cgal-discuss - Re: [cgal-discuss] Assertion: CGAL/Interval_nt.h:88: !(i>s)
  • To:
  • Subject: Re: [cgal-discuss] Assertion: CGAL/Interval_nt.h:88: !(i>s)
  • Date: Mon, 11 Oct 2010 10:20:12 +0200
Bruce Duncan wrote:
Sebastien Loriot (GeometryFactory) wrote:
Bruce Duncan wrote:
On Lunes 09 Agosto 2010 19:43:47 Sylvain Pion escribió:
Le 06/08/10 17:37, Bruce Duncan a écrit :
Sylvain Pion wrote:
Le 06/08/10 14:02, Bruce Duncan a écrit :
For one of the assertions I'm hitting, I've created what I hope is a
small testcase. The code and the output on my machine is attached.
The assertion means that an uninitialized variable has been used.
And indeed the plane equations in the Polyhedron of CGAL needs manual
construction. Seehttp://www.cgal.org/FAQ.html#polyhedron_normals .
I have tried to modify my program to use the Traits class as shown in
the example program.
I am now having trouble converting this Polyhedron to a Nef_polyhedron,
which I want to use for the boolean operations. Is this possible?
I haven't attached the compiler output this time, as it's very long.
Suffice to say it starts with "Nef_3/polyhedron_3_to_nef_3.h:218:
error:
'class Vector_3' has no member named 'is_degenerate'"
What am I doing wrong?
I am not well versed enough into the Nef polyhedron to answer.
I hope someone else can follow up. In any case, I advice to send
as much of the error message as possible : I'm not sure it's
possible for anyone to see what's going wrong here.
Hi,
Sorry for the delay in replying.
I have attached my test case and the compiler output. The code
compiles if line 20 is changed from Polyhedron_traits_with_normals_3
to just Polyhedron_traits_3.
I looked at the difference between CGAL/Polyhedron_traits_3.h and
CGAL/Polyhedron_traits_with_normals_3.h. This hunk seemed interesting
(line 32):
- typedef typename Kernel::Plane_3 Plane_3;
+ typedef typename Kernel::Vector_3 Plane_3;
I changed the code to:
typedef typename Kernel::Vector_3 Vector_3;
and it seems to compile. Is this a bug in CGAL? Perhaps the author
intended both Plane_3 and Vector_3 to be defined?
Thanks,
Bruce
Hello Bruce,
I had a look at the code and the problem is in my opinion in
polyhedron_3_to_nef_3 which assumes that the type Plane defined by the
polyhedron traits is a of type Plane<K>. I will have a closer look at it
to find a solution.
Can you use Polyhedron_traits_3 instead?
Hi Sebastien,
I think I really need the plane normals. I eventually hope to export
these data to a fortran code which will need them. Any hope that this
bug can be fixed? Am I allowed to call it a bug? :)
Bruce
Try with the attached patched file.
I am busy these days I did not have time to test it yet.
Tell me whether it works correctly or not.
S.
