cgal-discuss - Re: [cgal-discuss] Bugs in Alpha_shape_2 computation
  • To:
  • Subject: Re: [cgal-discuss] Bugs in Alpha_shape_2 computation
  • Date: Wed, 18 Aug 2010 00:55:11 +0200
Benoît Presles wrote:
I have just tried to execute the program using CGAL 3.6.1 without the patch you sent and I don't get the "CGAL::Assertion_exception".
To install the patch, I copied the new "Alpha_shape_2.h" file to include/CGAL and did make, make install.
Did I do something wrong ?
You do not need to do make and make install, just replace the file.
I did find the problem. Try with the patched file attached.
I did lots of tests today and everything seems OK.
Thank you very much for your help,
Best Regards,
Ben_P
Best,
S.
Thank you for your help,
Best Regards,
Ben_P
Dear Sébastien,
I did more tests using the function you provided me and I really think that a problem could be present in the "Alpha_shape_2" class.
First program:
- I compute the alpha shape (GENERAL) with the optimal alpha value found with the function "find_optimal_alpha(1)".
- I display on the screen all the edges (interior, exterior, singular, regular) using the function you sent.
- I display on the screen all the singular and regular edges using alpha_shape_edges.
First test (data file "fin"):
Here is the error I get:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: ((classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR) || (classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == SINGULAR))
File: /usr/local/include/CGAL/Alpha_shape_2.h
Line: 1189
Aborted
When I put this line in your code
A.set_alpha(*optAlpha);
I have one solid component but no assertion.
I redid the test and here is the result:
Source file: alphaShape.cpp with A.set_alpha(*optAlpha)
Data file: fin
Configuration: Ubuntu 10.04 LTS with CGAL 3.6.1 installed from sources and patched with the file you sent.
Compilation line: g++ -frounding-math -I/usr/local/include -L/ usr/local/lib -lCGAL alphaShape.cpp
Execution: ./a.out
Output:
Reading 6 points from file
Alpha Shape computed
Optimal alpha: 2
Nb of solid components: 1
REGULAR:
INTERIOR:
REGULAR:
INTERIOR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
EIRS 0 5 5 0
0 2 2 2
1 1 0 2
0 2 0 0
0 0 1 1
2 2 4 0
4 0 2 0
1 1 2 2
2 0 2 2
1 1 2 0
2 0 0 0
Line: 1189
Aborted
Second test (data file "fin2"):
The function you sent classify for example the segment (0.3,0.1)-(0.1,0.1) as regular (which is ok) but the function alpha_shape_edges doesn't display it which is an error I think.
with A.set_alpha(*optAlpha);
I have EIRS 1 10 13 1 and 14 edges of the alpha-shape are printed
(which are the correct one)
I also redid the test and here is the result:
Data file: fin2
Execution: ./a.out
Output:
Reading 13 points from file
Optimal alpha: 0.01
REGULAR:
INTERIOR:
REGULAR:
REGULAR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
REGULAR:
REGULAR:
SINGULAR:
REGULAR:
EXTERIOR:
REGULAR:
INTERIOR:
INTERIOR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
INTERIOR:
REGULAR:
EIRS 1 10 13 1
0.1 0 0 0
0.1 0.1 0 0
0.1 0 0.1 0.1
0 0.1 0 0.2
0 0 0 0.1
0.4 0 0.3 0
0.1 0.1 0 0.1
0.1 0.2 0 0.1
0.1 0.1 0.1 0.2
0.1 0.2 0.2 0.2
0.1 0.2 0 0.2
0.3 0.2 0.4 0.2
0.3 0 0.1 0
0.2 0.2 0.3 0.2
0.1 0 0.3 0.1
0.3 0.1 0.1 0.1
0.1 0.1 0.2 0.2
0.3 0.1 0.2 0.2
0.4 0.2 0.4 0.1
0.3 0.2 0.4 0.1
0.3 0.1 0.4 0.1
0.3 0.2 0.3 0.1
0.4 0.1 0.4 0
0.3 0.1 0.4 0
0.3 0.1 0.3 0
0.3 0.2 0.2 0.2
0 0 0.1 0
0 0.2 0 0.1
0 0.1 0 0
0.2 0.2 0.1 0.2
0.1 0.2 0 0.2
0.1 0 0.1 0.1
0.4 0.1 0.4 0.2
0.4 0 0.4 0.1
0.3 0.1 0.3 0
0.4 0.2 0.3 0.2
0.3 0 0.4 0
I get the same classification as you (I guess) but only 12 edges of the alpha-shape are printed.
I do not have any problem on my machine with the same CGAL and the
patched file. Do you have the same problem with
Exact_predicates_exact_constructions_kernel ?
I did both tests with "Exact_predicates_exact_constructions_kernel" and here are the results.
First test:
Optimal alpha: 2
REGULAR:
INTERIOR:
REGULAR:
INTERIOR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
EIRS 0 5 5 0
0 2 2 2
1 1 0 2
0 2 0 0
0 0 1 1
2 2 4 0
4 0 2 0
1 1 2 2
2 0 2 2
1 1 2 0
2 0 0 0
Line: 1189
Aborted
Second test:
Optimal alpha: 0.0125
REGULAR:
INTERIOR:
INTERIOR:
REGULAR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
REGULAR:
REGULAR:
REGULAR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
INTERIOR:
INTERIOR:
INTERIOR:
REGULAR:
INTERIOR:
INTERIOR:
EIRS 0 14 11 0
0.1 0 0 0
0.1 0.1 0 0
0.1 0 0.1 0.1
0 0.1 0 0.2
0 0 0 0.1
0.4 0 0.3 0
0.1 0.1 0 0.1
0.1 0.2 0 0.1
0.1 0.1 0.1 0.2
0.1 0.2 0.2 0.2
0.1 0.2 0 0.2
0.3 0.2 0.4 0.2
0.3 0 0.1 0
0.2 0.2 0.3 0.2
0.1 0 0.3 0.1
0.3 0.1 0.1 0.1
0.1 0.1 0.2 0.2
0.3 0.1 0.2 0.2
0.4 0.2 0.4 0.1
0.3 0.2 0.4 0.1
0.3 0.1 0.4 0.1
0.3 0.2 0.3 0.1
0.4 0.1 0.4 0
0.3 0.1 0.4 0
0.3 0.1 0.3 0
Line: 1189
Aborted
The result of the second test is different (not the same classification) but I still get the "Assertion_exception" in both cases.
