- To:
- Subject: Re: [cgal-discuss] Build fails on linux when CGAL is a subversion working copy
- Date: Thu, 16 Sep 2010 19:35:01 +0200
Hi,
> I am using the CGAL lib for quite a while now. Today I wanted to upgrade
> from CGAL 3.4 to 3.6. In our project, the whole CGAL code resides in a
> subversion repository. This means when the CGAL code is checked out on a
> machine every directory contains a .svn directory. Up to version 3.4
> this was not a problem. When I try to build the 3.6 on a Linux (Ubuntu
> 10.4) with the command "cmake .", like it is stated in the manual, I get
> the following error message:
> CMake Error at CMakeLists.txt:426 (install):
> install PROGRAMS given directory
> "/home/abenzler/temp/cgal/CGAL-3.6.1/source/scripts/.svn" to install.
> I tried the 3.7 beta1 as well with similar results:
> CMake Error at CMakeLists.txt:415 (install):
> "/home/abenzler/temp/cgal/CGAL-3.7-beta1/scripts/.svn" to install.
> Does anyone know whether this is a common problem and is there a
> workaround for that?
you can replace "scripts/*" by "scripts/c*" in the mentioned line.
Joachim
- [cgal-discuss] Build fails on linux when CGAL is a subversion working copy, Andreas Benzler, 09/09/2010
- Re: [cgal-discuss] Build fails on linux when CGAL is a subversion working copy, Joachim Reichel, 09/16/2010
- Re: [cgal-discuss] Build fails on linux when CGAL is a subversion working copy, Andreas Benzler, 09/17/2010
