cgal-discuss - Re: Re: Re: [cgal-discuss] problem with TAUCS
  • To:
  • Subject: Re: Re: Re: [cgal-discuss] problem with TAUCS
  • Date: Sat, 17 Jul 2010 15:28:27 +0200 (CEST)
meanwhile i restored CMakeLists.txt and run cmake-gui on the example's folder,
and i got this:
Build type: Release
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
-D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
-D_CRT_SECURE_NO_WARNINGS
-D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG'
USING EXEFLAGS = ' /STACK:10000000 /machine:X86 /INCREMENTAL:NO'
Targetting Visual Studio 9 2008
Target build enviroment supports auto-linking
Using VC90 compiler.
Generator uses intermediate configuration directory: $(OutDir)
USING DEBUG CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHa /GR
-D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /FR /wd4267 /wd4311 /wd4800
/wd4503 /wd4244 /wd4345 /wd4996 /wd4396 /wd4018 /D_DEBUG /MDd /Zi /Ob0 /Od
/RTC1'
USING DEBUG EXEFLAGS = ' /STACK:10000000 /machine:X86 /LARGEADDRESSAWARE
/debug /INCREMENTAL:YES'
USING RELEASE CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHa /GR
/wd4503 /wd4244 /wd4345 /wd4996 /wd4396 /wd4018 /MD /O2 /Ob2 /D NDEBUG'
USING RELEASE EXEFLAGS = ' /STACK:10000000 /machine:X86 /LARGEADDRESSAWARE
/INCREMENTAL:NO'
TAUCS include: C:/CGAL-3.6/auxiliary/taucs/include
TAUCS definitions:
TAUCS library directories: C:/CGAL-3.6/auxiliary/taucs/lib
LAPACK include: C:/CGAL-3.6/auxiliary/taucs/include
LAPACK definitions:
LAPACK library directories: C:/CGAL-3.6/auxiliary/taucs/lib
LAPACK link flags:
BLAS include: C:/CGAL-3.6/auxiliary/taucs/include
BLAS definitions:
BLAS library directories: C:/CGAL-3.6/auxiliary/taucs/lib
BLAS link flags:
MKL not found. Please specify library location.
NOTICE: Some of the executables in this directory need the MKL library and
will
not be compiled.
Configuring done
Cristóvão
