- To:
- Subject: [cgal-discuss] Re: Error building examples
- Date: Thu, 12 Aug 2010 08:58:53 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Z8JT//VKzHqccpLAdxeJUmSuSEXFfJzJ6qLQUaGY8IDv/BnaLlul7HQAcguYhIO7JS IbhemrXUCTpnAP7iXoHaRZB2cvSV+7tVN/vl6erLpESlFqZ3bLHpvFTFYa+VmxY+lkgB 00rbndqZ+HGk21T+cm5NAZHq7FCCKPNHpKMUo=
Hi again,
Apparently, the error is due to the incorrect linking to the boost library, as can be seen below (appendix). I built boost 1.43.0 although it seems cmake only finds 1.34.1. The new version of boost seems to be in /usr/local/include and /usr/local/lib. I tried creating the environment variable (according to [1]):
BOOST_ROOT=/usr/local/
But it didn't work. Then I tried to be more specific:
BOOST_INCLUDEDIR=/usr/local/include
BOOST_LIBRARYDIR=/usr/local/lib
It didn't work either. Do I have to set the variables through cmake too?
Thanks,
Appendix:
-- CGAL_MAJOR_VERSION=3
-- CGAL_MINOR_VERSION=6
-- CGAL_BUILD_VERSION=
-- CGAL_SONAME_VERSION=5
-- CGAL_SOVERSION =5.0.0
-- CGAL_REFERENCE_CACHE_DIR=
-- Building shared libraries
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- USING CMake version: 2.4.7
-- System: Linux
-- USING GCC_VERSION = '4.2.4 (Ubuntu 4.2.4-1ubuntu4)'
-- Using gcc version 4 or later. Adding -frounding-math
-- Using gcc version 4.2. Adding -fno-strict-aliasing
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -fno-strict-aliasing -O3 -DNDEBUG'
-- USING LDFLAGS = ' '
-- GMPXX include: /usr/include
-- GMPXX libraries: /usr/lib/libgmpxx.so
-- GMP include: /usr/include
-- GMP libraries: /usr/lib/libgmp.so
-- GMP definitions:
-- USING GMP_VERSION = '4.2.2'
-- MPFR include: /usr/include
-- MPFR libraries: /usr/lib/libmpfr.so
-- MPFR definitions:
-- USING MPFR_VERSION = '2.3.1'
-- Boost include: /usr/include
-- Boost libraries: optimized;/usr/lib/libboost_thread-gcc42-mt-1_34_1.so;debug;/usr/lib/libboost_thread-gcc42-mt-d-1_34_1.so
-- Boost definitions:
-- USING BOOST_VERSION = '1.34.1'
-- CMAKE_INSTALL_PREFIX=/usr/local
-- OpenGL include: /usr/include
-- OpenGL libraries: /usr/lib/libGLU.so;/usr/lib/libGL.so;/usr/lib/libX11.so
-- USING ZLIB_VERSION = '1.2.3'
-- ZLib include: /usr/include
-- ZLib libraries: /usr/lib/libz.so
-- CGAL_Qt3 needs Qt3, cannot be configured.
-- CGAL_Qt4 needs Qt4, cannot be configured.
-- Configuring done
-- Generating done
On Wed, Aug 11, 2010 at 5:38 PM, Guilherme Kunigami <> wrote:
Hi all,I'm having problems running the examples in CGAL/examples.First I installed CGAL withcmake .makesudo make installEverything goes fine (except CGAL_Qt3 and CGAL_Qt4, but I think it doesn't matter).Then, to run an example, I try for example the AABB_tree directory.There I docmake .andmakeBut in this one I receive an error mesage:Scanning dependencies of target AABB_custom_example[ 12%] Building CXX object CMakeFiles/AABB_custom_example.dir/AABB_custom_example.oLinking CXX executable AABB_custom_example/usr/local/lib/libCGAL.so: undefined reference to `boost::detail::set_tss_data(void const*, boost::shared_ptr<boost::detail::tss_cleanup_function>, void*, bool)'collect2: ld returned 1 exit statusmake[2]: *** [AABB_custom_example] Error 1make[1]: *** [CMakeFiles/AABB_custom_example.dir/all] Error 2make: *** [all] Error 2It seems that the problem is with boost library, but it didn't showed errors when I was building/installing CGAL.Does anyone have a clue about this error?Thanks!--
Guilherme Kunigami
Guilherme Kunigami
- [cgal-discuss] Error building examples, Guilherme Kunigami, 08/11/2010
- [cgal-discuss] Re: Error building examples, Guilherme Kunigami, 08/12/2010
- Re: [cgal-discuss] Error building examples, Andres E. Prato, 08/18/2010
- Re: [cgal-discuss] Error building examples, Joachim Reichel, 08/18/2010
- [cgal-discuss] Error building examples Ubuntu Lucid Lynx, Andres E. Prato, 08/19/2010
- Re: [cgal-discuss] Error building examples Ubuntu Lucid Lynx, Joachim Reichel, 08/19/2010