Do I need to install a specific version of Boost, GMP or MPFR ?
Second program (data file "fin2"):
- I compute the alpha shape (GENERAL) with alpha=0.0026.
I get some exterior edges like (0.1,0.1)-(0,0) but I think with such a value of alpha, this edge should be interior.
(0.1 x 0.1 + 0.1 x 0.1)/2 = 0.01
and 0.01 > 0.0026
So I see no reason why this edge should be interior.
Source file: alphaShape.cpp with A.set_alpha(FT(0.0026))
Data file: fin2
With such a value of alpha, I think the alpha-shape edges should be the blue edges in the image "alphaShapeFin2alpha=0.0026.jpg". So the edge (0.1,0.1)-(0,0) should be interior. Do I miss something ?
Yes, what I wrote before:
the squared distance between points (0.1,0.1) and (0,0) is
0.02
You set alpha to a value which is less than the half of the squared
distance, so the edge CANNOT be in the alpha complex.
Please re-read the documentation and the reference provided for more information
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_2/Chapter_main.html
You are right. I am sorry, it is my mistake.
Best Regards,
Ben_P
S.
Best Regards,
Ben_P
Le 12 août 10 à 09:01, Sebastien Loriot (GeometryFactory) a écrit :
If I remember correctly, the range
[alpha_shape_edges_begin,_end] is over regular edges in Regularized mode,
and singular and regular edges in general mode (it gives you the alpha-shape which is the boundary of the alpha-complex)
So interior edges are not displayed.
You this function so get the classifications:
void
alpha_edges( const Alpha_shape_2& A)
int r=0,s=0,i=0,e=0;
for(Alpha_shape_2::Finite_edges_iterator it = A.finite_edges_begin();
it != A.finite_edges_end();
++it)
switch ( A.classify(*it) )
case Alpha_shape_2::REGULAR: ++r; break;
case Alpha_shape_2::SINGULAR: ++s; break;
case Alpha_shape_2::EXTERIOR: ++e; break;
case Alpha_shape_2::INTERIOR: ++i; break;
std::cout << "EIRS " << e << " " << i << " "<< r << " " << s << std::endl;
S.
Hello Everybody,
In my last email, I submitted you 2 problems I had with the "Alpha_shape_2" class. I still have the first problem but after some tests I realised that the results I obtained about the second problem were OK.
However, I still get some wrong results for some list of points (cf. attached file):
First test:
- I compute the alpha shape (GENERAL) with the optimal alpha value found with the function "find_optimal_alpha(1)" and I display on the screen the alpha edges. With such a value of alpha I should get a closed boundary, but instead I get this result:
Optimal alpha: 0.01
0.3 0.2 0.2 0.2
0 0 0.1 0
0 0.2 0 0.1
0 0.1 0 0
0.2 0.2 0.1 0.2
0.1 0.2 0 0.2
0.1 0 0.1 0.1
0.4 0.1 0.4 0.2
0.4 0 0.4 0.1
0.3 0.1 0.3 0
0.4 0.2 0.3 0.2
0.3 0 0.4 0
Second test:
- I compute the alpha shape (GENERAL) with alpha=0.0025 and I display on the screen the alpha edges. With such a value of alpha I should get much more edges but instead I get this result:
Optimal alpha: 0.01
Nb of solid components: 0
0.3 0.2 0.2 0.2
Third test:
- I compute the alpha shape (GENERAL) with alpha=0.0026 and I display on the screen the alpha edges. With such a value of alpha I get too much edges:
Optimal alpha: 0.01
0.3 0.2 0.2 0.2
0.3 0.1 0.3 0.2
0 0 0.1 0
0 0.2 0 0.1
0 0.1 0 0
0.2 0.2 0.1 0.2
0.1 0.2 0 0.2
0.1 0.1 0 0.1
0.1 0.1 0.1 0.2
0.1 0 0.1 0.1
0.4 0.1 0.4 0.2
0.4 0 0.4 0.1
0.3 0.1 0.3 0
0.4 0.2 0.3 0.2
0.4 0.1 0.3 0.1
0.3 0 0.4 0
Best Regards,
Ben_P
Le 11 août 10 à 19:07, Benoît Presles a écrit :
Hello Everybody,
I use the latest patched version of CGAL and I think some bugs could be present in the "Alpha_shape_2" class (all problems can be reproduced by using the list of points "fin" attached in this email).
First problem:
- First, I use the function "find_optimal_alpha" to find the best alpha to get 1 connected component.
- Second, I set this alpha.
- Third, I use the function "number_of_solid_components" to get the number of solid components of A.
- Fourth, I compute the alpha edges which I display on the screen.
When I do this last step, I get a "CGAL::Assertion_exception":
Optimal alpha: 380.5
Expr: (classify((*edge_alpha_it).second.first, (*edge_alpha_it).second.second) == REGULAR)
File: /appli/include/CGAL/Alpha_shape_2.h
Line: 1170
Aborted
Second problem:
- First, I compute the alpha shape with alpha=50.
- Second, I compute the alpha edges which I display on the screen.
With such a value of alpha I should get the convex hull of the points, but instead I get this result:
0 0 1 0
1 0 2.5 0
2.5 0 4.5 0
4.5 0 7 0
Attached, you can fine the c++ code (basically the same as in the example) and a list of points for which the program doesn't work as expected (both problems).
