cgal-discuss - Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
  • To:
  • Subject: Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
  • Date: Wed, 20 Oct 2010 10:55:58 +0200
Hello!
On Wed, Oct 20, 2010 at 10:12:06AM +0200, Sebastien Loriot (GeometryFactory)
wrote:
> Hello,
> I tried to run it with CGAL 3.7beta1 and CGAL-3.7 and your code
> is working without assertion failure on my machine in both cases.
Oops?
Compiler is g++ (GCC) 4.2.4 (Ubuntu 4.2.4-1ubuntu4)
(from Ubuntu 8.04 LTS)
Boost libraries (1.40) and CGAL (3.7 final) are self-compiled.
I'm compiling the demo with the command
g++ -frounding-math -O3 distance_browsing.cpp -lCGAL
Optimization level seems not to be the issue, -O0 triggers the assertion
too. I added -frounding-math since CGAL notified me to do so. Any
other flags one should use?
Related stuff:
ii g++-4.2 4.2.4-1ubuntu4
ii libgmp3c2 2:4.2.2+dfsg-1ubuntu2
ii libgmpxx4ldbl 2:4.2.2+dfsg-1ubuntu2
ii libmpfr1ldbl 2.3.1.dfsg.1-2ubuntu1
Current versions are being used:
$ g++ -frounding-math -O3 distance_browsing.cpp -lCGAL -dynamic
$ ldd a.out
linux-vdso.so.1 => (0x00007fff98dff000)
libCGAL.so.6 => /opt/cgal/3.7_boost1.40/lib/libCGAL.so.6
(0x00007fe39f7ec000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007fe39f4e1000)
libm.so.6 => /lib/libm.so.6 (0x00007fe39f260000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007fe39f052000)
libc.so.6 => /lib/libc.so.6 (0x00007fe39ecf0000)
libgmpxx.so.4 => /usr/lib/libgmpxx.so.4 (0x00007fe39eaec000)
libmpfr.so.1 => /usr/lib/libmpfr.so.1 (0x00007fe39e8ab000)
libgmp.so.3 => /usr/lib/libgmp.so.3 (0x00007fe39e66c000)
libboost_thread.so.1.40.0 =>
/opt/boost/1_40_0/lib/libboost_thread.so.1.40.0 (0x00007fe39e457000)
/lib64/ld-linux-x86-64.so.2 (0x00007fe39fa1b000)
librt.so.1 => /lib/librt.so.1 (0x00007fe39e24e000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00007fe39e032000)
Thank you for any pointers!
Best regards, | Institut für Theoretische Physik I
Sebastian Kapfer | Staudtstr. 7, FAU Erlangen-Nürnberg
| Building B3, room #02.585
| Phone: +49-9131-85-2-8452
