Re: [cgal-discuss] CGAL 3.7 Beta 1 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 3.7 Beta 1 Released, Computational Geometry Algorithms Library
- Date: Tue, 24 Aug 2010 08:29:25 +0100
Why has support for Visual C++ 2008 been dropped? we are still going to have
to support and build under 2008 for another couple of years, and if I can't
build newer versions of CGAL
then I'm going to be missing out on a lot of bug fixes and new functionality.
On 23/08/2010 16:37, Laurent Rineau (GeometryFactory) wrote:
The CGAL Open Source Project is pleased to announce the Release 3.7 Beta 1
of CGAL, the Computational Geometry Algorithms Library.
CGAL-3.7-beta1 is a public testing release. It should provide
a solid ground to report bugs that need to be tackled before the
release of the final version of CGAL 3.7 end of September 2010.
CGAL-3.7 provides improvements and fixes to existing packages, and support
for new compilers.
See http://www.cgal.org/releases.html for a complete list of changes.
The CGAL project is a collaborative effort to develop a robust,
easy-to-use, and efficient C++ software library of geometric data
structures and algorithms, like
- triangulations (2D constrained triangulations and Delaunay
triangulations in 2D and 3D),
- Voronoi diagrams (for 2D and 3D points, 2D additively weighted
Voronoi diagrams, and segment Voronoi diagrams),
- Boolean operations on polygons and polyhedra,
- Regularized Boolean operations on polygons with curved arcs
- arrangements of curves,
- mesh algorithms (2D Delaunay mesh generation and 3D surface mesh
generation, surface mesh subdivision and parameterization),
- alpha shapes (in 2D and 3D),
- convex hull algorithms (in 2D, 3D and dD),
- operations on polygons (straight skeleton and offset polygon),
- search structures (kd trees for nearest neighbor search, and
range and segment trees),
- interpolation (natural neighbor interpolation and placement of
streamlines),
- optimization algorithms (smallest enclosing sphere of points or
spheres, smallest enclosing ellipsoid of points, principal
component analysis),
- kinetic data structures
Some modules are distributed under the terms of the LGPL Open Source
license (GNU Lesser General Public License v2.1).
Most modules are distributed under the terms of the QPL Open Source
license (Q Public License v1.0).
If your intended usage does not meet the criteria of the
aforementioned licenses, a commercial license can be purchased from
GeometryFactory (http://www.geometryfactory.com/).
For further information and for downloading the library and its
documentation, please visit the CGAL web site: http://www.cgal.org/
- [cgal-discuss] CGAL 3.7 Beta 1 Released, Computational Geometry Algorithms Library, Laurent Rineau (GeometryFactory), 08/23/2010
- Re: [cgal-discuss] CGAL 3.7 Beta 1 Released, Computational Geometry Algorithms Library, Joachim Reichel, 08/23/2010
- Re: [cgal-discuss] CGAL 3.7 Beta 1 Released, Computational Geometry Algorithms Library, Hansjoerg Seybold, 08/24/2010
- Re: [cgal-discuss] CGAL 3.7 Beta 1 Released, Computational Geometry Algorithms Library, Joachim Reichel, 08/24/2010
- Re: [cgal-discuss] CGAL 3.7 Beta 1 Released, Computational Geometry Algorithms Library, Karl Gaize, 08/24/2010
- Re: [cgal-discuss] CGAL 3.7 Beta 1 Released, Computational Geometry Algorithms Library, Andreas Fabri, 08/24/2010
