cgal-discuss - Re: [cgal-discuss] Precondition fail in intersection check
  • To:
  • Subject: Re: [cgal-discuss] Precondition fail in intersection check
  • Date: Thu, 12 Aug 2010 13:08:47 +0300
You should use exact predicates and exact constructions. After all you construct new points. I've tried it and wasn't able to reproduce (with an exact construction kernel). I get 2 intersections.
Quoting "Francesc Vila"
Hi,
I am doing an intersections check using CGAL::compute_intersection_points. I am using an exact predicates and inexact constructions kernel.
When I compute the intersections I receive an exception when is checking the precondition "comp_f(object, nodeP->object)" in CGAL::multiset. Could anyone explain why this exception is thrown?
In the comments it says that they are checking that the tree order is not violated, but I don't see why do those segments violate the order.
The contents of all the intersection segments is: (each line is a segment)
( 38029.437251200005, -91970.562748799988) ( 38029.437251200005, 38029.437251200005)
( 38029.437251200005, 38029.437251200005) (-128029.43725120000, 38029.437251200005)
(-128029.43725120000, 38029.437251200005) (-128029.43725119998, 21970.675886262117)
(-128029.43725119998, 21970.675886262117) ( 21970.562748800003, 21971.675886262114)
( 21970.562748800003, 21971.675886262114) ( 21970.562748799999, -108028.50010501972)
( 21970.562748799999, -108028.50010501972) ( 258029.43725120003, -108029.37439714751)
( 258029.43725120003, -108029.37439714751) ( 258029.43725120003, -91970.562748799988)
( 258029.43725120003, -91970.562748799988) ( 38029.437251200005, -91970.562748799988)
(-145000.00000000000, 5000.0000000000000) ( 275000.00000000000, 5000.0000000000000)
Thanks in advance,
Francesc Vila
