- To:
- Subject: [cgal-discuss] 3D mesh of an STL union
- Date: Thu, 12 Aug 2010 05:14:40 -0700 (PDT)
Greetings!
I wonder whether it is possible to construct a 3D volumetric mesh of a union
of 2 STL surface meshes with CGAL? I haven't found a direct way to create a
union of 2 STL surfaces.
My thinking is that since the manual says that 3D mesher reads in a domain
in a form of oracles (and I am just speculating here, because I am not sure
what an oracle is exactly), one can construct an oracle that describes a
union of several surface meshes and hence obtain a desired 3D mesh of this
union. Am I thinking along the correct lines here?
Cheers,
Yan
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-mesh-of-an-STL-union-tp2322606p2322606.html
- [cgal-discuss] 3D mesh of an STL union, Ianic, 08/12/2010
- Re: [cgal-discuss] 3D mesh of an STL union, Ramin H, 08/12/2010
- [cgal-discuss] Re: 3D mesh of an STL union, Ianic, 08/12/2010
