- To:
- Subject: [cgal-discuss] Re: Hilbert Sort on a User Defined Point
- Date: Tue, 10 Aug 2010 07:30:50 -0700 (PDT)
Here's the complex error massage:
In file included from
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/algorithm:62,
from nn_test.h:24,
from nn_test.cc:10:
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:
In function ‘const _Tp& std::__median(const _Tp&, const _Tp&, const _Tp&)
[with _Tp = Point3]’:
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:2268:
instantiated from ‘void std::__introsort_loop(_RandomAccessIterator,
_RandomAccessIterator, _Size) [with _RandomAccessIterator =
__gnu_cxx::__normal_iterator<Point3*, std::vector<Point3,
std::allocator<Point3> > >, _Size = int]’
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:5220:
instantiated from ‘void std::sort(_RAIter, _RAIter) [with _RAIter =
std::allocator<Point3> > >]’
nn_test.cc:327: instantiated from here
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:89:
error: no match for ‘operator<’ in ‘__a < __b’
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:90:
error: no match for ‘operator<’ in ‘__b < __c’
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:92:
error: no match for ‘operator<’ in ‘__a < __c’
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:96:
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:98:
In function ‘_RandomAccessIterator
std::__unguarded_partition(_RandomAccessIterator, _RandomAccessIterator,
_Tp) [with _RandomAccessIterator = __gnu_cxx::__normal_iterator<Point3*,
std::vector<Point3, std::allocator<Point3> > >, _Tp = Point3]’:
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:2209:
‘__first.__gnu_cxx::__normal_iterator<_Iterator, _Container>::operator*
[with _Iterator = Point3*, _Container = std::vector<Point3,
std::allocator<Point3> >]() < __pivot’
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:2212:
error: no match for ‘operator<’ in ‘__pivot <
__last.__gnu_cxx::__normal_iterator<_Iterator, _Container>::operator* [with
_Iterator = Point3*, _Container = std::vector<Point3, std::allocator<Point3>
In function ‘void std::__insertion_sort(_RandomAccessIterator,
_RandomAccessIterator) [with _RandomAccessIterator =
std::allocator<Point3> > >]’:
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:2178:
instantiated from ‘void std::__final_insertion_sort(_RandomAccessIterator,
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:5222:
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:2106:
error: no match for ‘operator<’ in ‘__val <
__first.__gnu_cxx::__normal_iterator<_Iterator, _Container>::operator* [with
In function ‘void std::__heap_select(_RandomAccessIterator,
_RandomAccessIterator, _RandomAccessIterator) [with _RandomAccessIterator =
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:5067:
instantiated from ‘void std::partial_sort(_RAIter, _RAIter, _RAIter) [with
_RAIter = __gnu_cxx::__normal_iterator<Point3*, std::vector<Point3,
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:2256:
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:1906:
‘__i.__gnu_cxx::__normal_iterator<_Iterator, _Container>::operator* [with
>]() < __first.__gnu_cxx::__normal_iterator<_Iterator,
_Container>::operator* [with _Iterator = Point3*, _Container =
std::vector<Point3, std::allocator<Point3> >]()’
In function ‘void std::__unguarded_linear_insert(_RandomAccessIterator, _Tp)
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:2112:
instantiated from ‘void std::__insertion_sort(_RandomAccessIterator,
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:2067:
__next.__gnu_cxx::__normal_iterator<_Iterator, _Container>::operator* [with
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:62,
from
from nn_test.h:24,
from nn_test.cc:10:
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_heap.h:
In function ‘void std::__adjust_heap(_RandomAccessIterator, _Distance,
_Distance, _Tp) [with _RandomAccessIterator =
std::allocator<Point3> > >, _Distance = int, _Tp = Point3]’:
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_heap.h:394:
instantiated from ‘void std::make_heap(_RAIter, _RAIter) [with _RAIter =
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_algo.h:1904:
instantiated from ‘void std::__heap_select(_RandomAccessIterator,
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_heap.h:232:
‘__first.__gnu_cxx::__normal_iterator<_Iterator, _Container>::operator+
std::allocator<Point3> >](((const ptrdiff_t&)((const ptrdiff_t*)(&
__secondChild)))).__gnu_cxx::__normal_iterator<_Iterator,
std::vector<Point3, std::allocator<Point3> >]() <
__first.__gnu_cxx::__normal_iterator<_Iterator, _Container>::operator+ [with
>](((const ptrdiff_t&)((const ptrdiff_t*)(&(__secondChild +
-0x000000001))))).__gnu_cxx::__normal_iterator<_Iterator,
In function ‘void std::__push_heap(_RandomAccessIterator, _Distance,
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_heap.h:244:
instantiated from ‘void std::__adjust_heap(_RandomAccessIterator, _Distance,
/usr/lib/gcc/i586-redhat-linux/4.4.1/../../../../include/c++/4.4.1/bits/stl_heap.h:134:
__parent)))).__gnu_cxx::__normal_iterator<_Iterator, _Container>::operator*
std::allocator<Point3> >]() < __value’
make: *** [nn_test.o] Error 1
The class I am using for traits is:
class Spatial_sorting_traits
public:
typedef Point3 Point_3;
Spatial_sorting_traits() {}
Spatial_sorting_traits(Spatial_sorting_traits &) {}
struct Less_x_3
bool operator()(const Point_3 &p1, const Point_3 &p2)
return p1.x() < p2.x();
struct Less_y_3
return p1.y() < p2.y();
struct Less_z_3
return p1.z() < p2.z();
Less_x_3 less_x_3_object() const
return Less_x_3();
Less_y_3 less_y_3_object() const
return Less_y_3();
Less_z_3 less_z_3_object() const
return Less_z_3();
I pass this into Hilbert_sort_3 as the Traits. I'm pretty sure that my
problem is the CGAL kernel. I don't know how to give my class the model for
a CGAL Kernel. Should I have Spatial_sorting_traits extend the Kernel I use
for my point (which is just a simple one I wrote for my point class)?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Hilbert-Sort-on-a-User-Defined-Point-tp2318793p2319878.html
- [cgal-discuss] Hilbert Sort on a User Defined Point, Derek Basehore, 08/09/2010
- Re: [cgal-discuss] Hilbert Sort on a User Defined Point, Sylvain Pion, 08/09/2010
- [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Derek, 08/09/2010
- Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Sylvain Pion, 08/09/2010
- [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Derek, 08/10/2010
- Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Sylvain Pion, 08/10/2010
- Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Andreas Fabri, 08/10/2010
