- To:
- Subject: Re: [cgal-discuss] Bugs in Alpha_shape_2 computation
- Date: Tue, 17 Aug 2010 01:46:51 +0200
I have just tried to execute the program using CGAL 3.6.1 without the patch you sent and I don't get the "CGAL::Assertion_exception".
To install the patch, I copied the new "Alpha_shape_2.h" file to include/CGAL and did make, make install.
Did I do something wrong ?
Thank you for your help,
Best Regards,
Ben_P
Le 16 août 10 à 22:24, Benoît Presles a écrit :
Benoît Presles wrote:
I do not have any problem on my machine with the same CGAL and theI redid the test and here is the result:Dear Sébastien,When I put this line in your code
I did more tests using the function you provided me and I really think that a problem could be present in the "Alpha_shape_2" class.
First program:
- I compute the alpha shape (GENERAL) with the optimal alpha value found with the function "find_optimal_alpha(1)".
- I display on the screen all the edges (interior, exterior, singular, regular) using the function you sent.
- I display on the screen all the singular and regular edges using alpha_shape_edges.
First test (data file "fin"):
Here is the error I get:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: ((classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR) || (classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == SINGULAR))
File: /usr/local/include/CGAL/Alpha_shape_2.h
Line: 1189
Aborted
A.set_alpha(*optAlpha);
I have one solid component but no assertion.
Source file: alphaShape.cpp with A.set_alpha(*optAlpha)
Data file: fin
Configuration: Ubuntu 10.04 LTS with CGAL 3.6.1 installed from sources and patched with the file you sent.
Compilation line: g++ -frounding-math -I/usr/local/include -L/usr/ local/lib -lCGAL alphaShape.cpp
Execution: ./a.out
Output:
Reading 6 points from file
Alpha Shape computed
Optimal alpha: 2
Nb of solid components: 1
REGULAR:
INTERIOR:
REGULAR:
INTERIOR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
EIRS 0 5 5 0
0 2 2 2
1 1 0 2
0 2 0 0
0 0 1 1
2 2 4 0
4 0 2 0
1 1 2 2
2 0 2 2
1 1 2 0
2 0 0 0
Line: 1189
Aborted
I also redid the test and here is the result:
Second test (data file "fin2"):with A.set_alpha(*optAlpha);
The function you sent classify for example the segment (0.3,0.1)- (0.1,0.1) as regular (which is ok) but the function alpha_shape_edges doesn't display it which is an error I think.
I have EIRS 1 10 13 1 and 14 edges of the alpha-shape are printed
(which are the correct one)
Data file: fin2
Execution: ./a.out
Output:
Reading 13 points from file
Optimal alpha: 0.01
REGULAR:
INTERIOR:
REGULAR:
REGULAR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
REGULAR:
REGULAR:
SINGULAR:
REGULAR:
EXTERIOR:
REGULAR:
INTERIOR:
INTERIOR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
INTERIOR:
REGULAR:
EIRS 1 10 13 1
0.1 0 0 0
0.1 0.1 0 0
0.1 0 0.1 0.1
0 0.1 0 0.2
0 0 0 0.1
0.4 0 0.3 0
0.1 0.1 0 0.1
0.1 0.2 0 0.1
0.1 0.1 0.1 0.2
0.1 0.2 0.2 0.2
0.1 0.2 0 0.2
0.3 0.2 0.4 0.2
0.3 0 0.1 0
0.2 0.2 0.3 0.2
0.1 0 0.3 0.1
0.3 0.1 0.1 0.1
0.1 0.1 0.2 0.2
0.3 0.1 0.2 0.2
0.4 0.2 0.4 0.1
0.3 0.2 0.4 0.1
0.3 0.1 0.4 0.1
0.3 0.2 0.3 0.1
0.4 0.1 0.4 0
0.3 0.1 0.4 0
0.3 0.1 0.3 0
0.3 0.2 0.2 0.2
0 0 0.1 0
0 0.2 0 0.1
0 0.1 0 0
0.2 0.2 0.1 0.2
0.1 0.2 0 0.2
0.1 0 0.1 0.1
0.4 0.1 0.4 0.2
0.4 0 0.4 0.1
0.3 0.1 0.3 0
0.4 0.2 0.3 0.2
0.3 0 0.4 0
I get the same classification as you (I guess) but only 12 edges of the alpha-shape are printed.
patched file. Do you have the same problem with
Exact_predicates_exact_constructions_kernel ?
