- To:
- Subject: Re: [cgal-discuss] Re: Problem with partitioning
- Date: Wed, 28 Jul 2010 09:49:11 +0200
Kostis wrote:
I have one more question that is related with polygon partitioning.1) you can use the arrangement package:
In some cases, I have non-simple polygons that need to be partitioned. Since all the partitioning algorithms require a simple polygon, is there a
way to convert a non-simple polygon to a union of simple polygons?
make an arrangement of the segment and use the result to get simple polygons.
2) a constrained triangulation with intersecting constraints can probably do the job as well
S.
- [cgal-discuss] Problem with partitioning, Kostis, 07/19/2010
- Re: [cgal-discuss] Problem with partitioning, Sebastien Loriot (GeometryFactory), 07/19/2010
- [cgal-discuss] Re: Problem with partitioning, Kostis, 07/20/2010
- [cgal-discuss] Re: Problem with partitioning, Kostis, 07/21/2010
- [cgal-discuss] Re: Problem with partitioning, Kostis, 07/27/2010
- Re: [cgal-discuss] Re: Problem with partitioning, Sebastien Loriot (GeometryFactory), 07/28/2010
- [cgal-discuss] Re: Problem with partitioning, Ralph Boland, 07/28/2010
