- To:
- Subject: [cgal-discuss] Classification problem in 2D Alpha Shapes
- Date: Thu, 07 Oct 2010 15:03:56 +0200
Hello everybody,
I did a program which first computes the alpha shape (GENERAL mode) of some points for a specific alpha value and then classifies the points and the edges of the underlying Delaunay triangulation. The problem is that I do not understand the results I get.
First program:
- I compute the alpha shape (GENERAL mode, alpha value = *(A.alpha_begin())) of some points (cf. "fin.txt") and I classify the points and the edges of the underlying Delaunay triangulation (cf. Delaunay.png).
Output:
Reading 10 points from file
Alpha Shape computed
1 alpha shape edges
--OUT--
0.848177 0.590931 0.884446 0.641268
EIRS 0 0 0 10
EIRS 20 0 0 1
So I get only 1 edge: 20 edges are "exterior", 1 is singular (cf. alphaShapeSegments_1.png).
I agree with this result but I do not understand why I get 10 singular points (EIRS 0 0 0 10).
Second program:
- I compute the alpha shape (GENERAL mode, alpha value = *(A.alpha_begin()+9)) of some points (cf. "fin.txt") and I classify the points and the edges of the underlying Delaunay triangulation (cf. Delaunay.png).
Output:
10 alpha shape edges
--OUT--
0.884446 0.641268 0.727141 0.658053
0.604772 0.345775 0.69997 0.404789
0.727141 0.658053 0.848177 0.590931
0.560009 0.78025 0.407242 0.774075
0.324098 0.0413514 0.484923 0.0451195
0.188165 0.171543 0.324098 0.0413514
0.727141 0.658053 0.560009 0.78025
0.69997 0.404789 0.848177 0.590931
0.727141 0.658053 0.69997 0.404789
EIRS 0 0 3 7
EIRS 11 0 3 7
In this case, I do not understand both results: "EIRS 0 0 3 7" and "EIRS 11 0 3 7" (cf. alphaShapeSegments_2.png).
Thank you very much for your help,
Best Regards,
Benoît
--OUT--
EIRS 0 0 3 7
EIRS 11 0 3 7
Takes a list of points and returns a list of segments corresponding to the
Alpha shape.
#include <CGAL/algorithm.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Alpha_shape_2.h>
#include <iostream>
#include <fstream>
#include <vector>
#include <list>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::FT FT;
typedef K::Point_2 Point_2;
typedef K::Segment_2 Segment_2;
typedef CGAL::Alpha_shape_vertex_base_2<K> Vb;
typedef CGAL::Alpha_shape_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<K,Tds> Triangulation_2;
typedef CGAL::Alpha_shape_2<Triangulation_2> Alpha_shape_2;
typedef Alpha_shape_2::Face Face;
typedef Alpha_shape_2::Vertex Vertex;
typedef Alpha_shape_2::Edge Edge;
typedef Alpha_shape_2::Face_handle Face_handle;
typedef Alpha_shape_2::Vertex_handle Vertex_handle;
typedef Alpha_shape_2::Face_circulator Face_circulator;
typedef Alpha_shape_2::Vertex_circulator Vertex_circulator;
typedef Alpha_shape_2::Locate_type Locate_type;
typedef Alpha_shape_2::Face_iterator Face_iterator;
typedef Alpha_shape_2::Vertex_iterator Vertex_iterator;
typedef Alpha_shape_2::Edge_iterator Edge_iterator;
typedef Alpha_shape_2::Edge_circulator Edge_circulator;
typedef Alpha_shape_2::Alpha_iterator Alpha_iterator;
typedef Alpha_shape_2::Alpha_shape_edges_iterator Alpha_shape_edges_iterator;
void alpha_all_edges(const Alpha_shape_2& A)
int r=0,s=0,i=0,e=0;
for(Alpha_shape_2::Finite_edges_iterator it = A.finite_edges_begin();
it != A.finite_edges_end();
++it)
switch ( A.classify(*it) )
case Alpha_shape_2::REGULAR: ++r; break;
case Alpha_shape_2::SINGULAR: ++s; break;
case Alpha_shape_2::EXTERIOR: ++e; break;
case Alpha_shape_2::INTERIOR: ++i; break;
std::cout << "EIRS " << e << " " << i << " "<< r << " " << s << std::endl;
void alpha_all_vertices(const Alpha_shape_2& A,std::vector<Point_2> &points)
for(std::vector<Point_2>::iterator it = points.begin();it !=
points.end();++it)
//std::cout << "*it "<<*it<<std::endl;
template <class OutputIterator>
void
alpha_edges( const Alpha_shape_2& A,
OutputIterator out)
for(Alpha_shape_edges_iterator it = A.alpha_shape_edges_begin();
it != A.alpha_shape_edges_end();
++it){
*out++ = A.segment(*it);
bool
file_input(OutputIterator out)
std::ifstream is("./fin.txt", std::ios::in);
if(is.fail()){
std::cerr << "unable to open file for input" << std::endl;
return false;
int n;
is >> n;
std::cout << "Reading " << n << " points from file" << std::endl;
CGAL::copy_n(std::istream_iterator<Point_2>(is), n, out);
return true;
//------------------ main -------------------------------------------
int main()
std::vector<Point_2> points;
if(! file_input(std::back_inserter(points))){
return -1;
Alpha_shape_2 A(points.begin(), points.end(),
FT(10000),
Alpha_shape_2::GENERAL);
Alpha_iterator alpha_it = A.alpha_begin();
A.set_alpha(*alpha_it);
std::vector<Segment_2> segments;
alpha_edges( A, std::back_inserter(segments));
std::cout << "Alpha Shape computed" << std::endl;
std::cout << segments.size() << " alpha shape edges" << std::endl;
//DEBUG
std::cout<<"--OUT--"<<std::endl;
std::vector<Segment_2>::iterator it_seg = segments.begin();
while(it_seg != segments.end())
std::cout<<(*it_seg)<<std::endl;
it_seg++;
//FIN DEBUG
alpha_all_vertices(A,points);
alpha_all_edges(A);
return 0;
Alpha shape.
#include <iostream>
#include <fstream>
#include <vector>
#include <list>
typedef K::FT FT;
++it)
points.end();++it)
void
OutputIterator out)
++it){
bool
if(is.fail()){
return false;
int n;
is >> n;
return true;
int main()
return -1;
FT(10000),
A.set_alpha(*(alpha_it+9));
//DEBUG
it_seg++;
//FIN DEBUG
alpha_all_edges(A);
return 0;
Description: PNG image
5.6000861e-01 7.8025025e-01
6.9996984e-01 4.0478872e-01
3.2409775e-01 4.1351351e-02
4.8492261e-01 4.5119464e-02
4.0724158e-01 7.7407523e-01
8.8444597e-01 6.4126785e-01
7.2714145e-01 6.5805292e-01
8.4817671e-01 5.9093100e-01
1.8816486e-01 1.7154302e-01
6.0477158e-01 3.4577464e-01
1 alpha shape edges
--OUT--
EIRS 0 0 0 10
EIRS 20 0 0 1
- [cgal-discuss] Classification problem in 2D Alpha Shapes, Benoît Presles, 10/07/2010
- Re: [cgal-discuss] Classification problem in 2D Alpha Shapes, Sebastien Loriot (GeometryFactory), 10/11/2010
