cgal-discuss - Re: Re: [cgal-discuss] problem with TAUCS
  • To:
  • Subject: Re: Re: [cgal-discuss] problem with TAUCS
  • Date: Fri, 16 Jul 2010 17:34:13 +0200 (CEST)
Hi,
ok, i guess you mean this (from cmake):
CGAL_MAJOR_VERSION=3
CGAL_MINOR_VERSION=6
CGAL_BUILD_VERSION=
CGAL_SONAME_VERSION=5
CGAL_SOVERSION =5.0.0
CGAL_REFERENCE_CACHE_DIR=
Building static libraries
Targetting Visual Studio 9 2008
Target build enviroment supports auto-linking
Using VC90 compiler.
Generator uses intermediate configuration directory: $(OutDir)
USING CMake version: 2.8.1
System: Windows
Build type: Release
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
-D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
-D_CRT_SECURE_NO_WARNINGS
-D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG'
USING LDFLAGS = ' '
GMP include: C:/CGAL-3.6/auxiliary/gmp/include
GMP libraries:
GMP definitions:
USING GMP_VERSION = '4.2.4'
MPFR include: C:/CGAL-3.6/auxiliary/gmp/include
MPFR libraries:
MPFR definitions:
USING MPFR_VERSION = '2.3.2'
Boost include: C:/Programas/boost/boost_1_41
Boost libraries:
optimized;C:/Programas/boost/boost_1_41/lib/libboost_thread-vc90-mt-1_41.lib;debug;C:/Programas/boost/boost_1_41/lib/libboost_thread-vc90-mt-gd-1_41.lib
Boost definitions:
USING BOOST_VERSION = '1.41.0'
CMAKE_INSTALL_PREFIX=C:/Programas/CGAL
Could NOT find ZLIB (missing: ZLIB_LIBRARIES ZLIB_INCLUDE_DIRS)
OpenGL include:
OpenGL libraries: glu32;opengl32
NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature will
not
be activated.
CGAL_Qt3 needs Qt3, cannot be configured.
USING QT4_VERSION = '4.6.2'
OpenGL include:
OpenGL definitions:
Qt4 include: C:/Qt/4.6.2/include
Qt4 libraries:
optimized;C:/Qt/4.6.2/lib/qtmain.lib;debug;C:/Qt/4.6.2/lib/qtmaind.lib;optimized;C:/Qt/4.6.2/lib/QtOpenGL4.lib;debug;C:/Qt/4.6.2/lib/QtOpenGLd4.lib;optimized;C:/Qt/4.6.2/lib/QtGui4.lib;debug;C:/Qt/4.6.2/lib/QtGuid4.lib;optimized;C:/Qt/4.6.2/lib/QtCore4.lib;debug;C:/Qt/4.6.2/lib/QtCored4.lib
Qt4 definitions: -DQT_DLL
moc executable: C:/Qt/4.6.2/bin/moc.exe
uic executable: C:/Qt/4.6.2/bin/uic.exe
Configuring C:/CGAL-3.6/examples/AABB_tree example
Configuring C:/CGAL-3.6/examples/Algebraic_foundations example
Configuring C:/CGAL-3.6/examples/Algebraic_kernel_d example
Could NOT find MPFI
RS requires MPFI
NOTICE: This program requires RS and will not be compiled.