Best Regards,
Ben_P
<fin.txt><alphaShape.cpp>
<alphaShape.cpp><fin><fin2>
// Copyright (c) 1997 INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL: svn+ssh:///svn/cgal/branches/ CGAL-3.6-branch/Alpha_shapes_2/include/CGAL/Alpha_shape_2.h $
// $Id: Alpha_shape_2.h 47026 2008-11-25 13:21:09Z afabri $
// Author(s) : Tran Kai Frank DA
// Andreas Fabri
#ifndef CGAL_ALPHA_SHAPE_2_H
#define CGAL_ALPHA_SHAPE_2_H
#include <CGAL/basic.h>
#include <list>
#include <set>
#include <map>
#include <vector>
#include <algorithm>
#include <utility>
#include <iostream>
#include <CGAL/utility.h>
#include <CGAL/Unique_hash_map.h>
#include <CGAL/Triangulation_vertex_base_2.h>
#include <CGAL/Triangulation_face_base_2.h>
#include <CGAL/Alpha_shape_vertex_base_2.h>
#include <CGAL/Alpha_shape_face_base_2.h>
CGAL_BEGIN_NAMESPACE
template < class Dt >
class Alpha_shape_2 : public Dt
// DEFINITION The class Alpha_shape_2<Dt> represents the family
// of alpha-shapes of points in a plane for all positive alpha. It
// maintains the underlying Delaunay triangulation which represents
// connectivity and order among its faces. Each k-dimensional face of the
// Delaunay triangulation is associated with an interval that specifies
// for which values of alpha the face belongs to the alpha-shape (sorted
// linear arrays resp. multimaps or interval trees). There are links
// between the intervals and the k-dimensional faces of the Delaunay
// triangulation (multimaps resp. std::hashtables).
//------------------------- TYPES ------------------------------------
public:
typedef typename Dt::Geom_traits Gt;
typedef typename Dt::Triangulation_data_structure Tds;
typedef typename Gt::FT Coord_type;
typedef typename Gt::FT NT;
typedef typename Gt::FT FT;
typedef typename Gt::Point_2 Point;
typedef typename Gt::Segment_2 Segment;
typedef typename Gt::Ray_2 Ray;
typedef typename Gt::Line_2 Line;
typedef typename Dt::Face_handle Face_handle;
typedef typename Dt::Vertex_handle Vertex_handle;
typedef typename Dt::Edge Edge;
typedef typename Dt::Face_circulator Face_circulator;
typedef typename Dt::Edge_circulator Edge_circulator;
typedef typename Dt::Vertex_circulator Vertex_circulator;
typedef typename Dt::Finite_faces_iterator Finite_faces_iterator;
typedef typename Dt::Edge_iterator Edge_iterator;
typedef typename Dt::Finite_vertices_iterator Finite_vertices_iterator;
typedef typename Dt::Locate_type Locate_type;
using Dt::finite_vertices_begin;
using Dt::finite_vertices_end;
using Dt::faces_begin;
using Dt::faces_end;
using Dt::edges_begin;
using Dt::edges_end;
using Dt::number_of_vertices;
using Dt::cw;
using Dt::ccw;
using Dt::VERTEX;
using Dt::EDGE;
using Dt::FACE;
using Dt::OUTSIDE_CONVEX_HULL;
using Dt::OUTSIDE_AFFINE_HULL;
using Dt::dimension;
// for backward compatibility
typedef Finite_vertices_iterator Vertex_iterator;
typedef Finite_faces_iterator Face_iterator;
private:
typedef std::multimap< Coord_type, Face_handle > Interval_face_map;
typedef typename Interval_face_map::value_type Interval_face;
typedef typename Tds::Face::Interval_3 Interval3;
typedef std::multimap< Interval3, Edge > Interval_edge_map;
typedef typename Interval_edge_map::value_type Interval_edge;
typedef std::pair< Coord_type, Coord_type > Interval2;
typedef std::multimap< Interval2, Vertex_handle > Interval_vertex_map;
typedef typename Interval_vertex_map::value_type Interval_vertex;
typedef Face_handle const const_void;
typedef std::pair<const_void, int> const_Edge;
typedef std::vector< Coord_type > Alpha_spectrum;
typedef std::vector< Segment > Vect_seg;
typedef Unique_hash_map< Face_handle, bool > Marked_face_set;
public:
typedef typename std::list< Vertex_handle >::iterator
Alpha_shape_vertices_iterator;
typedef typename std::list< Edge >::iterator Alpha_shape_edges_iterator;
typedef typename Alpha_spectrum::const_iterator Alpha_iterator;
// An iterator that allow to traverse the sorted sequence of
// different alpha-values. The iterator is bidirectional and
// non-mutable. Its value-type is Coord_type
enum Classification_type {EXTERIOR, SINGULAR, REGULAR, INTERIOR};
// Distinguishes the different cases for classifying a
// k-dimensional face of the underlying Delaunay triangulation of
// the alpha-shape.
// `EXTERIOR' if the face does not belong to the alpha-complex.
// `SINGULAR' if the face belongs to the boundary of the
// alpha-shape, but is not incident to any higher-dimensional
// face of the alpha-complex
// `REGULAR' if face belongs to the boundary of the alpha-shape
// and is incident to a higher-dimensional face of the
// alpha-complex
// `INTERIOR' if the face belongs to the alpha-complex, but does
// not belong to the boundary of the alpha-shape
enum Mode {GENERAL, REGULARIZED};
// In general, an alpha shape is a non-connected, mixed-dimension
// polygon. Its regularized version is formed by the set of
// regular edges and their vertices
//------------------------ private VARIABLES -------------------------
private:
// only finite edges and faces are inserted into the maps
Interval_face_map _interval_face_map;
Interval_edge_map _interval_edge_map;
Interval_vertex_map _interval_vertex_map;
Alpha_spectrum _alpha_spectrum;
Coord_type _alpha;
Mode _mode;
// should be constants
Coord_type Infinity;
Coord_type UNDEFINED;
mutable std::list< Vertex_handle > Alpha_shape_vertices_list;
mutable std::list< Edge > Alpha_shape_edges_list;
mutable bool use_vertex_cache;
mutable bool use_edge_cache;
public:
//------------------------- CONSTRUCTORS ------------------------------
// Introduces an empty alpha-shape `A' for a positive
// alpha-value `alpha'. Precondition: `alpha' >= 0.
