- To:
- Subject: Re: [cgal-discuss] Location of "thin" map faces
- Date: Fri, 20 Aug 2010 18:26:19 +0300
In CG there are these notions of width:
1. The width of a set of points P ⊆ R^d is the minimum distance between parallel hyperplanes supporting the convex hull of P.
2. Given a normalized vector v, the directional width is the distance between parallel hyperplanes supporting the convex hull of P and orthogonal to v.
So the width (resp. the directional width) of P is the penetration depth (resp. the directional penetration depth) of P and a copy of P.
width(P) = penetration-depth(P,P) = inf{|| t|| | t /∈ (P ⊕ −P), t ∈ R^d}
In simple words the width of a polygon is the smallest distance of the origin from the boundary of the Minkowski sum of P and -P (P reflected about the origin). The directional width in the direction of a given vector v is the distance of the origin from the boundary of the Minkowski sum of P and -P in the direction of v.
Quoting "Ben Supnik"
Hi Y'all,
I'm looking for the right term for an algorithm to determine the largest "width" of a polygon. Colloquially, I want to identify how "thin" a polygon is...in other words, I want to identify slivers and long thin winding polygons vs. large round areas.
Naively I think I could do an inset using a minkowski sum and if my resulting set is empty, I know that no point was "wider" than the 2x the diamater of the shape I used for convolution.
Are there metrics or algorithms that compute this kind of value more directly? If anyone has a search term for the type of computational geometry problem I'm looking at, a hint would be much appreciated.
cheers
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Location of "thin" map faces, Ben Supnik, 08/19/2010
- Re: [cgal-discuss] Location of "thin" map faces, Christian Brunschen, 08/19/2010
- Re: [cgal-discuss] Location of "thin" map faces, efif, 08/20/2010
