- To:
- Subject: [cgal-discuss] Delaunay_d and threads
- Date: Thu, 7 Oct 2010 11:30:35 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=IVx/VXhuZ2IJKuuz6QJUhf4ct5lisVk7W9EYxI/SUhCP59rc8IeqISRcT5Ff5deeIc DgP9HDka2fhkRf5q6lFYCbQR8XtuYZRfhAk2OnCjmbhRaA3HK2crmyQ+2C5rVsxA4l1W pOTewKF00yIMNiDwH4bYi3jzKHsZJOt5ulcug=
Hello.
I am using Delaunay_d to maintain a 4D triangulation of a set of points. After the algorithm terminates, my application launches at about 2000 Dt.locate() queries. To speed the queries up, I employ threads each of which calls some out of the 2,000 queries.
Delaunay_d requires Gmpq to be the RT. Since Gmpq is not thread safe, I replaced Gmpq with mpq_class. It seems, however, that mpq_class causes problems when Delaunay_d tries to determine the orientation of a point to hyperplanes. Is that because of parallelism or because mpq_class is not so exact as Gmpq?
I know that thread safety in CGAL is still an unresolved issue, but I just want to ask if there is a solution to what I am trying to do.
Best Regards,
Panagiotis Foteinos
- [cgal-discuss] Delaunay_d and threads, Panagiotis Foteinos, 10/07/2010