Alpha_shape_2(Coord_type alpha = Coord_type(0),
Mode m = GENERAL)
: _alpha(alpha), _mode(m), Infinity(-1), UNDEFINED(-2),
use_vertex_cache(false), use_edge_cache(false)
// Introduces an alpha-shape `A' for a positive alpha-value
// `alpha' that is initialized with the points in the range
// from first to last
template <class InputIterator>
Alpha_shape_2(const InputIterator& first,
const InputIterator& last,
const Coord_type& alpha = Coord_type(0),
Mode m = GENERAL)
: _alpha(alpha), _mode(m), Infinity(-1), UNDEFINED(-2) ,
Dt::insert(first, last);
if (dimension() == 2)
// Compute the associated _interval_face_map
initialize_interval_face_map();
// Compute the associated _interval_edge_map
initialize_interval_edge_map();
// Compute the associated _interval_vertex_map
initialize_interval_vertex_map();
// merge the two maps
initialize_alpha_spectrum();
public:
//----------- OUTPUT POINTS CONNECTED BY PAIRS ----------------------
std::list<Point> Output();
std::ostream& op_ostream(std::ostream& os) const;
//----------------------- OPERATIONS ---------------------------------
template < class InputIterator >
int make_alpha_shape(const InputIterator& first,
const InputIterator& last)
clear();
int n = Dt::insert(first, last);
return n;
private :
//--------------------- INITIALIZATION OF PRIVATE MEMBERS -----------
void initialize_interval_face_map();
void initialize_interval_edge_map();
void initialize_interval_vertex_map();
void initialize_alpha_spectrum();
public:
void clear()
// clears the structure
Dt::clear();
_interval_face_map.clear();
_interval_edge_map.clear();
_interval_vertex_map.clear();
_alpha_spectrum.clear();
Alpha_shape_vertices_list.clear();
Alpha_shape_edges_list.clear();
set_alpha(Coord_type(0));
set_mode(GENERAL);
//----------------------- PRIVATE MEMBERS --------------------------
private:
struct Less
bool operator()(const Interval_edge& ie,
const Coord_type& alpha)
return ie.first.first < alpha;
bool operator()( const Coord_type& alpha,
const Interval_edge& ie)
return alpha < ie.first.first;
// Needed for STL implementations of upper_bound which in debug mode
// check sortedness of range
const Interval_edge& ie2) const
return ie < ie2;
//----------------------- ACCESS TO PRIVATE MEMBERS -----------------
private:
Coord_type find_interval(const Face_handle& f) const
return f->get_alpha();
// return the value Alpha f the face f
Interval3 find_interval(const_Edge e) const
{ // corriger le parametrage
return (e.first)->get_ranges(e.second);
// return the Interval3 for the edge n
public:
Coord_type set_alpha(const Coord_type& alpha)
// Sets the alpha-value to `alpha'. Precondition: `alpha' >= 0.
// Returns the previous alpha
Coord_type previous_alpha = _alpha;
_alpha = alpha;
use_vertex_cache = false;
use_edge_cache = false;
return previous_alpha;
const Coord_type& get_alpha() const
// Returns the current alpha-value.
return _alpha;
const Coord_type& get_nth_alpha(int n) const
// Returns the n-th alpha-value.
// n < size()
if (! _alpha_spectrum.empty())
return _alpha_spectrum[n];
else
return UNDEFINED;
int number_of_alphas() const
// Returns the number of not necessary different alpha-values
return _alpha_spectrum.size();
private:
// the dynamic version is not yet implemented
// desactivate the triangulation member functions
Vertex_handle insert(const Point& p);
// Inserts point `p' in the alpha shape and returns the
// corresponding vertex of the underlying Delaunay triangulation.
// If point `p' coincides with an already existing vertex, this
// vertex is returned and the alpha shape remains unchanged.
// Otherwise, the vertex is inserted in the underlying Delaunay
// triangulation and the associated intervals are updated.
void remove(Vertex_handle v);
// Removes the vertex from the underlying Delaunay triangulation.
// The created hole is retriangulated and the associated intervals
// are updated.
public:
Mode set_mode(Mode mode = GENERAL )
// Sets `A' to its general or regularized version. Returns the
// previous mode.
Mode previous_mode = _mode;
_mode = mode;
return previous_mode;
Mode get_mode() const
// Returns whether `A' is general or regularized.
return _mode;
private:
void
update_alpha_shape_vertex_list()const;
void
update_alpha_shape_edges_list() const;
public:
Alpha_shape_vertices_iterator alpha_shape_vertices_begin() const
if(!use_vertex_cache){
update_alpha_shape_vertex_list();
return Alpha_shape_vertices_list.begin();
Alpha_shape_vertices_iterator Alpha_shape_vertices_begin()
return alpha_shape_vertices_begin();
Alpha_shape_vertices_iterator alpha_shape_vertices_end() const
return Alpha_shape_vertices_list.end();
Alpha_shape_vertices_iterator Alpha_shape_vertices_end() const
Alpha_shape_edges_iterator alpha_shape_edges_begin() const
if(!use_edge_cache){
update_alpha_shape_edges_list();
return Alpha_shape_edges_list.begin();
Alpha_shape_edges_iterator Alpha_shape_edges_begin() const
return alpha_shape_edges_begin();
Alpha_shape_edges_iterator alpha_shape_edges_end() const
return Alpha_shape_edges_list.end();
Alpha_shape_edges_iterator Alpha_shape_edges_end() const
public:
// Traversal of the alpha-Values
// The alpha shape class defines an iterator that allows to
// visit the sorted sequence of alpha-values. This iterator is
// non-mutable and bidirectional. Its value type is Coord_type.
