- To:
- Subject: Re: [cgal-discuss] 4D Delaunay
- Date: Tue, 24 Aug 2010 08:39:31 +0200
Panagiotis Foteinos wrote:
Hello.
I am using the Delaunay_d class for the triangulation of 4D points. I am also using the Cartesian_d<double> kernel.
Looking at the documentation here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_d_ref/Class_Cartesian_d.html#Index_anchor_736
you'll see that you need to use an exact number type such as CGAL::Gmpq (in particular with collinear points) to compute safely the triangulation.
S.
I observed that the insertion of the following simple point sequence:
1st point: 6.8, 6.8, 6.8, 6.8
2nd point: 6.8, 6.8, 6.8, 43.2
3rd point: 6.8, 6.8, 43.2, 6.8
4th point: 6.8, 6.8, 43.2, 43.2
triggers, during the insertion of the 4th point, the following assertion:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: j != dim
File: .../CGAL-3.6.1/include/CGAL/Kernel_d/HyperplaneCd.h
Line: 103
Explanation: HyperplaneCd::constructor: cannot use o to determine side.
Is there a workaround? Why is this behaviour happening?
Thank you,
Panagiotis Foteinos
- [cgal-discuss] 4D Delaunay, Panagiotis Foteinos, 08/23/2010
- Re: [cgal-discuss] 4D Delaunay, Sebastien Loriot (GeometryFactory), 08/24/2010
- Re: [cgal-discuss] 4D Delaunay, Panagiotis Foteinos, 08/25/2010
- Re: [cgal-discuss] 4D Delaunay, Sebastien Loriot (GeometryFactory), 08/25/2010
- Re: [cgal-discuss] 4D Delaunay, Sebastien Loriot (GeometryFactory), 08/26/2010
