- To:
- Subject: Re: [cgal-discuss] Problem with storing handles as member objects
- Date: Tue, 6 Jul 2010 10:08:06 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=KlfaopJEDSUBRDh0xR6VpxIPUUPVXsUotuy4lnlTAa0ntnpnFHRMRZq85Of8RAUsSs 9MUmbPBAwGZp2rrUDGEbHPAgg21c6+fvNeduXp1XReyfG9F01DFxztxuPCNx1gZNJdxE 5oH/fxciYJVohifYQvva9qiPInYKuUW4Nu0aE=
Here's scraps of code that are indicative of the situation:
* In the augmented halfedge class I store a CGAL::Object that contains
* a handle, it could be either a face handle or an edge stored in it:
Object _corresponding_triangulation_object;
* And the member functions that make use of it are:
bool overlaps_with_triangulation_edge(void)
{ bool temp = _corresponding_triangulation_object.template is<Triangulation_face_handle>();
return !temp; }
void set_corresponding_triangulation_object( Object &obj )
{ _corresponding_triangulation_object = obj; }
template< typename Triangulation_item >
void set_corresponding_triangulation_object( Triangulation_item &t_item )
{ _corresponding_triangulation_object = Construct_object()(t_item); }
Object& corresponding_triangulation_object(void)
{ return _corresponding_triangulation_object; }
* So let's say that at some point some function "A" is called where it does this:
Halfedge_handle current_ph;
**** do something with current_ph ****
Halfedge_handle target_ph, old_ph;
target_ph = fnwk.surface_polyhedron().split_edge( current_ph );
target_ph->vertex()->point() = p;
old_ph = target_ph->next();
target_ph->set_corresponding_triangulation_object(current_ph->corresponding_triangulation_object());
CGAL_assertion(target_ph->overlaps_with_triangulation_edge());
target_ph->opposite()->set_corresponding_triangulation_object(current_ph->opposite()->corresponding_triangulation_object());
CGAL_assertion(target_ph->opposite()->overlaps_with_triangulation_edge());
old_ph->opposite()->set_corresponding_triangulation_object(current_ph->opposite()->corresponding_triangulation_object());
* Up to here everything is executed ok. But in the following code, after the execution
*of "A" is done, when I traverse the polyhedron face that contains the above halfedges I get *segmentation faults either in the std::cout line or in the line where *->overlaps_with_triangulation_edge() is called.
Halfedge_handle other_ph = ..... ;
Triangulation_edge entry_te = ..... ;
Triangulation_edge current_te = entry_te;
while( !(other_ph->overlaps_with_triangulation_edge()) || current_te == entry_te )
std::cout << " other_ph->vertex : "<< other_ph->vertex()->point() << std::endl;
other_ph = other_ph->next();
if(other_ph->overlaps_with_triangulation_edge())
CGAL::assign(current_te, other_ph->corresponding_triangulation_object() );
I think there is no problem with accessing the vertex point, the memory error
has to do with the triangulation handles stored as objects in the halfedges.
thanks
Constantinos
On Tue, Jul 6, 2010 at 7:48 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
Costas Tsirogiannis wrote:What do you use to split halfedges ? (the underlying question being how
Greetings,
I have a problem with run-time errors coming from an unorthodox use of handles:
I make use of a triangulation and of an augmented polyhedron_3 object. This augmented polyhedron
is a refinement of the surface represented by the triangulation : as some algorithm goes on, new edges
are added on what used to be the triangular faces. It is important that the halfedges,faces and vertices
on the polyhedron that originate from features of the triangulation should point to the corresponding triangulation
features. Thus each feature stores a handle of the original triangulation object: a polyhedron vertex stores a handle
to the original triangulation vertex of the same coordinates, a halfedge stores a handle to the triangulation edge or
face on which it lies etc.
When a feature is refined eg a halfedge is split, these stored handles of triangulation features are copied to
the newly created features. And then segmentation faults appear.
your handles are set)--
Specifically, things go wrong when there is an attempt
to access the handle member object of the new feature outside of the function that created the feature (and copied the
handle object to it). Any ideas for what could fix this?
thanks
Constantinos
- [cgal-discuss] Problem with storing handles as member objects, Costas Tsirogiannis, 07/05/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Sebastien Loriot (GeometryFactory), 07/06/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Costas Tsirogiannis, 07/06/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Costas Tsirogiannis, 07/07/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Sebastien Loriot (GeometryFactory), 07/08/2010
- Re: [cgal-discuss] Problem with storing handles as member objects, Costas Tsirogiannis, 07/08/2010