Alpha_iterator alpha_begin() const
// Returns an iterator that allows to traverse the sorted sequence
// of alpha-values of `A'.
return _alpha_spectrum.begin();
Alpha_iterator alpha_end() const
// Returns the corresponding past-the-end iterator.
return _alpha_spectrum.end();
Alpha_iterator alpha_find(const Coord_type& alpha) const
// Returns an iterator pointing to an element with alpha-value
// `alpha', or the corresponding past-the-end iterator if such an
// element is not found.
return std::find(_alpha_spectrum.begin(),
_alpha_spectrum.end(),
alpha);
Alpha_iterator alpha_lower_bound(const Coord_type& alpha) const
// Returns an iterator pointing to the first element with
// alpha-value not less than `alpha'.
return std::lower_bound(_alpha_spectrum.begin(),
alpha);
Alpha_iterator alpha_upper_bound(const Coord_type& alpha) const
// alpha-value greater than `alpha'.
return std::upper_bound(_alpha_spectrum.begin(),
alpha);
//--------------------- PREDICATES -----------------------------------
// the classification predicates take
// amortized const time if STL_STD::HASH_TABLES
// O(log #alpha_shape ) otherwise
Classification_type classify(const Point& p ) const
return classify( p, get_alpha());
Classification_type classify(const Point& p,
// Classifies a point `p' with respect to `A'.
Locate_type type;
int i;
Face_handle pFace = locate(p, type, i);
switch (type)
case VERTEX : return classify(pFace->vertex(i), alpha);
case EDGE : return classify(pFace, i, alpha);
case FACE : return classify(pFace, alpha);
case OUTSIDE_CONVEX_HULL :
case OUTSIDE_AFFINE_HULL : return EXTERIOR;
default : return EXTERIOR;
Classification_type classify(const Face_handle& f) const
// Classifies the face `f' of the underlying Delaunay
// triangulation with respect to `A'.
return classify(f, get_alpha());
Classification_type classify(const Face_handle& f,
// we consider close circles :
// f->radius < alpha <=> f exterior
// problem the operator [] is non-const
if (is_infinite(f)) return EXTERIOR;
// the version that computes the squared radius seems to be
// much faster
return (find_interval(f) <= alpha) ?
INTERIOR :
EXTERIOR;
Classification_type classify(const Edge& edge) const
return classify(edge.first, edge.second, get_alpha());
int i) const
return classify(f, i, get_alpha());
Classification_type classify(const Edge& edge,
return classify(edge.first, edge.second, alpha);
int i,
const Coord_type& alpha) const;
Classification_type classify(const Vertex_handle& v) const
return classify(v, get_alpha());
Classification_type classify(const Vertex_handle& v,
//--------------------- NB COMPONENTS ---------------------------------
int
number_solid_components() const
return number_of_solid_components(get_alpha());
int
number_of_solid_components() const
int
number_solid_components(const Coord_type& alpha) const
int
number_of_solid_components(const Coord_type& alpha) const;
private:
void traverse(const Face_handle& pFace,
Marked_face_set& marked_face_set,
const Coord_type alpha) const;
class Line_face_circulator;
public:
Alpha_iterator find_optimal_alpha(int nb_components);
private:
Coord_type find_alpha_solid() const;
//---------------------- PREDICATES ------------------------------------
private:
bool is_attached(const Face_handle& f, int i) const
Bounded_side b =
Gt().side_of_bounded_circle_2_object()(f->vertex(cw(i))->point(),
f->vertex(ccw(i))->point(),
f->vertex(i)->point());
return (b == ON_BOUNDED_SIDE) ? true : false;
//-------------------- GEOMETRIC PRIMITIVES ----------------------------
Coord_type squared_radius(const Face_handle& f) const
return
Gt().compute_squared_radius_2_object()(f->vertex(0)->point(),
f->vertex(1)->point(),
f->vertex(2)->point());
Coord_type squared_radius(const Face_handle& f, int i) const
return
Gt().compute_squared_radius_2_object()(f->vertex(ccw(i))->point(),
f->vertex(cw(i))->point());
private:
// prevent default copy constructor and default assigment
Alpha_shape_2(const Alpha_shape_2& A);
Alpha_shape_2& operator=(const Alpha_shape_2& A);
public:
// to debug
void print_edge_map();
//----------------------- MEMBER FUNCTIONS -----------------------------
void
Alpha_shape_2<Dt>::initialize_interval_face_map()
Coord_type alpha_f;
// only finite faces
for(Finite_faces_iterator face_it = faces_begin(); face_it != faces_end(); ++face_it)
alpha_f = squared_radius(face_it);
_interval_face_map.insert(Interval_face(alpha_f, face_it));
// cross references
face_it->set_alpha(alpha_f);
void
Alpha_shape_2<Dt>::initialize_interval_edge_map()
Edge_iterator edge_it;
Edge edge;
for( edge_it = edges_begin();
edge_it != edges_end();
++edge_it)
Interval3 interval;
edge = (*edge_it);
Face_handle pFace = edge.first;
int i = edge.second;
Face_handle pNeighbor = pFace->neighbor(i);
int Neigh_i = pNeighbor->index(pFace);
// not on the convex hull
if(!is_infinite(pFace) && !is_infinite(pNeighbor))
Coord_type squared_radius_Face =
find_interval(pFace);
Coord_type squared_radius_Neighbor =
find_interval(pNeighbor);
if (squared_radius_Neighbor < squared_radius_Face)
edge = Edge(pNeighbor, Neigh_i);
Coord_type coord_tmp = squared_radius_Face;
squared_radius_Face = squared_radius_Neighbor;
squared_radius_Neighbor = coord_tmp;
interval = (is_attached(pFace, i) ||
is_attached(pNeighbor, Neigh_i)) ?
