- To:
- Subject: Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point
- Date: Tue, 10 Aug 2010 16:53:38 +0200
Hi Derek,
here comes a self contained example.
andreas
#include <CGAL/spatial_sort.h>
struct MyPoint {
double x,y;
MyPoint()
: x(0), y(0)
MyPoint(double x, double y)
: x(x), y(y)
struct MyLessX {
bool operator()(const MyPoint& p, const MyPoint& q) const
return p.x < q.x;
struct MyLessY {
return p.y < q.y;
struct MySpatialSortingTraits {
typedef MyPoint Point_2;
typedef MyLessX Less_x_2;
typedef MyLessY Less_y_2;
Less_x_2 less_x_2_object() const
return Less_x_2();
Less_y_2 less_y_2_object() const
return Less_y_2();
int main()
MyPoint points[2];
points[0] = MyPoint(78,12);
points[1] = MyPoint(3,121);
MySpatialSortingTraits sst;
CGAL::spatial_sort(points, points+2, sst);
std::cerr << "done" << std::endl;
return 0;
- [cgal-discuss] Hilbert Sort on a User Defined Point, Derek Basehore, 08/09/2010
- Re: [cgal-discuss] Hilbert Sort on a User Defined Point, Sylvain Pion, 08/09/2010
- [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Derek, 08/09/2010
- Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Sylvain Pion, 08/09/2010
- [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Derek, 08/10/2010
- Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Sylvain Pion, 08/10/2010
- Re: [cgal-discuss] Re: Hilbert Sort on a User Defined Point, Andreas Fabri, 08/10/2010
