- To:
- Subject: Re: [cgal-discuss] 4D Delaunay
- Date: Wed, 25 Aug 2010 00:23:40 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=D4rSSnvNzFdcOyJ4ZzByiyKYlTk9zSYc4q9NypV7ABpyY9WJD37XNOsmruiaTbt6oS OxTlzrQahi96IEHNp+krQ23d+o39TOLytNZa6+etxfoZ2cl98rr7Q8dBwIHAjSVTcKYI TJsBu6OSpnALkdSL6lBoiq8bK1bvUteHlj398=
Thank you Sebastien.
I assumed that exact constructions were not necessary for the 4D kernels, simply because this is the case for the 3D kernels. I was wrong. The Cartesian_d<CGAL::Gmpq> kernel works fine now.
I encountered, however, another error which sadly does not trigger any assertion, but rather it throws a segmentation fault.
Consider the following insertion sequence of 4D points:
1st point: 6.8, 6.8, 6.8, 6.8
2nd point: 6.8, 6.8, 6.8, 43.2
3rd point: 6.8, 6.8, 43.2, 6.8
4th point: 6.8, 6.8, 43.2, 43.2
The function DT.lookup() on the 4th point before its insertion throws a segmentation fault in the file CGAL/Handle_for.h (Line 125) .
I looked into the code and I observed that CGAL checks the points of at least one simplex. However, no simplex has to exist in the triangulation so far: only 3 points have been inserted. Also, no extra (i.e., more than it is needed to describe the actual triangulation) simplices are created (for example infinite simplices as is the case in 3D), and therefore I do not understand why CGAL finds a simplex to check. Maybe this observation is related to the segmentation fault occurred.
Any input? I am really wondering if someone could reproduce the error I get, i.e. a segmentation fault during the insertion of the 4th point... I am using version 3.6.1 .
Thank you in advance,
Panagiotis Foteinos
On Tue, Aug 24, 2010 at 8:39 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
Panagiotis Foteinos wrote:Looking at the documentation here:
Hello.
I am using the Delaunay_d class for the triangulation of 4D points. I am also using the Cartesian_d<double> kernel.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_d_ref/Class_Cartesian_d.html#Index_anchor_736
you'll see that you need to use an exact number type such as CGAL::Gmpq (in particular with collinear points) to compute safely the triangulation.--
S.
I observed that the insertion of the following simple point sequence:
triggers, during the insertion of the 4th point, the following assertion:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: j != dim
File: .../CGAL-3.6.1/include/CGAL/Kernel_d/HyperplaneCd.h
Line: 103
Explanation: HyperplaneCd::constructor: cannot use o to determine side.
Is there a workaround? Why is this behaviour happening?
Thank you,
Panagiotis Foteinos
- [cgal-discuss] 4D Delaunay, Panagiotis Foteinos, 08/23/2010
- Re: [cgal-discuss] 4D Delaunay, Sebastien Loriot (GeometryFactory), 08/24/2010
- Re: [cgal-discuss] 4D Delaunay, Panagiotis Foteinos, 08/25/2010
- Re: [cgal-discuss] 4D Delaunay, Sebastien Loriot (GeometryFactory), 08/25/2010
- Re: [cgal-discuss] 4D Delaunay, Sebastien Loriot (GeometryFactory), 08/26/2010