I did both tests with "Exact_predicates_exact_constructions_kernel" and here are the results.
First test:
Optimal alpha: 2
REGULAR:
INTERIOR:
REGULAR:
INTERIOR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
EIRS 0 5 5 0
0 2 2 2
1 1 0 2
0 2 0 0
0 0 1 1
2 2 4 0
4 0 2 0
1 1 2 2
2 0 2 2
1 1 2 0
2 0 0 0
Line: 1189
Aborted
Second test:
Optimal alpha: 0.0125
REGULAR:
INTERIOR:
INTERIOR:
REGULAR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
REGULAR:
REGULAR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
INTERIOR:
INTERIOR:
EIRS 0 14 11 0
0.1 0 0 0
0.1 0.1 0 0
0.1 0 0.1 0.1
0 0.1 0 0.2
0 0 0 0.1
0.4 0 0.3 0
0.1 0.1 0 0.1
0.1 0.2 0 0.1
0.1 0.1 0.1 0.2
0.1 0.2 0.2 0.2
0.1 0.2 0 0.2
0.3 0.2 0.4 0.2
0.3 0 0.1 0
0.2 0.2 0.3 0.2
0.1 0 0.3 0.1
0.3 0.1 0.1 0.1
0.1 0.1 0.2 0.2
0.3 0.1 0.2 0.2
0.4 0.2 0.4 0.1
0.3 0.2 0.4 0.1
0.3 0.1 0.4 0.1
0.3 0.2 0.3 0.1
0.4 0.1 0.4 0
0.3 0.1 0.4 0
0.3 0.1 0.3 0
Line: 1189
Aborted
The result of the second test is different (not the same classification) but I still get the "Assertion_exception" in both cases.
Do I need to install a specific version of Boost, GMP or MPFR ?
Yes, what I wrote before:Source file: alphaShape.cpp with A.set_alpha(FT(0.0026))Second program (data file "fin2"):
- I compute the alpha shape (GENERAL) with alpha=0.0026.
I get some exterior edges like (0.1,0.1)-(0,0) but I think with such a value of alpha, this edge should be interior.
(0.1 x 0.1 + 0.1 x 0.1)/2 = 0.01
and 0.01 > 0.0026
So I see no reason why this edge should be interior.
Data file: fin2
With such a value of alpha, I think the alpha-shape edges should be the blue edges in the image "alphaShapeFin2alpha=0.0026.jpg". So the edge (0.1,0.1)-(0,0) should be interior. Do I miss something ?
the squared distance between points (0.1,0.1) and (0,0) is
0.02
You set alpha to a value which is less than the half of the squared
distance, so the edge CANNOT be in the alpha complex.
Please re-read the documentation and the reference provided for more information
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_2/Chapter_main.html
You are right. I am sorry, it is my mistake.
Thank you very much for your help,
Best Regards,
Ben_P
S.
Best Regards,
Ben_P
Le 12 août 10 à 09:01, Sebastien Loriot (GeometryFactory) a écrit :If I remember correctly, the range
[alpha_shape_edges_begin,_end] is over regular edges in Regularized mode,
and singular and regular edges in general mode (it gives you the alpha-shape which is the boundary of the alpha-complex)
So interior edges are not displayed.
You this function so get the classifications:
void
alpha_edges( const Alpha_shape_2& A)
int r=0,s=0,i=0,e=0;
for(Alpha_shape_2::Finite_edges_iterator it = A.finite_edges_begin();
it != A.finite_edges_end();
++it)
switch ( A.classify(*it) )
case Alpha_shape_2::REGULAR: ++r; break;
case Alpha_shape_2::SINGULAR: ++s; break;
case Alpha_shape_2::EXTERIOR: ++e; break;
case Alpha_shape_2::INTERIOR: ++i; break;
std::cout << "EIRS " << e << " " << i << " "<< r << " " << s << std::endl;
S.
Hello Everybody,
In my last email, I submitted you 2 problems I had with the "Alpha_shape_2" class. I still have the first problem but after some tests I realised that the results I obtained about the second problem were OK.
