cgal-discuss - [cgal-discuss] Bugs in Alpha_shape_2 computation
  • To:
  • Cc: "Sebastien Loriot (GeometryFactory)" <>
  • Subject: [cgal-discuss] Bugs in Alpha_shape_2 computation
  • Date: Wed, 11 Aug 2010 19:07:54 +0200
Hello Everybody,
I use the latest patched version of CGAL and I think some bugs could be present in the "Alpha_shape_2" class (all problems can be reproduced by using the list of points "fin" attached in this email).
First problem:
- First, I use the function "find_optimal_alpha" to find the best alpha to get 1 connected component.
- Second, I set this alpha.
- Third, I use the function "number_of_solid_components" to get the number of solid components of A.
- Fourth, I compute the alpha edges which I display on the screen.
When I do this last step, I get a "CGAL::Assertion_exception":
Reading 6 points from file
Alpha Shape computed
Optimal alpha: 380.5
Nb of solid components: 1
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: (classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR)
File: /appli/include/CGAL/Alpha_shape_2.h
Line: 1170
Aborted
Second problem:
- First, I compute the alpha shape with alpha=50.
- Second, I compute the alpha edges which I display on the screen.
With such a value of alpha I should get the convex hull of the points, but instead I get this result:
0 0 1 0
1 0 2.5 0
2.5 0 4.5 0
4.5 0 7 0
Attached, you can fine the c++ code (basically the same as in the example) and a list of points for which the program doesn't work as expected (both problems).
Thank you for your help,
Best Regards,
Ben_P
6
0 0
1 0
2.5 0
4.5 0
7 0
20 20
Takes a list of points and returns a list of segments corresponding to the
Alpha shape.
#include <CGAL/algorithm.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Alpha_shape_2.h>
#include <iostream>
#include <fstream>
#include <vector>
#include <list>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::FT FT;
typedef K::Point_2 Point;
typedef K::Segment_2 Segment;
typedef CGAL::Alpha_shape_vertex_base_2<K> Vb;
typedef CGAL::Alpha_shape_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<K,Tds> Triangulation_2;
typedef CGAL::Alpha_shape_2<Triangulation_2> Alpha_shape_2;
typedef Alpha_shape_2::Face Face;
typedef Alpha_shape_2::Vertex Vertex;
typedef Alpha_shape_2::Edge Edge;
typedef Alpha_shape_2::Face_handle Face_handle;
typedef Alpha_shape_2::Vertex_handle Vertex_handle;
typedef Alpha_shape_2::Face_circulator Face_circulator;
typedef Alpha_shape_2::Vertex_circulator Vertex_circulator;
typedef Alpha_shape_2::Locate_type Locate_type;
typedef Alpha_shape_2::Face_iterator Face_iterator;
typedef Alpha_shape_2::Vertex_iterator Vertex_iterator;
typedef Alpha_shape_2::Edge_iterator Edge_iterator;
typedef Alpha_shape_2::Edge_circulator Edge_circulator;
typedef Alpha_shape_2::Alpha_iterator Alpha_iterator;
typedef Alpha_shape_2::Alpha_shape_edges_iterator Alpha_shape_edges_iterator;
template <class OutputIterator>
void
alpha_edges( const Alpha_shape_2& A,
OutputIterator out)
for(Alpha_shape_edges_iterator it = A.alpha_shape_edges_begin();
it != A.alpha_shape_edges_end();
++it)
*out++ = A.segment(*it);
bool
file_input(OutputIterator out)
std::ifstream is("./fin", std::ios::in);
if(is.fail()){
std::cerr << "unable to open file for input" << std::endl;
return false;
int n;
is >> n;
std::cout << "Reading " << n << " points from file" << std::endl;
CGAL::copy_n(std::istream_iterator<Point>(is), n, out);
return true;
//------------------ main -------------------------------------------
int main()
std::list<Point> points;
if(! file_input(std::back_inserter(points)))
return -1;
Alpha_shape_2 A(points.begin(), points.end(),
FT(50),
Alpha_shape_2::GENERAL);
//std::cout << "Alpha Shape computed" << std::endl;
//Alpha_iterator optAlpha = A.find_optimal_alpha(1);
//std::cout << "Optimal alpha: " << *optAlpha<<std::endl;
//A.set_alpha(*optAlpha);
//std::cout<<"Nb of solid components:
"<<A.number_of_solid_components()<<std::endl;
std::vector<Segment> segments;
alpha_edges( A, std::back_inserter(segments));
//Print segments:
std::vector<Segment>::iterator itPrint = segments.begin();
while (itPrint!=segments.end())
std::cout<<*itPrint<<std::endl;
itPrint++;
return 0;