// Copyright (c) 1997-2002  Max-Planck-Institute Saarbruecken (Germany).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL: svn+ssh:///svn/cgal/trunk/Nef_3/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h $
// $Id: polyhedron_3_to_nef_3.h 56667 2010-06-09 07:37:13Z sloriot $
// Author(s)     : Michael Seel    <>
//                 Miguel Granados <>
//                 Susan Hert      <>
//                 Lutz Kettner    <>
#ifndef CGAL_NEF_POLYHEDRON_3_TO_NEF_3_H
#define CGAL_NEF_POLYHEDRON_3_TO_NEF_3_H
#include <CGAL/Circulator_project.h>
#include <CGAL/normal_vector_newell_3.h>
#include <CGAL/Nef_S2/SM_point_locator.h>
#include <CGAL/Nef_3/SNC_indexed_items.h>
#undef CGAL_NEF_DEBUG
#define CGAL_NEF_DEBUG 29
#include <CGAL/Nef_2/debug.h>
namespace CGAL {
template < class Node, class Object>
struct Project_vertex_point {
  typedef Node                  argument_type;
  typedef Object                result_type;
  Object&       operator()( Node& x)       const { return x.vertex()->point();}
  const Object& operator()( const Node& x) const { return x.vertex()->point();}
namespace internal
  template <class T>
  struct Plane_constructor;
  template <class K>
  struct Plane_constructor< CGAL::Plane_3<K> >
    template <class Facet>
    static const CGAL::Plane_3<K>& get_plane(Facet,const CGAL::Plane_3<K>& plane){return plane;}
    static CGAL::Plane_3<K> get_type_plane(const CGAL::Point_3<K>& p,const CGAL::Vector_3<K>& vector){return CGAL::Plane_3<K>(p,vector);}
    static CGAL::Vector_3<K> get_opposite_orthogonal_vector(const CGAL::Plane_3<K>& plane){return plane.opposite().orthogonal_vector();}
  template <class K>
  struct Plane_constructor< CGAL::Vector_3<K> >
    static CGAL::Plane_3<K> get_plane(Facet f,const CGAL::Vector_3<K>& vector){
      return CGAL::Plane_3<K>(f->halfedge()->vertex()->point(),vector);
    static const CGAL::Vector_3<K>& get_type_plane(const CGAL::Point_3<K>&,const CGAL::Vector_3<K>& vector){
      return vector;
    static CGAL::Vector_3<K> get_opposite_orthogonal_vector(const CGAL::Vector_3<K>& vector){return -vector;}
  template <class K,class Object,class Facet>
  CGAL::Plane_3<K> get_plane(const Facet& f,const Object& obj)
  {return Plane_constructor<Object>::get_plane(f,obj);}
  template <class K,class Object>
  CGAL::Vector_3<K> get_opposite_orthogonal_vector(const Object& obj)
  {return Plane_constructor<Object>::get_opposite_orthogonal_vector(obj);}
} //namespace internal
struct Facet_plane_3 {
  template < class Facet_>
  typename Facet_::Plane_3 operator()( Facet_& f) {
    typedef Facet_                              Facet;
    typedef typename Facet::Plane_3             Plane;
    typedef Kernel_traits< Plane>               KernelTraits;
    typedef typename KernelTraits::Kernel       Kernel;
    typedef typename Kernel::Vector_3           Vector;
    typedef typename Facet::Halfedge_around_facet_const_circulator
                                                Halfedge_circulator;
    typedef typename Facet::Halfedge            Halfedge;
    typedef typename Halfedge::Vertex           Vertex;
    typedef typename Vertex::Point_3            Point;
    typedef Project_vertex_point< Halfedge, const Point> Proj_vertex_point;
    typedef Circulator_project< Halfedge_circulator, Proj_vertex_point,
      const Point, const Point*> Circulator;
    /* TODO: to implement a better approach
       typedef Project_vertex< Halfedge> Project_vertex;
       typedef Project_point< Vertex> Project_point;
       typedef Compose< Project_vertex, Project_point> Projector;
       typedef Circulator_project< Halfedge_circulator, Projector> Circulator;
