- To:
- Subject: [cgal-discuss] Precondition fail in intersection check
- Date: Wed, 11 Aug 2010 20:34:41 +0200
Hi,
I am doing an intersections check using CGAL::compute_intersection_points. I am using an exact predicates and inexact constructions kernel.
When I compute the intersections I receive an exception when is checking the precondition "comp_f(object, nodeP->object)" in CGAL::multiset. Could anyone explain why this exception is thrown?
In the comments it says that they are checking that the tree order is not violated, but I don't see why do those segments violate the order.
The contents of all the intersection segments is: (each line is a segment)
( 38029.437251200005, -91970.562748799988) ( 38029.437251200005,
38029.437251200005)
( 38029.437251200005, 38029.437251200005) (-128029.43725120000,
38029.437251200005)
(-128029.43725120000, 38029.437251200005) (-128029.43725119998,
21970.675886262117)
(-128029.43725119998, 21970.675886262117) ( 21970.562748800003,
21971.675886262114)
( 21970.562748800003, 21971.675886262114) ( 21970.562748799999,
-108028.50010501972)
( 21970.562748799999, -108028.50010501972) ( 258029.43725120003,
-108029.37439714751)
( 258029.43725120003, -108029.37439714751) ( 258029.43725120003,
( 258029.43725120003, -91970.562748799988) ( 38029.437251200005,
(-145000.00000000000, 5000.0000000000000) ( 275000.00000000000,
5000.0000000000000)
Thanks in advance,
Francesc Vila
- [cgal-discuss] Precondition fail in intersection check, Francesc Vila, 08/11/2010
- Re: [cgal-discuss] Precondition fail in intersection check, efif, 08/12/2010
- Re: [cgal-discuss] Precondition fail in intersection check, Francesc Vila, 08/12/2010