Configuring C:/CGAL-3.6/examples/Alpha_shapes_2 example
Configuring C:/CGAL-3.6/examples/Alpha_shapes_3 example
Configuring C:/CGAL-3.6/examples/Apollonius_graph_2 example
Configuring C:/CGAL-3.6/examples/Approximate_min_ellipsoid_d example
Configuring C:/CGAL-3.6/examples/Arrangement_on_surface_2 example
Configuring C:/CGAL-3.6/examples/BGL_arrangement_2 example
Configuring C:/CGAL-3.6/examples/BGL_polyhedron_3 example
Configuring C:/CGAL-3.6/examples/BGL_triangulation_2 example
Configuring C:/CGAL-3.6/examples/Boolean_set_operations_2 example
Configuring C:/CGAL-3.6/examples/Box_intersection_d example
Configuring C:/CGAL-3.6/examples/CGAL_ipelets example
Configuring C:/CGAL-3.6/examples/CGALimageIO example
Configuring C:/CGAL-3.6/examples/Circular_kernel_2 example
Configuring C:/CGAL-3.6/examples/Circular_kernel_3 example
Configuring C:/CGAL-3.6/examples/Circulator example
Configuring C:/CGAL-3.6/examples/Convex_decomposition_3 example
Configuring C:/CGAL-3.6/examples/Convex_hull_2 example
Configuring C:/CGAL-3.6/examples/Convex_hull_3 example
Configuring C:/CGAL-3.6/examples/Core example
Configuring C:/CGAL-3.6/examples/Developers_manual example
Configuring C:/CGAL-3.6/examples/Envelope_2 example
Configuring C:/CGAL-3.6/examples/Envelope_3 example
Configuring C:/CGAL-3.6/examples/Filtered_kernel example
Configuring C:/CGAL-3.6/examples/Generator example
Configuring C:/CGAL-3.6/examples/HalfedgeDS example
Configuring C:/CGAL-3.6/examples/Interpolation example
Configuring C:/CGAL-3.6/examples/Interval_skip_list example
Configuring C:/CGAL-3.6/examples/Jet_fitting_3 example
LAPACK include: C:/CGAL-3.6/auxiliary/taucs/include
LAPACK definitions:
LAPACK library directories: C:/CGAL-3.6/auxiliary/taucs/lib
LAPACK link flags:
BLAS include: C:/CGAL-3.6/auxiliary/taucs/include
BLAS definitions:
BLAS library directories: C:/CGAL-3.6/auxiliary/taucs/lib
BLAS link flags:
CMake Warning at cmake/modules/FindBoost.cmake:406 (if):
given arguments:
"NOT" "BOOST_ROOT" "AND" "NOT" "C:\\Programas\\boost\\boost_1_41"
"C:\\Programas\\boost\\boost_1_41\\lib" "STREQUAL" ""
Unknown arguments specified
Call Stack (most recent call first):
examples/Jet_fitting_3/CMakeLists.txt:30 (find_package)
Configuring C:/CGAL-3.6/examples/Kernel_23 example
Configuring C:/CGAL-3.6/examples/Kinetic_data_structures example
Configuring C:/CGAL-3.6/examples/Kinetic_framework example
Configuring C:/CGAL-3.6/examples/Largest_empty_rect_2 example
Configuring C:/CGAL-3.6/examples/Matrix_search example
Configuring C:/CGAL-3.6/examples/Mesh_2 example
Configuring C:/CGAL-3.6/examples/Mesh_3 example
NOTICE: The example mesh_3D_image.cpp needs CGAL_ImageIO to be configured with
ZLIB support, and will not be compiled.
Configuring C:/CGAL-3.6/examples/Min_annulus_d example
Configuring C:/CGAL-3.6/examples/Min_circle_2 example
Configuring C:/CGAL-3.6/examples/Min_ellipse_2 example
Configuring C:/CGAL-3.6/examples/Min_quadrilateral_2 example
Configuring C:/CGAL-3.6/examples/Min_sphere_d example
Configuring C:/CGAL-3.6/examples/Min_sphere_of_spheres_d example
Configuring C:/CGAL-3.6/examples/Minkowski_sum_2 example
Configuring C:/CGAL-3.6/examples/Minkowski_sum_3 example
Configuring C:/CGAL-3.6/examples/Modular_arithmetic example
Configuring C:/CGAL-3.6/examples/Nef_2 example
Configuring C:/CGAL-3.6/examples/Nef_3 example
Configuring C:/CGAL-3.6/examples/Nef_S2 example
Configuring C:/CGAL-3.6/examples/Partition_2 example
Configuring C:/CGAL-3.6/examples/Periodic_3_triangulation_3 example
Configuring C:/CGAL-3.6/examples/Point_set_2 example
Configuring C:/CGAL-3.6/examples/Point_set_processing_3 example
USING DEBUG CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHa /GR
-D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /FR /wd4267 /wd4311 /wd4800
/wd4503 /wd4244 /wd4345 /wd4996 /wd4396 /wd4018 /D_DEBUG /MDd /Zi /Ob0 /Od
/RTC1'
USING DEBUG EXEFLAGS = ' /STACK:10000000 /machine:X86 /LARGEADDRESSAWARE
/debug /INCREMENTAL:YES'