    Circulator point_cir( f.facet_begin());
    Vector plane_orthogonal_vector;
    normal_vector_newell_3( point_cir, point_cir, plane_orthogonal_vector);
    CGAL_NEF_TRACEN( *point_cir);
    CGAL_NEF_TRACEN(internal::Plane_constructor<Plane>::get_type_plane(*point_cir, Vector( plane_orthogonal_vector)));
    if(plane_orthogonal_vector == Vector(0,0,0))
      std::cerr << "Error !!!!!!!!!!!!!!!!!!!!!!!" << std::endl;
    return(internal::Plane_constructor<Plane>::get_type_plane( *point_cir, Vector( plane_orthogonal_vector)));
template<typename Items, typename Polyhedron, typename SNC_structure>
class Index_adder {
  typedef typename SNC_structure::SHalfedge_handle   SHalfedge_handle;
  typedef typename Polyhedron::Halfedge_around_vertex_const_circulator
    Halfedge_around_vertex_const_circulator;
 public:
  Index_adder(Polyhedron& ) {}
  void set_hash(Halfedge_around_vertex_const_circulator,
		SHalfedge_handle) {}
  void resolve_indexes() {}
template<typename Polyhedron, typename SNC_structure>
class Index_adder<CGAL::SNC_indexed_items, Polyhedron, SNC_structure> {
  typedef typename Polyhedron::Halfedge_const_handle
    Halfedge_const_handle;
  typedef typename Polyhedron::Facet_const_iterator
    Facet_const_iterator;
  typedef typename Polyhedron::Halfedge_around_facet_const_circulator
    Halfedge_around_facet_const_circulator;
  typedef typename CGAL::Unique_hash_map<Halfedge_const_handle,
                                         SHalfedge_handle> Hash;
  Polyhedron& P;
  Hash hash;
 public:
  Index_adder(Polyhedron& P_) : P(P_) {}
  void set_hash(Halfedge_around_vertex_const_circulator evc,
		SHalfedge_handle se) {
    hash[evc] = se;
    Facet_const_iterator fi;
    for(fi = P.facets_begin(); fi != P.facets_end(); ++fi) {
	fc(fi->facet_begin()), end(fc);
      hash[fc]->set_index();
      hash[fc]->twin()->set_index();
      hash[fc]->twin()->source()->set_index();
      int se  = hash[fc]->get_index();
      int set = hash[fc]->twin()->get_index();
      int sv  = hash[fc]->twin()->source()->get_index();
      ++fc;
      CGAL_For_all(fc, end) {
	hash[fc]->set_index(se);
	hash[fc]->twin()->set_index(set);
	hash[fc]->source()->set_index(sv);
template <class Polyhedron_, class SNC_structure>
void polyhedron_3_to_nef_3(Polyhedron_& P, SNC_structure& S)
  typedef Polyhedron_                                Polyhedron;
  typedef typename Polyhedron::Facet::Plane_3        Plane;
  typedef typename Polyhedron::Traits::Kernel        Kernel;
  typedef typename SNC_structure::SNC_decorator      SNC_decorator;
  typedef typename SNC_structure::SM_decorator       SM_decorator;
  typedef typename SNC_structure::Vertex_handle      Vertex_handle;
  typedef typename SNC_structure::SVertex_handle     SVertex_handle;
  typedef typename SNC_structure::SFace_handle       SFace_handle;
  typedef typename SNC_structure::Point_3            Point_3;
  typedef typename SNC_structure::Sphere_point       Sphere_point;
  typedef typename SNC_structure::Sphere_segment     Sphere_segment;
  typedef typename SNC_structure::Sphere_circle      Sphere_circle;
  Index_adder<typename SNC_structure::Items,
    Polyhedron, SNC_structure> index_adder(P);
  CGAL_NEF_TRACEN("  calculating facet's planes...");
  std::transform( P.facets_begin(), P.facets_end(),
		  P.planes_begin(), Facet_plane_3());
  typename Polyhedron::Vertex_iterator pvi;
  for( pvi = P.vertices_begin(); pvi != P.vertices_end(); ++pvi ) {
    typename Polyhedron::Vertex pv = *pvi;
    Vertex_handle nv = S.new_vertex();
    nv->point() = pv.point();
    nv->mark() = true;
    CGAL_NEF_TRACEN("v "<<pv.point());
    SM_decorator SM(&*nv);
