cgal-discuss - Re: [cgal-discuss] Error building examples Ubuntu Lucid Lynx
  • To:
  • Subject: Re: [cgal-discuss] Error building examples Ubuntu Lucid Lynx
  • Date: Thu, 19 Aug 2010 23:33:31 +0200
Hi Andres,
> Sorry for not starting a new tread. I Attached my system
> log... there is some things about memory, I got 1 GB of RAM, a T5500
> intel core 2 duo, and I got 3 GB of free space on my home directory....
> After the error appeared, I got some configuration problems on my
> Ubuntu-Gnome desktop, some Icons disappeared, and I had to restart
> everything....
you don't need that much disk space (maybe if want to build *all* examples).
Important is the RAM size (but you could setup a swap file/partition).
The examples inherit the compiler flags from the library. I think bulding in
debug mode needs less memory than optimized mode. Did you build the library in
optimized mode? You could try buildind the library in debug mode, or edit
CGALConfig.cmake after you built the library.
If you are using the .deb packages, the file CGALConfig.cmake is in
/usr/lib/CGAL.
Joachim
>> Andres E. Prato wrote:
>>> I have problemas with CGAL - examples.
>>> I am new and starting with CGAL, and I cant compile the examples, I did:
>> please don't reply to other thread if you have unrelated problems,
>> start a new
>> thread instead.
>>> cmake .
>>> When I do make:
>>> After a wile....
>>> Linking CXX executable mesh_global
>>> [ 38%] Built target mesh_global
>>> Scanning dependencies of target mesh_with_seeds
>>> [ 39%] Building CXX object
>>> Mesh_2/CMakeFiles/mesh_with_seeds.dir/mesh_with_seeds.o
>>> Linking CXX executable mesh_with_seeds
>>> [ 39%] Built target mesh_with_seeds
>>> Scanning dependencies of target mesh_3D_image
>>> Mesh_3/CMakeFiles/mesh_3D_image.dir/mesh_3D_image.o
>>> c++: Internal error: Terminado (killed) (program cc1plus)
>>> Please submit a full bug report.
>>> See<file:///usr/share/doc/gcc-4.4/README.Bugs> for instructions.
>>> make[2]: *** [Mesh_3/CMakeFiles/mesh_3D_image.dir/mesh_3D_image.o]
>>> Error 1
>>> make[1]: *** [Mesh_3/CMakeFiles/mesh_3D_image.dir/all] Error 2
>>> make: *** [all] Error 2
>> Your compiler process got killed. Maybe you don't have enough free
>> memory? Can
>> you check whether /var/log/syslog contains any messages about killed
>> processes?
>> Joachim