USING RELEASE CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHa /GR
/wd4503 /wd4244 /wd4345 /wd4996 /wd4396 /wd4018 /MD /O2 /Ob2 /D NDEBUG'
USING RELEASE EXEFLAGS = ' /STACK:10000000 /machine:X86 /LARGEADDRESSAWARE
/INCREMENTAL:NO'
LAPACK definitions:
LAPACK link flags:
BLAS definitions:
BLAS link flags:
Configuring C:/CGAL-3.6/examples/Polygon example
Configuring C:/CGAL-3.6/examples/Polyhedron example
Configuring C:/CGAL-3.6/examples/Polyhedron_IO example
Configuring C:/CGAL-3.6/examples/Polynomial example
Configuring C:/CGAL-3.6/examples/Polynomial_kernel example
Configuring C:/CGAL-3.6/examples/Polytope_distance_d example
Configuring C:/CGAL-3.6/examples/Principal_component_analysis example
Configuring C:/CGAL-3.6/examples/Profiling_tools example
Configuring C:/CGAL-3.6/examples/QP_solver example
Configuring C:/CGAL-3.6/examples/RangeSegmentTrees example
Configuring C:/CGAL-3.6/examples/Ridges_3 example
LAPACK definitions:
LAPACK link flags:
BLAS definitions:
BLAS link flags:
given arguments:
examples/Ridges_3/CMakeLists.txt:26 (find_package)
Configuring C:/CGAL-3.6/examples/STL_Extension example
Configuring C:/CGAL-3.6/examples/Segment_Delaunay_graph_2 example
Configuring C:/CGAL-3.6/examples/Skin_surface_3 example
Configuring C:/CGAL-3.6/examples/Snap_rounding_2 example
Configuring C:/CGAL-3.6/examples/Spatial_searching example
Configuring C:/CGAL-3.6/examples/Spatial_sorting example
Configuring C:/CGAL-3.6/examples/Straight_skeleton_2 example
Configuring C:/CGAL-3.6/examples/Stream_lines_2 example
Configuring C:/CGAL-3.6/examples/Subdivision_method_3 example
Configuring C:/CGAL-3.6/examples/Surface_mesh_parameterization example
/RTC1'
/INCREMENTAL:NO'
given arguments:
examples/Surface_mesh_parameterization/CMakeLists.txt:63 (find_package)
TAUCS include: C:/CGAL-3.6/auxiliary/taucs/include
TAUCS definitions:
TAUCS library directories: C:/CGAL-3.6/auxiliary/taucs/lib
LAPACK definitions:
LAPACK link flags:
BLAS definitions:
BLAS link flags:
Configuring C:/CGAL-3.6/examples/Surface_mesh_simplification example
Configuring C:/CGAL-3.6/examples/Surface_mesher example
Configuring C:/CGAL-3.6/examples/Triangulation_2 example
Configuring C:/CGAL-3.6/examples/Triangulation_3 example
Configuring C:/CGAL-3.6/examples/Voronoi_diagram_2 example
Configuring C:/CGAL-3.6/examples/Width_3 example
Configuring done
...and this from VC++ compiler:
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Taucs_matrix.h(291) :
error C4430: missing type specifier - int assumed. Note: C++ does not support
default-int
9.0\VC\include\CGAL/Taucs_matrix.h(402) : see reference to class template
instantiation 'CGAL::Taucs_matrix<T>' being compiled
error C2143: syntax error : missing ';' before '*'
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Taucs_matrix.h(292) :
default-int
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Taucs_matrix.h(341) :
warning C4183: 'get_taucs_matrix': missing return type; assumed to be a member
function returning 'int'
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Taucs_matrix.h(400) :
default-int
default-int
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Taucs_matrix.h(448) :
error C2065: 'taucs_double' : undeclared identifier
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Taucs_matrix.h(450) :
error C2913: explicit specialization; 'CGAL::Taucs_traits' is not a
specialization of a class template
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Taucs_matrix.h(453) :
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Taucs_matrix.h(456) :
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Taucs_matrix.h(459) :
C:\Programas\Microsoft Visual Studio 9.0\VC\include\CGAL/Win32_exception.h(77)
: warning C4535: calling _set_se_translator() requires /EHa
9.0\VC\include\CGAL/Peak_memory_sizer.h(55) : error C3861:
'taucs_system_memory_size': identifier not found
9.0\VC\include\CGAL/Peak_memory_sizer.h(106) : error C3861:
hope that's what you were asking me to do!!
Best regards,
Cristóvão