However, I still get some wrong results for some list of points (cf. attached file):
First test:
- I compute the alpha shape (GENERAL) with the optimal alpha value found with the function "find_optimal_alpha(1)" and I display on the screen the alpha edges. With such a value of alpha I should get a closed boundary, but instead I get this result:
Optimal alpha: 0.01
0.3 0.2 0.2 0.2
0 0 0.1 0
0 0.2 0 0.1
0 0.1 0 0
0.2 0.2 0.1 0.2
0.1 0.2 0 0.2
0.1 0 0.1 0.1
0.4 0.1 0.4 0.2
0.4 0 0.4 0.1
0.3 0.1 0.3 0
0.4 0.2 0.3 0.2
0.3 0 0.4 0
Second test:
- I compute the alpha shape (GENERAL) with alpha=0.0025 and I display on the screen the alpha edges. With such a value of alpha I should get much more edges but instead I get this result:
Optimal alpha: 0.01
Nb of solid components: 0
0.3 0.2 0.2 0.2
Third test:
- I compute the alpha shape (GENERAL) with alpha=0.0026 and I display on the screen the alpha edges. With such a value of alpha I get too much edges:
Optimal alpha: 0.01
0.3 0.2 0.2 0.2
0.3 0.1 0.3 0.2
0 0 0.1 0
0 0.2 0 0.1
0 0.1 0 0
0.2 0.2 0.1 0.2
0.1 0.2 0 0.2
0.1 0.1 0 0.1
0.1 0.1 0.1 0.2
0.1 0 0.1 0.1
0.4 0.1 0.4 0.2
0.4 0 0.4 0.1
0.3 0.1 0.3 0
0.4 0.2 0.3 0.2
0.4 0.1 0.3 0.1
0.3 0 0.4 0
Best Regards,
Ben_P
Le 11 août 10 à 19:07, Benoît Presles a écrit :
Hello Everybody,
I use the latest patched version of CGAL and I think some bugs could be present in the "Alpha_shape_2" class (all problems can be reproduced by using the list of points "fin" attached in this email).
First problem:
- First, I use the function "find_optimal_alpha" to find the best alpha to get 1 connected component.
- Second, I set this alpha.
- Third, I use the function "number_of_solid_components" to get the number of solid components of A.
- Fourth, I compute the alpha edges which I display on the screen.
When I do this last step, I get a "CGAL::Assertion_exception":
Optimal alpha: 380.5
Expr: (classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR)
File: /appli/include/CGAL/Alpha_shape_2.h
Line: 1170
Aborted
Second problem:
- First, I compute the alpha shape with alpha=50.
- Second, I compute the alpha edges which I display on the screen.
With such a value of alpha I should get the convex hull of the points, but instead I get this result:
0 0 1 0
1 0 2.5 0
2.5 0 4.5 0
4.5 0 7 0
Attached, you can fine the c++ code (basically the same as in the example) and a list of points for which the program doesn't work as expected (both problems).
Best Regards,
Ben_P
<fin.txt><alphaShape.cpp>
<alphaShape.cpp><fin><fin2>
- [cgal-discuss] Bugs in Alpha_shape_2 computation, Benoît Presles, 08/11/2010
- Re: [cgal-discuss] Bugs in Alpha_shape_2 computation, Benoît Presles, 08/12/2010
- Re: [cgal-discuss] Bugs in Alpha_shape_2 computation, Sebastien Loriot (GeometryFactory), 08/12/2010
- Re: [cgal-discuss] Bugs in Alpha_shape_2 computation, Sebastien Loriot (GeometryFactory), 08/13/2010
- Re: [cgal-discuss] Bugs in Alpha_shape_2 computation, Benoît Presles, 08/13/2010
- Re: [cgal-discuss] Bugs in Alpha_shape_2 computation, Sebastien Loriot (GeometryFactory), 08/16/2010
- Re: [cgal-discuss] Bugs in Alpha_shape_2 computation, Benoît Presles, 08/16/2010
- Re: [cgal-discuss] Bugs in Alpha_shape_2 computation, Benoît Presles, 08/17/2010
- Re: [cgal-discuss] Bugs in Alpha_shape_2 computation, Sebastien Loriot (GeometryFactory), 08/17/2010
- Re: [cgal-discuss] Bugs in Alpha_shape_2 computation, Benoît Presles, 08/18/2010
