- To:
- Subject: [cgal-discuss] Build fails on linux when CGAL is a subversion working copy
- Date: Thu, 09 Sep 2010 14:53:11 +0200
Dear list
I am using the CGAL lib for quite a while now. Today I wanted to upgrade from CGAL 3.4 to 3.6. In our project, the whole CGAL code resides in a subversion repository. This means when the CGAL code is checked out on a machine every directory contains a .svn directory. Up to version 3.4 this was not a problem. When I try to build the 3.6 on a Linux (Ubuntu 10.4) with the command "cmake .", like it is stated in the manual, I get the following error message:
CMake Error at CMakeLists.txt:426 (install):
install PROGRAMS given directory
"/home/abenzler/temp/cgal/CGAL-3.6.1/source/scripts/.svn" to install.
I tried the 3.7 beta1 as well with similar results:
CMake Error at CMakeLists.txt:415 (install):
"/home/abenzler/temp/cgal/CGAL-3.7-beta1/scripts/.svn" to install.
Does anyone know whether this is a common problem and is there a workaround for that?
Kind Regards
Andreas Benzler
- [cgal-discuss] Build fails on linux when CGAL is a subversion working copy, Andreas Benzler, 09/09/2010
- Re: [cgal-discuss] Build fails on linux when CGAL is a subversion working copy, Joachim Reichel, 09/16/2010
- Re: [cgal-discuss] Build fails on linux when CGAL is a subversion working copy, Andreas Benzler, 09/17/2010
