- To:
- Subject: [cgal-discuss] Re: Problem with partitioning
- Date: Wed, 21 Jul 2010 05:10:25 -0700 (PDT)
I read the documentation of JTS and it appears that JTS assumes that all
polygons are simple (by definition). So, the function Polygon.isSimple is
the following:
public boolean isSimple() {
return true;
Thank you very much for your help!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-partitioning-tp2293936p2297005.html
- [cgal-discuss] Problem with partitioning, Kostis, 07/19/2010
- Re: [cgal-discuss] Problem with partitioning, Sebastien Loriot (GeometryFactory), 07/19/2010
- [cgal-discuss] Re: Problem with partitioning, Kostis, 07/20/2010
- [cgal-discuss] Re: Problem with partitioning, Kostis, 07/21/2010
- [cgal-discuss] Re: Problem with partitioning, Kostis, 07/27/2010
- Re: [cgal-discuss] Re: Problem with partitioning, Sebastien Loriot (GeometryFactory), 07/28/2010
- [cgal-discuss] Re: Problem with partitioning, Ralph Boland, 07/28/2010
