ooc_llt.c:1338: warning:
‘recursive_compute_supernodes_ipostorder’ defined but not used
external/src/ \
-o ./obj/linux/taucs_ccs_ooc_llt_S.o
used
external/src/ \
-o ./obj/linux/taucs_ccs_ooc_llt_Z.o
used
external/src/ \
-o ./obj/linux/taucs_ccs_ooc_llt_C.o
used
external/src/ \
src/taucs_ccs_ooc_lu.c \
-o ./obj/linux/taucs_ccs_ooc_lu.o
external/src/ \
-o ./obj/linux/taucs_ccs_ooc_lu_D.o
external/src/ \
-o ./obj/linux/taucs_ccs_ooc_lu_S.o
external/src/ \
-o ./obj/linux/taucs_ccs_ooc_lu_Z.o
external/src/ \
-o ./obj/linux/taucs_ccs_ooc_lu_C.o
external/src/ \
src/taucs_ooc_io.c \
-o ./obj/linux/taucs_ooc_io.o
external/src/ \
src/taucs_iter.c \
-o ./obj/linux/taucs_iter_D.o
external/src/ \
src/taucs_vaidya.c \
-o ./obj/linux/taucs_vaidya_D.o
src/taucs_vaidya.c:336: warning: ‘quick_sort’ defined but not used
src/taucs_vaidya.c: In function ‘amst_preconditioner_create’:
src/taucs_vaidya.c:3667: warning: ‘dilation’ may be used uninitialized in
this function
src/taucs_vaidya.c:3667: note: ‘dilation’ was declared here
src/taucs_vaidya.c: In function ‘taucs_amwb_preconditioner_create’:
src/taucs_vaidya.c:214: warning: ‘h.edges’ may be used uninitialized in this
function
src/taucs_vaidya.c:1376: note: ‘h.edges’ was declared here
src/taucs_vaidya.c:215: warning: ‘h.key’ may be used uninitialized in this
function
src/taucs_vaidya.c:1376: note: ‘h.key’ was declared here
external/src/ \
src/taucs_recvaidya.c \
-o ./obj/linux/taucs_recvaidya_D.o
src/taucs_recvaidya.c: In function
‘taucs_recursive_amwb_preconditioner_create’:
src/taucs_recvaidya.c:254: warning: ‘p’ may be used uninitialized in this
function
external/src/ \
src/taucs_gremban.c \
-o ./obj/linux/taucs_gremban_D.o
external/src/ \
src/taucs_ccs_xxt.c \
-o ./obj/linux/taucs_ccs_xxt_D.o
external/src/ \
src/taucs_ccs_generators.c \
-o ./obj/linux/taucs_ccs_generators_D.o
src/taucs_ccs_generators.c: In function ‘taucs_ccs_generate_rrn’:
src/taucs_ccs_generators.c:446: warning: suggest parentheses around
comparison in operand of ‘!=’
external/src/ \
src/taucs_malloc.c \
-o ./obj/linux/taucs_malloc.o
g77 -c -O3 -g -fno-second-underscore -Wall \
external/src/readhb.f \
-o ./obj/linux/readhb.o
external/src/amdatr.f \
-o ./obj/linux/amdatr.o
external/src/amdatr.f: In subroutine `amdatr':
In file included from external/src/amdatr.f:0:
external/src/amdatr.f:404: warning: unused variable 'dext'
external/src/amdatr.f:406: warning: 'me' might be used uninitialized in this
function
external/src/amdbar.f \
-o ./obj/linux/amdbar.o
external/src/amdbar.f: In subroutine `amdbar':
In file included from external/src/amdbar.f:0:
external/src/amdbar.f:405: warning: unused variable 'dext'
external/src/amdbar.f:407: warning: 'me' might be used uninitialized in this
function
external/src/amdexa.f \
-o ./obj/linux/amdexa.o
external/src/amdexa.f: In subroutine `amdexa':
In file included from external/src/amdexa.f:0:
external/src/amdexa.f:396: warning: unused variable 'wnvi'
external/src/amdexa.f:396: warning: unused variable 'we'
external/src/amdexa.f:393: warning: unused variable 'dext'
