cgal-discuss - Re: [cgal-discuss] Problem with storing handles as member objects
  • To:
  • Subject: Re: [cgal-discuss] Problem with storing handles as member objects
  • Date: Tue, 6 Jul 2010 16:02:05 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=cMQXnHZM1WfsHZGpWVXD6CFZWq3q84O/JX9IATPf0jTeJTY2t64jPPyjdWy5X1saQX hjegnbzJQzuub1nC9AtBYDn8hl4EGsl4G9xGaroQCETyZulyVk8hWPlI56cNjyIvzBgA +Ngmpoc1z4a1TP3ZZk6gA/gL6b9y55O+Kl8i0=
 I have not defined a copy constructor for the augmented half-edges, would that change something here?
On Tue, Jul 6, 2010 at 3:31 PM, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
Did you define a copy constructor and forget to copy the object?
I think in your case, you should use a boost::Variant as the number of
possible types is only 2.
Costas Tsirogiannis wrote:
Here's scraps of code that are indicative of the situation:
* In the augmented halfedge class I store a CGAL::Object that contains
* a handle, it could be either a face handle or an edge stored in it:
Object  _corresponding_triangulation_object;
* And the member functions that make use of it are:
 bool overlaps_with_triangulation_edge(void)
 { bool temp = _corresponding_triangulation_object.template is<Triangulation_face_handle>();
  return !temp; }
 void set_corresponding_triangulation_object( Object &obj )
 { _corresponding_triangulation_object = obj; }
 template< typename Triangulation_item >
 void set_corresponding_triangulation_object( Triangulation_item &t_item )
 { _corresponding_triangulation_object = Construct_object()(t_item); }
 Object& corresponding_triangulation_object(void)
 { return _corresponding_triangulation_object; }
* So let's say that at some point some function "A"  is called where it does this:
Halfedge_handle current_ph;
**** do something with current_ph ****
 Halfedge_handle   target_ph, old_ph;
target_ph = fnwk.surface_polyhedron().split_edge( current_ph );
target_ph->vertex()->point() = p;
 old_ph = target_ph->next();
 target_ph->set_corresponding_triangulation_object(current_ph->corresponding_triangulation_object());
 CGAL_assertion(target_ph->overlaps_with_triangulation_edge());
 target_ph->opposite()->set_corresponding_triangulation_object(current_ph->opposite()->corresponding_triangulation_object());
 CGAL_assertion(target_ph->opposite()->overlaps_with_triangulation_edge());
 old_ph->opposite()->set_corresponding_triangulation_object(current_ph->opposite()->corresponding_triangulation_object());
* Up to here everything is executed ok. But in the following code, after the execution
*of "A" is done, when I traverse the polyhedron face that contains the above halfedges I get *segmentation faults  either in the std::cout line or in the line where *->overlaps_with_triangulation_edge() is called.
Halfedge_handle other_ph = ..... ;
Triangulation_edge entry_te = ..... ;
Triangulation_edge current_te = entry_te;
while( !(other_ph->overlaps_with_triangulation_edge()) || current_te == entry_te )
    std::cout << " other_ph->vertex : "<<  other_ph->vertex()->point() << std::endl;
   other_ph = other_ph->next();
   if(other_ph->overlaps_with_triangulation_edge())
     CGAL::assign(current_te, other_ph->corresponding_triangulation_object() );
 I think there is no problem with accessing the vertex point, the memory error
has to do with the triangulation handles stored as objects in the halfedges.
thanks
Constantinos
On Tue, Jul 6, 2010 at 7:48 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:
       Greetings,
       I have a problem with run-time errors coming from an unorthodox
       use of handles:
        I make use of a triangulation and of an augmented polyhedron_3
       object. This augmented polyhedron
       is a refinement of the surface represented by the triangulation
       : as some algorithm goes on, new edges
       are added on what used to be the triangular faces. It is
       important that the halfedges,faces and vertices
       on the polyhedron that originate from features of the
       triangulation should point to the corresponding triangulation
       features.  Thus each feature stores a handle of the original
       triangulation object: a polyhedron vertex stores a handle
       to the original triangulation vertex of the same coordinates, a
       halfedge stores a handle to the triangulation edge or
       face on which it lies etc.
        When a feature is refined eg a halfedge is split, these stored
       handles of triangulation features are copied to
       the newly created features. And then segmentation faults appear.
   What do you use to split halfedges ? (the underlying question being how
   your handles are set)
       Specifically, things go wrong when there is an attempt
       to access the handle member object of the new feature outside of
       the function that created the feature (and copied the
       handle object to it).  Any ideas for what could fix this?
       thanks
       Constantinos
   --     You are currently subscribed to cgal-discuss.
