cgal-discuss - Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
  • To:
  • Subject: Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
  • Date: Wed, 20 Oct 2010 15:39:02 +0200
Sebastian Kapfer wrote:
Dear Sebastien!
On Wed, Oct 20, 2010 at 11:27:26AM +0200, Sebastien Loriot (GeometryFactory)
wrote:
I can see you have a 64bits machine. Mine is 32.
I try on a 64bits machine and still you code ran without
assertion failure.
Did you used cmake to build CGAL?
Yes.
can you try using cmake to generate the makefile to compile
your example (you can use the script cgal_create_cmake_script to
generate a CMakeLists.txt)
Using CMake has nothing to do with it.
I think it does.
The config flag of gcc should have been set when configuring CGAL.
Can you give me the content of CGAL_CXX_FLAGS in CMakeCache.txt
where you configure CGAL.
In the meantime, I tried on a more modern machine. Ubuntu Lucid, GCC
4.4, AMD64, Boost 1.43, CGAL 3.7. Same problem.
But your mention of your 32 bit machine tripped me off. Of course, on
AMD64, GCC uses the SSE unit to implement floating point, which has
64-bit floats all the way through, and doesn't use 80-bit floats for
registers.
sk@noether(~/spielwiese/fast_thicken/MinimalExample)>
g++ -O3
-frounding-math -mfpmath=387 -lCGAL -odistance_browsing
distance_browsing.cpp sk@noether(~/spielwiese/fast_thicken/MinimalExample)>
./distance_browsing sk@noether(~/spielwiese/fast_thicken/MinimalExample)> g++ -O3
-frounding-math -mfpmath=sse -lCGAL -odistance_browsing
./distance_browsing terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: new_rd >= copy_rd
File:
/opt/cgal/3.7_boost1.40/include/CGAL/Orthogonal_incremental_neighbor_search.h
Line: 267
Aborted
(see http://gcc.gnu.org/onlinedocs/gcc/i386-and-x86_002d64-Options.html)
So it seems CGAL works when using 80-bit floats, but not with true
64-bit floats?