external/src/amdexa.f:395: warning: 'me' might be used uninitialized in this
function
external/src/amdhaf.f \
-o ./obj/linux/amdhaf.o
external/src/amdhaf.f: In subroutine `amdhaf':
In file included from external/src/amdhaf.f:0:
external/src/amdhaf.f:403: warning: unused variable 'wnvi'
external/src/amdhaf.f:403: warning: unused variable 'we'
external/src/amdhaf.f:400: warning: unused variable 'dext'
external/src/amdhaf.f:402: warning: 'me' might be used uninitialized in this
function
external/src/amdhat.f \
-o ./obj/linux/amdhat.o
external/src/amdhat.f: In subroutine `amdhat':
In file included from external/src/amdhat.f:0:
external/src/amdhat.f:402: warning: unused variable 'wnvi'
external/src/amdhat.f:402: warning: unused variable 'we'
external/src/amdhat.f:399: warning: unused variable 'dext'
external/src/amdhat.f:401: warning: 'me' might be used uninitialized in this
function
external/src/amdpre.f \
-o ./obj/linux/amdpre.o
external/src/amdpre.f: In subroutine `amdpre':
In file included from external/src/amdpre.f:0:
external/src/amdpre.f:120: warning: 'ntemp' might be used uninitialized in
this function
external/src/amdtru.f \
-o ./obj/linux/amdtru.o
external/src/amdtru.f: In subroutine `amdtru':
In file included from external/src/amdtru.f:0:
external/src/amdtru.f:396: warning: unused variable 'wnvi'
external/src/amdtru.f:396: warning: unused variable 'we'
external/src/amdtru.f:393: warning: unused variable 'dext'
external/src/amdtru.f:395: warning: 'me' might be used uninitialized in this
function
external/src/genmmd.f \
-o ./obj/linux/genmmd.o
external/src/ \
external/src/colamd.c \
-o ./obj/linux/colamd.o
rm -rf lib/linux/libtaucs.a
ar cr lib/linux/libtaucs.a obj/linux/taucs_sn_llt.o
obj/linux/taucs_sn_llt_D.o obj/linux/taucs_sn_llt_S.o
obj/linux/taucs_sn_llt_Z.o obj/linux/taucs_sn_llt_C.o
obj/linux/taucs_linsolve.o obj/linux/taucs_logging.o
obj/linux/taucs_memory.o obj/linux/taucs_timer.o obj/linux/taucs_ccs_base.o
obj/linux/taucs_ccs_base_D.o obj/linux/taucs_ccs_base_S.o
obj/linux/taucs_ccs_base_Z.o obj/linux/taucs_ccs_base_C.o
obj/linux/taucs_vec_base.o obj/linux/taucs_vec_base_D.o
obj/linux/taucs_vec_base_S.o obj/linux/taucs_vec_base_Z.o
obj/linux/taucs_vec_base_C.o obj/linux/taucs_ccs_ops.o
obj/linux/taucs_ccs_ops_D.o obj/linux/taucs_ccs_ops_S.o
obj/linux/taucs_ccs_ops_Z.o obj/linux/taucs_ccs_ops_C.o
obj/linux/taucs_ccs_io.o obj/linux/taucs_ccs_io_D.o
obj/linux/taucs_ccs_io_S.o obj/linux/taucs_ccs_io_Z.o
obj/linux/taucs_ccs_io_C.o obj/linux/taucs_ccs_order.o
obj/linux/taucs_ccs_factor_llt.o obj/linux/taucs_ccs_factor_llt_D.o
obj/linux/taucs_ccs_factor_llt_S.o obj/linux/taucs_ccs_factor_llt_Z.o
obj/linux/taucs_ccs_factor_llt_C.o obj/linux/taucs_ccs_solve_llt.o
obj/linux/taucs_ccs_solve_llt_D.o obj/linux/taucs_ccs_solve_llt_S.o
obj/linux/taucs_ccs_solve_llt_Z.o obj/linux/taucs_ccs_solve_llt_C.o
obj/linux/taucs_complex.o obj/linux/taucs_complex_D.o
obj/linux/taucs_complex_S.o obj/linux/taucs_complex_Z.o
obj/linux/taucs_complex_C.o obj/linux/taucs_ccs_ooc_llt.o
