cgal-discuss - [cgal-discuss] Re: Problem with partitioning
  • To:
  • Subject: [cgal-discuss] Re: Problem with partitioning
  • Date: Tue, 20 Jul 2010 04:33:24 -0700 (PDT)
You are right... According to CGAL the polygon I am trying to partition is
not simple.
I am writing my program in Java and I use the CGAL through JNI. Currently, I
was checking whether my polygon is simple through JTS (Java Topology Suite),
that believes that this polygon is simple!
I'll read through the documentation to check if JTS define simplicity in the
same way that CGAL defines it (although I can't understand why there should
be any difference).
Thank you very much for your reply!
[1]
http://www.cgal.org/Manual/3.2/doc_html/cgal_manual/Polygon/Chapter_main.html
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-partitioning-tp2293936p2295326.html
