- To:
- Subject: Re: [cgal-discuss] Build fails on linux when CGAL is a subversion working copy
- Date: Fri, 17 Sep 2010 08:01:38 +0200
Hi Joachim
On 16.09.2010 19:35, Joachim Reichel wrote:
CMake Error at CMakeLists.txt:415 (install):
install PROGRAMS given directory
"/home/abenzler/temp/cgal/CGAL-3.7-beta1/scripts/.svn" to install.
Does anyone know whether this is a common problem and is there a
workaround for that?
you can replace "scripts/*" by "scripts/c*" in the mentioned line.
Thank your for that hint. The compile process works perfect now. Is there anything I should do that this fix is included in future releases?
The install script seems to copy a lot of not revelvant .svn directory's.
I found a lot of similar outputs during the installation process:
-- Installing: /temp/cgal/install/include/CGAL/Arr_point_location/.svn/prop-base
I also noticed that older versions of CGAL like 3.4 also had that behavior. For me it is not a real problem but just to let you know...
Regards
Andreas
- [cgal-discuss] Build fails on linux when CGAL is a subversion working copy, Andreas Benzler, 09/09/2010
- Re: [cgal-discuss] Build fails on linux when CGAL is a subversion working copy, Joachim Reichel, 09/16/2010
- Re: [cgal-discuss] Build fails on linux when CGAL is a subversion working copy, Andreas Benzler, 09/17/2010