obj/linux/taucs_ccs_ooc_llt_D.o obj/linux/taucs_ccs_ooc_llt_S.o
obj/linux/taucs_ccs_ooc_llt_Z.o obj/linux/taucs_ccs_ooc_llt_C.o
obj/linux/taucs_ccs_ooc_lu.o obj/linux/taucs_ccs_ooc_lu_D.o
obj/linux/taucs_ccs_ooc_lu_S.o obj/linux/taucs_ccs_ooc_lu_Z.o
obj/linux/taucs_ccs_ooc_lu_C.o obj/linux/taucs_ooc_io.o
obj/linux/taucs_iter_D.o obj/linux/taucs_vaidya_D.o
obj/linux/taucs_recvaidya_D.o obj/linux/taucs_gremban_D.o
obj/linux/taucs_ccs_xxt_D.o obj/linux/taucs_ccs_generators_D.o
obj/linux/taucs_malloc.o obj/linux/readhb.o obj/linux/amdatr.o
obj/linux/amdbar.o obj/linux/amdexa.o obj/linux/amdhaf.o obj/linux/amdhat.o
obj/linux/amdpre.o obj/linux/amdtru.o obj/linux/genmmd.o obj/linux/colamd.o
ranlib lib/linux/libtaucs.a
external/src/ \
progs/direct.c \
-o ./obj/linux/direct.o
progs/direct.c: In function ‘actual_main’:
progs/direct.c:402: warning: ignoring return value of ‘fscanf’, declared
progs/direct.c:406: warning: ignoring return value of ‘fscanf’, declared
cc \
-o ./bin/linux/direct \
obj/linux/direct.o \
-Llib/linux/ -ltaucs \
-L external/lib/linux -llapack -L external/lib/linux -lf77blas
-lcblas -latlas -L external/lib/linux -lmetis -lg2c -lm
external/src/ \
progs/taucs_run.c \
-o ./obj/linux/taucs_run.o
cc \
-o ./bin/linux/taucs_run \
obj/linux/taucs_run.o \
external/src/ \
progs/iter.c \
-o ./obj/linux/iter.o
progs/iter.c: In function ‘main’:
progs/iter.c:365: warning: ignoring return value of ‘fscanf’, declared with
progs/iter.c:369: warning: ignoring return value of ‘fscanf’, declared with
cc \
-o ./bin/linux/iter \
obj/linux/iter.o \
make
mkdir obj
mkdir obj/linux/
external/src/ \
cc \
external/src/ \
cc \
external/src/ \
cc \
-lmetis -lg2c -lm
external/src/ \
cc \
-lg2c -lm
mkdir bin
mkdir bin/linux/
mkdir lib
mkdir lib/linux/
external/src/ \
used
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
src/taucs_timer.c \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
used
external/src/ \
used
external/src/ \
used
external/src/ \
used
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
external/src/ \
src/taucs_iter.c \
external/src/ \
this function
function
function
external/src/ \
function
external/src/ \
external/src/ \
external/src/ \
external/src/ \
function
function
function
function
function
this function
function
external/src/ \
external/src/ \
progs/direct.c \
cc \
external/src/ \
progs/taucs_run.c \
cc \
external/src/ \
progs/iter.c \
cc \
obj/linux/iter.o \
Best regards
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Re-Error-by-compiling-poisson-reconstruction-example-tp2268101p2271352.html
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, (continued)
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/25/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Rineau (GeometryFactory), 06/25/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/28/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/29/2010
- [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Xie Yi, 06/29/2010
- Re: [cgal-discuss] Re: Error by compiling poisson_reconstruction_example, Laurent Saboret, 06/30/2010
