cgal-discuss - Re: [cgal-discuss] Assertion: CGAL/Interval_nt.h:88: !(i>s)
  • To:
  • Subject: Re: [cgal-discuss] Assertion: CGAL/Interval_nt.h:88: !(i>s)
  • Date: Tue, 05 Oct 2010 15:15:11 +0200
Bruce Duncan wrote:
On Lunes 09 Agosto 2010 19:43:47 Sylvain Pion escribió:
Le 06/08/10 17:37, Bruce Duncan a écrit :
Sylvain Pion wrote:
Le 06/08/10 14:02, Bruce Duncan a écrit :
For one of the assertions I'm hitting, I've created what I hope is a
small testcase. The code and the output on my machine is attached.
The assertion means that an uninitialized variable has been used.
And indeed the plane equations in the Polyhedron of CGAL needs manual
construction. Seehttp://www.cgal.org/FAQ.html#polyhedron_normals .
I have tried to modify my program to use the Traits class as shown in
the example program.
I am now having trouble converting this Polyhedron to a Nef_polyhedron,
which I want to use for the boolean operations. Is this possible?
I haven't attached the compiler output this time, as it's very long.
Suffice to say it starts with "Nef_3/polyhedron_3_to_nef_3.h:218: error:
'class Vector_3' has no member named 'is_degenerate'"
What am I doing wrong?
I am not well versed enough into the Nef polyhedron to answer.
I hope someone else can follow up. In any case, I advice to send
as much of the error message as possible : I'm not sure it's
possible for anyone to see what's going wrong here.
Hi,
Sorry for the delay in replying.
I have attached my test case and the compiler output. The code compiles if line 20 is changed from Polyhedron_traits_with_normals_3 to just Polyhedron_traits_3.
I looked at the difference between CGAL/Polyhedron_traits_3.h and CGAL/Polyhedron_traits_with_normals_3.h. This hunk seemed interesting (line 32):
- typedef typename Kernel::Plane_3 Plane_3;
+ typedef typename Kernel::Vector_3 Plane_3;
I changed the code to:
typedef typename Kernel::Vector_3 Vector_3;
and it seems to compile. Is this a bug in CGAL? Perhaps the author intended both Plane_3 and Vector_3 to be defined?
Thanks,
Bruce
Hello Bruce,
I had a look at the code and the problem is in my opinion in polyhedron_3_to_nef_3 which assumes that the type Plane defined by the polyhedron traits is a of type Plane<K>. I will have a closer look at it to find a solution.
Can you use Polyhedron_traits_3 instead?
S.
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