make_triple(UNDEFINED,
squared_radius_Face,
squared_radius_Neighbor):
make_triple(squared_radius(pFace, i),
squared_radius_Neighbor);
else
{ // on the convex hull
if(is_infinite(pFace))
if (!is_infinite(pNeighbor))
interval = (is_attached(pNeighbor,
Neigh_i)) ?
find_interval(pNeighbor),
Infinity):
make_triple(squared_radius(pNeighbor,
Neigh_i),
Infinity);
else
// both faces are infinite by definition unattached
// the edge is finite by construction
CGAL_triangulation_precondition((is_infinite(pNeighbor)
&& is_infinite(pFace)));
interval = make_triple(squared_radius(pFace, i),
Infinity,
Infinity);
else
{ // is_infinite(pNeighbor)
&& !is_infinite(pFace)));
if (is_attached(pFace, i))
interval = make_triple(UNDEFINED,
find_interval(pFace),
Infinity);
else
Infinity);
_interval_edge_map.insert(Interval_edge(interval, edge));
// cross-links
(edge.first)->set_ranges(edge.second,interval);
// MY : to fix a bug I store the interval of the edge in both faces
Face_handle neighbor = (edge.first)->neighbor(edge.second);
int ni = neighbor->index(edge.first);
neighbor->set_ranges( ni, interval);
// Remark:
// The interval_edge_map will be sorted as follows
// first the attached edges on the convex hull
// second not on the convex hull
// third the un-attached edges on the convex hull
// finally not on the convex hull
// if we are in regularized mode we should sort differently
// by the second third first Key
void
Alpha_shape_2<Dt>::initialize_interval_vertex_map()
Coord_type alpha_mid_v;
Coord_type alpha_max_v;
Coord_type alpha_f;
Finite_vertices_iterator vertex_it;
for( vertex_it = finite_vertices_begin();
vertex_it != finite_vertices_end();
++vertex_it)
Vertex_handle v = vertex_it;
Face_handle f;
alpha_max_v = Coord_type(0);
alpha_mid_v = (!_interval_face_map.empty() ?
(--_interval_face_map.end())->first :
Coord_type(0));
//----------------- examine incident edges --------------------------
// // if we used Edelsbrunner and Muecke's definition
// // singular means not incident to any higher-dimensional face
// // regular means incident to a higher-dimensional face
// Edge_circulator edge_circ = this->incident_edges(v),
// edge_done(edge_circ);
// do
// f = (*edge_circ).first;
// int i = (*edge_circ).second;
// if (is_infinite(f, i))
// alpha_max_v = Infinity;
// else
// Interval3 interval3 = find_interval(const_Edge(f, i));
// alpha_mid_v = (interval3.first != UNDEFINED) ?
// CGAL::min BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_mid_v, interval3.first):
// CGAL::min BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_mid_v, interval3.second);
// if (alpha_max_v != Infinity)
// alpha_max_v = (interval3.third != Infinity) ?
// CGAL::max BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_max_v, interval3.third):
// Infinity;
// while(++edge_circ != edge_done);
//-------------- examine incident faces --------------------------
// we use a different definition than Edelsbrunner and Muecke
// singular means not incident to any 2-dimensional face
// regular means incident to a 2-dimensional face
Face_circulator face_circ = this->incident_faces(v),
done = face_circ;
if (!face_circ.is_empty())
do
f = face_circ;
if (is_infinite(f))
// continue;
else
alpha_f = find_interval(f);
// if we define singular as not incident to a 2-dimensional
// face
alpha_mid_v = CGAL::min BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_mid_v, alpha_f);
alpha_max_v = CGAL::max BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_max_v, alpha_f);
while(++face_circ != done);
Interval2 interval = std::make_pair(alpha_mid_v, alpha_max_v);
_interval_vertex_map.insert(Interval_vertex(interval, vertex_it));
// cross references
vertex_it->set_range(interval);
void
Alpha_shape_2<Dt>::initialize_alpha_spectrum()
// skip the attached edges
// <=> _interval_edge_map.first.first == UNDEFINED
typename Interval_edge_map::iterator
edge_it = std::upper_bound(_interval_edge_map.begin(),
_interval_edge_map.end(),
UNDEFINED,
Less());
// merge the maps which is sorted and contains the alpha-values
// of the unattached edges and the triangles.
