- To:
- Subject: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
- Date: Tue, 19 Oct 2010 18:06:57 +0200
Dear CGAL community,
I'm trying to use CGAL to locate closest points in a point cloud, and
am having problems with it.
I tried to modidy the example distance_browsing.cpp as below. When I
only insert one copy of the point set into the search tree, everything
is fine; however, once the second copy is inserted, I trigger a CGAL
assertion. (Of course in my real application the problem is that I
genuinely have duplicates.)
> terminate called after throwing an instance of 'CGAL::Assertion_exception'
> what(): CGAL ERROR: assertion violation!
> Expr: new_rd >= copy_rd
> File:
> /opt/cgal/3.7_boost1.40/include/CGAL/Orthogonal_incremental_neighbor_search.h
> Line: 267
> Aborted
What do I need to change to make CGAL cope with duplicate points?
Best regards,
Sebastian Kapfer
Minimal example:
Input file:
http://www.theorie1.physik.uni-erlangen.de/people/skapfer/points_in_searchtree.txt
Code:
http://www.theorie1.physik.uni-erlangen.de/people/skapfer/distance_browsing.cpp
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Orthogonal_incremental_neighbor_search.h>
#include <CGAL/Search_traits_3.h>
#include <fstream>
typedef CGAL::Simple_cartesian<double> K;
typedef K::Point_3 Point_d;
typedef CGAL::Search_traits_3<K> TreeTraits;
typedef CGAL::Orthogonal_incremental_neighbor_search<TreeTraits>
NN_incremental_search;
typedef NN_incremental_search::iterator NN_iterator;
typedef NN_incremental_search::Tree Tree;
// A functor that returns true, iff the x-coordinate of a dD point is not
positive
struct X_not_positive {
bool operator()(const NN_iterator& it) { return ((*it).first)[0]<0; }
// An iterator that only enumerates dD points with positive x-coordinate
typedef CGAL::Filter_iterator<NN_iterator, X_not_positive>
NN_positive_x_iterator;
int main() {
Tree tree;
std::ifstream is ("points_in_searchtree.txt");
double x, y, z;
while (is >> x >> y >> z)
tree.insert (Point_d (x, y, z));
if (0) // change to 1 to insert second copy
double x, y, z;
for (int i = 0; i != 32; ++i)
for (int j = 0; j != 256; ++j)
for (int k = 0; k != 256; ++k) {
Point_d query (i*.5/32+.25, j*.5/32+.25, k*.5/32+.25);
NN_incremental_search NN(tree, query);
NN_positive_x_iterator it(NN.end(), X_not_positive(), NN.begin()),
end(NN.end(), X_not_positive());
for (int j=0; (j < 5)&&(it!=end); ++j,++it);
return 0;
Best regards, | Institut für Theoretische Physik I
Sebastian Kapfer | Staudtstr. 7, FAU Erlangen-Nürnberg
| Building B3, room #02.585
| Phone: +49-9131-85-2-8452
- [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/19/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Laurent Rineau (GeometryFactory), 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Laurent Rineau (GeometryFactory), 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/22/2010
