- To:
- Subject: Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
- Date: Wed, 20 Oct 2010 17:29:10 +0200
>>> your example (you can use the script cgal_create_cmake_script to
>>> generate a CMakeLists.txt)
>> Using CMake has nothing to do with it.
> I think it does.
> The config flag of gcc should have been set when configuring CGAL.
> Can you give me the content of CGAL_CXX_FLAGS in CMakeCache.txt
> where you configure CGAL.
After running ccmake . (2.8.2):
sk@noether(/scratch/sk/CGAL-3.7)>
grep CGAL_CXX_FL CMakeCache.txt
CGAL_CXX_FLAGS:STRING= -frounding-math -fno-strict-aliasing
Hm. *puzzled*
Best regards, | Institut für Theoretische Physik I
Sebastian Kapfer | Staudtstr. 7, FAU Erlangen-Nürnberg
| Building B3, room #02.585
| Phone: +49-9131-85-2-8452
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, (continued)
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Laurent Rineau (GeometryFactory), 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Laurent Rineau (GeometryFactory), 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/21/2010