// eliminate duplicate values due to for example attached edges
// merge and copy from STL since assignment should be function object
typename Interval_face_map::iterator
face_it = _interval_face_map.begin();
_alpha_spectrum.reserve(_interval_face_map.size() +
_interval_edge_map.size()/ 2 );
// should be only the number of unattached edges
// size_type nb_unattached_edges;
// distance(edge_it, _interval_edge_map.end(), nb_unattached_edges);
// however the distance function is expensive
while (edge_it != _interval_edge_map.end() ||
face_it != _interval_face_map.end())
if (face_it != _interval_face_map.end() &&
(edge_it == _interval_edge_map.end() ||
((*face_it).first < (*edge_it).first.first)))
if (((_alpha_spectrum.empty() ||
_alpha_spectrum.back() < (*face_it).first)) &&
((*face_it).first > Coord_type(0)))
_alpha_spectrum.push_back((*face_it).first);
face_it++;
else
_alpha_spectrum.back() < (*edge_it).first.first)) &&
(((*edge_it).first.first) > Coord_type(0)))
_alpha_spectrum.push_back((*edge_it).first.first);
edge_it++;
while (edge_it != _interval_edge_map.end())
_alpha_spectrum.back() < (*edge_it).first.first))&&
edge_it++;
while (face_it != _interval_face_map.end())
_alpha_spectrum.back() < (*face_it).first))&&
face_it++;
void
Alpha_shape_2<Dt>::update_alpha_shape_vertex_list()const {
//typedef typename Alpha_shape_2<Dt>::Interval_vertex_map
// Interval_vertex_map;
typename Interval_vertex_map::const_iterator vertex_alpha_it;
//const typename Alpha_shape_2<Dt>::Interval2* pInterval2;
const Interval2* pInterval2;
Vertex_handle v;
// write the regular vertices
for (vertex_alpha_it = _interval_vertex_map.begin();
vertex_alpha_it != _interval_vertex_map.end() &&
(*vertex_alpha_it).first.first <= get_alpha();
++vertex_alpha_it)
pInterval2 = &(*vertex_alpha_it).first;
if((pInterval2->second > get_alpha()
|| pInterval2->second == Infinity))
// alpha must be larger than the min boundary
// and alpha is smaller than the upper boundary
// which might be infinity
// write the vertex
v = (*vertex_alpha_it).second;
CGAL_triangulation_assertion((classify(v) == REGULAR));
Alpha_shape_vertices_list.push_back(v);
if (get_mode() == Alpha_shape_2<Dt>::GENERAL)
// write the singular vertices
for (;
vertex_alpha_it != _interval_vertex_map.end();
++vertex_alpha_it)
CGAL_triangulation_assertion((classify(v) == SINGULAR));
use_vertex_cache = true;
void
Alpha_shape_2<Dt>::update_alpha_shape_edges_list() const
// Writes the edges of the alpha shape `A' for the current $\alpha$- value
// to the container where 'out' refers to. Returns an output iterator
// which is the end of the constructed range.
//typedef typename Alpha_shape_2<Dt>::Interval_edge_map Interval_edge_map;
typename Interval_edge_map::const_iterator edge_alpha_it;
//const typename Alpha_shape_2<Dt>::Interval3* pInterval;
const Interval3* pInterval;
if (get_mode() == REGULARIZED)
// it is much faster looking at the sorted intervals
// than looking at all sorted faces
// alpha must be larger than the mid boundary
for (edge_alpha_it = _interval_edge_map.begin();
edge_alpha_it != _interval_edge_map.end() &&
(*edge_alpha_it).first.first <= get_alpha();
++edge_alpha_it)
pInterval = &(*edge_alpha_it).first;
CGAL_triangulation_assertion(pInterval->second != Infinity);
// since this happens only for convex hull of dimension 2
// thus singular
if(pInterval->second <= get_alpha() &&
(pInterval->third > get_alpha()
|| pInterval->third == Infinity))
// visualize the boundary
CGAL_triangulation_assertion((classify((*edge_alpha_it).second.first,
== REGULAR));
Alpha_shape_edges_list.push_back(Edge((*edge_alpha_it).second.first,
(*edge_alpha_it).second.second));
else
{ // get_mode() == GENERAL -------------------------------------------
// draw the edges
++edge_alpha_it)
if (pInterval->first == UNDEFINED)
// thus singular
== REGULAR));
else
if(pInterval->third > get_alpha()
// if alpha is smaller than the upper boundary
CGAL_triangulation_assertion(((classify((*edge_alpha_it).second.first,
== REGULAR)
== SINGULAR)));
use_edge_cache = true;
typename Alpha_shape_2<Dt>::Classification_type
Alpha_shape_2<Dt>::classify(const Face_handle& f, int i,
// Classifies the edge `e' of the underlying Delaunay
// the version that uses a simplified version without crosslinks
// is much slower
return EXTERIOR;
// we store only finite edges in _edge_interval_map
Interval3 interval = find_interval(const_Edge(f, i));
// (*(_edge_interval_map.find(const_Edge(f, i)))).second;
if (alpha < interval.second)
if (get_mode() == REGULARIZED ||
interval.first == UNDEFINED ||
alpha < interval.first)
return EXTERIOR;
else // alpha >= interval.first
return SINGULAR;
else
{ // alpha >= interval.second
if (interval.third == Infinity ||
alpha < interval.third)
return REGULAR;
else // alpha >= interval.third
return INTERIOR;
Alpha_shape_2<Dt>::classify(const Vertex_handle& v,
// Classifies the vertex `v' of the underlying Delaunay
Interval2 interval = v->get_range();
if (alpha < interval.first)
return EXTERIOR;
else // general => vertices are never exterior
return SINGULAR;
else
{ // alpha >= interval.first
if (interval.second == Infinity ||
return REGULAR;
else // alpha >= interval.second
return INTERIOR;
int
Alpha_shape_2<Dt>::number_of_solid_components(const Coord_type& alpha) const
// Determine the number of connected solid components
typedef typename Marked_face_set::Data Data;
Marked_face_set marked_face_set(false);
Finite_faces_iterator face_it;
int nb_solid_components = 0;
if (number_of_vertices()==0)
return 0;
for( face_it = faces_begin();
++face_it)
Face_handle pFace = face_it;
CGAL_triangulation_postcondition( pFace != NULL);
if (classify(pFace, alpha) == INTERIOR){