    Halfedge_around_vertex_const_circulator pe = pv.vertex_begin(), pe_prev(pe);
    CGAL_assertion_code(Halfedge_around_vertex_const_circulator pe_0(pe));
    CGAL_assertion( pe != 0 );
    Point_3 pe_target_0(pe->opposite()->vertex()->point());
    Point_3 sp_point_0(CGAL::ORIGIN+(pe_target_0-pv.point()));
    Sphere_point sp_0(sp_point_0);
    SVertex_handle sv_0 = SM.new_svertex(sp_0);
    sv_0->mark() = true;
    pe++;
    CGAL_assertion(pe != pv.vertex_begin());
    SVertex_handle sv_prev = sv_0;
    bool with_border = false;
    do {
      //      CGAL_assertion(!pe->is_border());
      CGAL_assertion(pe_prev->face() == pe->opposite()->face());
      CGAL_assertion(pe_prev->vertex()->point()==pv.point());
      CGAL_assertion(pe->vertex()->point()==pv.point());
      Point_3 pe_target = pe->opposite()->vertex()->point();
      Point_3 sp_point = CGAL::ORIGIN+(pe_target-pv.point());
      Sphere_point sp(sp_point);
      SVertex_handle sv = SM.new_svertex(sp);
      sv->mark() = true;
      //      CGAL_NEF_TRACEN(pe_prev->facet()->plane());
      CGAL_NEF_TRACEN(pe_target);
      CGAL_NEF_TRACEN(pe_prev->opposite()->vertex()->point());
      if(pe_prev->facet()->plane().is_degenerate()) {
	typename Polyhedron::Halfedge_around_facet_const_circulator fc(pv.vertex_begin()), fcend(fc);
	std::cerr << "wrong cycle "  << std::endl;
	CGAL_For_all(fc,fcend) {
	  std::cerr << "  " << fc->vertex()->point() << std::endl;
      CGAL_assertion(pe_prev->is_border() ||
                     !internal::Plane_constructor<Plane>::get_plane(pe_prev->facet(),pe_prev->facet()->plane()).is_degenerate());
		     has_on(pe_prev->opposite()->vertex()->point()));
		     internal::Plane_constructor<Plane>::get_plane(pe_prev->facet(),pe_prev->facet()->plane()).has_on(pe_target));
		     internal::Plane_constructor<Plane>::get_plane(pe_prev->facet(),pe_prev->facet()->plane()).has_on(pv.point()));
      if(pe_prev->is_border())
	with_border = true;
      else {
	typename Kernel::Plane_3 ss_plane
	  (CGAL::ORIGIN,
           internal::Plane_constructor<Plane>::get_opposite_orthogonal_vector(pe_prev->facet()->plane()));
	Sphere_circle ss_circle(ss_plane);
	CGAL_assertion(ss_circle.has_on(sp));
	CGAL_assertion(ss_circle.has_on(sv_prev->point()));
	SHalfedge_handle e = SM.new_shalfedge_pair(sv_prev, sv);
	e->circle() = ss_circle;
	e->twin()->circle() = ss_circle.opposite();
	e->mark() = e->twin()->mark() = true;
	index_adder.set_hash(pe_prev, e);
      sv_prev = sv;
      pe_prev = pe;
      ++pe;
    while( pe != pv.vertex_begin() );
    CGAL_assertion(pe_prev->face() == pe_0->opposite()->face());
    CGAL_assertion(pe_0->vertex()->point()==pv.point());
    CGAL_NEF_TRACEN(internal::Plane_constructor<Plane>::get_plane(pe_prev->facet(),pe_prev->facet()->plane()));
    CGAL_NEF_TRACEN(pe_target_0);
		   internal::Plane_constructor<Plane>::get_plane(pe_prev->facet(),pe_prev->facet()->plane()).has_on(pe_target_0));
    SHalfedge_handle e;
    if(pe_prev->is_border()) {
      with_border = true;
      e = sv_prev->out_sedge();
    } else {
	(CGAL::ORIGIN,
      CGAL_assertion(ss_plane.has_on(sv_prev->point()));
      CGAL_assertion(ss_circle.has_on(sp_0));
      e = SM.new_shalfedge_pair(sv_prev, sv_0);
    // create faces
    SFace_handle fext = SM.new_sface();
    SM.link_as_face_cycle(e->twin(), fext);
    fext->mark() = false;
    if(!with_border) {
      SFace_handle fint = SM.new_sface();
      SM.link_as_face_cycle(e, fint);
      fint->mark() = false;
    SM.check_integrity_and_topological_planarity();
  index_adder.resolve_indexes();
} //namespace CGAL
#endif //CGAL_NEF_POLYHEDRON_3_TO_NEF_3_H