Data& data = marked_face_set[pFace];
if(data == false)
// we traverse only interior faces
traverse(pFace, marked_face_set, alpha);
nb_solid_components++;
return nb_solid_components;
void
Alpha_shape_2<Dt>::traverse(const Face_handle& pFace,
std::list<Face_handle> faces;
faces.push_back(pFace);
Face_handle pNeighbor, fh;
while(! faces.empty()){
fh = faces.front();
faces.pop_front();
for (int i=0; i<3; i++)
pNeighbor = fh->neighbor(i);
CGAL_triangulation_assertion(pNeighbor != NULL);
if (classify(pNeighbor, alpha) == INTERIOR){
Data& data = marked_face_set[pNeighbor];
if(data == false){
data = true;
faces.push_back(pNeighbor);
typename Alpha_shape_2<Dt>::Alpha_iterator
Alpha_shape_2<Dt>::find_optimal_alpha(int nb_components)
// find the minimum alpha that satisfies the properties
// (1) nb_components solid components
// (2) all data points on the boundary or in its interior
Coord_type alpha = find_alpha_solid();
// from this alpha on the alpha_solid satisfies property (2)
Alpha_iterator first = alpha_lower_bound(alpha);
if (number_of_solid_components(alpha) == nb_components)
if ((first+1) < alpha_end())
return (first+1);
else
return first;
// do binary search on the alpha values
// number_of_solid_components() is a monotone function
// if we start with find_alpha_solid
Alpha_iterator last = alpha_end();
Alpha_iterator middle;
std::ptrdiff_t len = last - first - 1;
std::ptrdiff_t half;
while (len > 0)
half = len / 2;
middle = first + half;
#ifdef CGAL_DEBUG_ALPHA_SHAPE_2
std::cout << "first : " << *first << " last : " << *(first+len)
<< " mid : " << *middle
<< " nb comps : " << number_of_solid_components(*middle)
<< std::endl;
#endif // CGAL_DEBUG_ALPHA_SHAPE_2
if (number_of_solid_components(*middle) > nb_components)
first = middle + 1;
len = len - half - 1;
else
{ // number_of_solid_components(*middle) <= nb_components
len = half;
return (first+1);
else
return first;
typename Alpha_shape_2<Dt>::Coord_type
Alpha_shape_2<Dt>::find_alpha_solid() const
// compute the minumum alpha such that all data points
// are either on the boundary or in the interior
// not necessarily connected
// starting point for searching
// takes O(#alpha_shape) time
Coord_type alpha_solid = 0;
// only finite vertices
++vertex_it)
Coord_type alpha_min_v = (--_interval_face_map.end())->first;
Face_circulator face_circ = this->incident_faces(vertex_it);
Face_circulator done = face_circ;
do
Face_handle f = face_circ;
if (! is_infinite(f))
alpha_min_v = CGAL::min BOOST_PREVENT_MACRO_SUBSTITUTION(find_interval(f),
alpha_min_v);
while (++face_circ != done);
alpha_solid = CGAL::max BOOST_PREVENT_MACRO_SUBSTITUTION (alpha_min_v, alpha_solid);
return alpha_solid;
std::ostream&
Alpha_shape_2<Dt>::op_ostream(std::ostream& os) const
Interval_vertex_map ;
Unique_hash_map< Vertex_handle , int > V;
int number_of_vertices = 0;
Interval_edge_map;
if (get_mode() == Alpha_shape_2<Dt>::REGULARIZED)
typename Alpha_shape_2<Dt>::Vertex_handle v;
++vertex_alpha_it)
typename Alpha_shape_2<Dt>::Coord_type alpha =
get_alpha();
typename Alpha_shape_2<Dt>::Coord_type alpha_mid =
pInterval2->first;
typename Alpha_shape_2<Dt>::Coord_type alpha_max =
pInterval2->second;
// write the vertex
Alpha_shape_2<Dt>::REGULAR));
// we would write too many vertices
V[v] = number_of_vertices++;
os << v->point() << std::endl;
// the vertices are oriented counterclockwise
typename Alpha_shape_2<Dt>::Face_handle f;
int i;
++edge_alpha_it)
// since this happens only for convex hull of dimension 1
// thus singular
f = (*edge_alpha_it).second.first;
i = (*edge_alpha_it).second.second;
// assure that all vertices are in ccw order
if (classify(f) == Alpha_shape_2<Dt>::EXTERIOR)
// take the reverse face
pNeighbor = f->neighbor(i);
i = pNeighbor->index(f);
f = pNeighbor;
CGAL_triangulation_assertion((classify(f) ==
Alpha_shape_2<Dt>::INTERIOR));
CGAL_triangulation_assertion((classify(f, i) ==
os << V[f->vertex(f->ccw(i))] << ' '
<< V[f->vertex(f->cw(i))] << std::endl;
else
++vertex_alpha_it)
// write the vertex
for (;
++vertex_alpha_it)
Alpha_shape_2<Dt>::SINGULAR));
int i;
++edge_alpha_it)
get_alpha();
typename Alpha_shape_2<Dt>::Coord_type alpha_min =
pInterval->first;
pInterval->second;
pInterval->third;
// write the regular edges
if (pInterval->second != Infinity &&
pInterval->second <= get_alpha())
f = pNeighbor;
else
{ // pInterval->second == Infinity ||
// pInterval->second >=
get_alpha())
// pInterval->second == Infinity happens only for convex
hull
// of dimension 1 thus singular
// write the singular edges
if (pInterval->first != UNDEFINED)
return os;
std::ostream&
operator<<(std::ostream& os, const Alpha_shape_2<Dt>& A)
return A.op_ostream(os);
std::list<typename Alpha_shape_2<Dt>::Point>
Alpha_shape_2<Dt>::Output ()
std::list<Point> L;
++edge_alpha_it)
if (pInterval->second != Infinity)
// thus singular
REGULAR));
// thus we would write to many vertices
L.push_back((segment((*edge_alpha_it).second.first,
.source());
.target());
else
// draw the edges
++edge_alpha_it)
// thus singular
REGULAR));
.source());
.target());
else
REGULAR) ||
SINGULAR)));
.source());
.target());
return L;
void
Alpha_shape_2<Dt>::print_edge_map() {
for (typename Interval_edge_map::iterator iemapit= _interval_edge_map.begin();
iemapit != _interval_edge_map.end(); ++iemapit) {
Interval3 interval = (*iemapit).first;
Edge edge = (*iemapit).second;
Point p1 = edge.first->vertex(cw(edge.second))->point();
Point p2 = edge.first->vertex(ccw(edge.second))->point();
std::cout << "[ (" << p1 << ") - (" << p2 << ") ] : "
<< interval.first << " "
<< interval.second << " " << interval.third << std::endl;
CGAL_END_NAMESPACE
#endif //CGAL_ALPHA_SHAPE_2_H
